Question about Frigidaire Refrigerators
Have frigidaire freezer...not freezing food,,,food thawing....but still running....should switch at bottom is off....if ytou turn it on, it buzzes. FOOD THAWING!
    President:
  • 1,099 Answers
The first thing I would do is to check the compressor and the condenser fan. Remove the cover on the back of the fridge and check how hot is the compressor? Is the condenser fan turning well? Also check the condenser coil under the fridge, it is very possible it needs cleaning.
If the condenser fan is not working properly then it has to be replaced.
ALSO NOTE THAT
You need to check the temperature settings and see if there is enough air flow in the refrigerator and freezer. You need to check for air flow restrictions in the vents and clean the compressor coils. The door seals, door switch, defrost heater and timer has to be checked. Also clean the clogged drain tube and refrigerant leak.
If you have try all of the above and it is not working in such case you need a certified technician to fix a leak and to charge the system.
Good luck.
Posted on Jul 07, 2010
Frigidaire upright FFU17f9gw3 temperture light is on and food is starting to thaw. I put alot of freezer jam in freezer yesterday
If the control is "ON" and the compressor is not running, you will need a start relay... Make sure you didn't accidentally turn it off by pushing food against the control knob!
Jun 06, 2016 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Why are the sides of my frostfree freezer so hot?
check to see if you have a fan down by the compressor if so make sure it is running. if no fan you are starting to loose freon
Jul 25, 2014 | Frigidaire 13.7 cu. ft. / 388 liter...
LG bottom freezer not freezing food completely food starting to thaw. LG only 1 year old!!!
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 29, 2010 | LG LRDC22744 Bottom Freezer Refrigerator
My Frigidaire FRT21H7AS freezer is not working properly. It will freeze ice, but the ice is slick and some of the food is thawing. The fridge part is fine. I haven't noticed any temp problems with it. Just...
first try manual defrost/ cleaning drain holes,possibly blocked.no hot water.dry out, then switch back on should be okay.if not try replacing temp sensor in freezer.before you do use freezer temp guage to check minus 20c
Feb 11, 2010 | Frigidaire FRT21H7AS Top Freezer...
FREEZER NOT FREEZING AND F RIDGE FEELING WARM
Before you throw out this refrigerator, try a few simple tests.
First, open the freezer while the compressor is running and listen for the fan running. If it is not, this could be your problem. Replacement fans can be ordered from on-line parts stores, a local appliance repair shop, even ebay.
Second, try turning off the refrigerator and letting the coils in the freezer thaw completely. Of course, move your food to a safe place for a few hours while you thaw the freezer. If you really get ambitious, remove the rear panel from the freezer and look to see if the coils are frozen. If they are, thaw them and dry the freezer compartment completely. Reassemble the freezer and restart the refrigerator.
If the problem reoccurs, you may have a problem with your defrosting circuit.
Jan 30, 2010 | Frigidaire Freezers
Fridge is freezing everything!
There is a flap that directs the air from freezer to fridge. Sometimes this flap can stick Or the actuator that controls the flap can go out. Same with autodefrost timer which seems to give a lot of people trouble. Thermostat is at the top, uncirculated cold air sinks, food in the bottom of the fridge freezes.
Sep 09, 2009 | Frigidaire FRS3R5EMB Side by Side...
Freezer is in garage and has worked up until now. Still runs, makes a humming sound and is cold but not freezing. Food is thawing.
jeskjw
If it is below freezing in your garage the freezer will not work.
No freezer except one Frigidaire freezer will work in the extreme cold.
This one has a button to switch it to a refrigerator in the winter and a freezer in the summer.
Apr 06, 2009 | Frigidaire Freezers
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
