Question about Poulan Garden
I have a GBI 22 Weedeater blower and would like to get the owners and overhaul service manual
3 Suggested Answers
SOURCE: I have poulan/weedeater leaf blower
ignition coil,or blown head gasket...
Posted on Nov 09, 2009
2strokeJim
  • 577 Answers
SOURCE: weedeater blower GBI-22v starts then shuts off
see if it will run with the choke on, if so then looks like the carb needs new diaphram and needle
Posted on Oct 01, 2011
Spark plug gap on a stihl leaf blower shoulder strap
.0020 is the gap.Here's a link to your manual,it's listed in section 26,specifications. http://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/STIHL-BG-56-66-86-SH-56-86-Owners-Instruction-Manual.pdf I also had a B56C and after 2 years,the engine locked up,am very disappointed in these ,also have a weedeater that the carb had to be rebuilt twice,if you leave gas in them over the winter,it messes up the carb,we'll I threw the blower away,got a huskvana from lowes,it is awesome,Stihl has let me down,will never buy another one,guess your having problems now,want to buy my weedeater and 500 chain saw.lol.
Aug 08, 2015 | Stihl Garden
Weedeater gbi 22 leaf blower will not start, how do I start it and what could be the cause?
Replace the spark plug, drain last years fuel and use fresh fuel mix.
Sounds like you may have a fouled plug. A speck of carbon or other debris can short the gap causing ZERO runtime.
Apr 02, 2015 | Weedeater Garden
Have Homelite Yard Broom II UT08514. Fuel filter fell out of tank when I dumped old gas! Which little black tube (way back in the tank) does it belong on and how do I reconnect it? thanks
I have a GBI 22"v leaf blower anyway i replace a pull cord on blower but dosen't pull cusae it hard to pull i took everything apart again and again and still hard to pull the cord ok help me pelase.
Dec 18, 2011 | Garden
Weedeater blower GBI-22v starts then shuts off already cleaned carb,replaced fuel and filter and cleaned plug
Sep 27, 2011 | Garden
What is the gas and oil ratio for Weed Eater leaf Blower GBI 22V? please
40:1 which is 3oz. of 2 Cycle Oil to 1 Gallon of gas.
Jim
Aug 15, 2011 | Weedeater Gas Blower
Weedeater gbi 20 leaf blower will not start, how do I start it and what could be the cause?
Start procedure is, switch igbition on, lever to full choke, pull until it fires once, do not continue pulling with full choke, move choke to central position, crank engine until it runs, once warm move choke to off, if it refuses to start, drain the fuel tank and re fill with fresh mix, remove spark plug and check for a spark by earthing the plug against the cylinder, if after many pulls the spark plug is dry, there is a blockage in the carb, remove the air filter cover, remove the two allen screws holding the carb on, remove the single screw securing the alloy pump cover, under the diaphram is a filter, replace this filter, rebuild and try again.
Apr 23, 2011 | Garden
How can I connect the Vacuum parts .
here is the link to the pdf owners manual describing in detail how to switch the unit between blower and vacuum modes
http://weborder.husqvarna.com/order_static/doc/WOUS/WOUS2010/WOUS2010_545186750.pdf
Dec 27, 2010 | Weedeater 12 Amp Electric Blower Ebv215
Hi there! I have a used Poulan Weed Eater SV30 Barracuda 32cc Super Blower Mulching Vac w/ reconditioned engine; Engine Family TPW032UB24RA : EM and Serial No 96215N500274-1 I need an Owner's / Repair...
unbolt the cover and there is a pully under it,,,this pully holds the starter rope but its needs to be tenshond up first so it pulls the rope inside when let go,,,the rope is just knoted to the pully
also its a 20 to 1 petrol oil mix,,,for running it on,,,
Aug 21, 2010 | Poulan Garden
I have a weedeater leaf blower that will start when I put gas in the caberator but will not run otherwise
sounds like the carby needs an overhaul. bellows in carby that **** up fuel may need replacing
Jun 30, 2009 | RTO Weed Eater Electric Barracuda 2595...
I need an owners manual for model #bc3100
Go to... http://www.weedeater.com/poulanpro/indexAction.do?id=default Scroll down to Download Manuals on the right, then enter your model number. There you have the owners manual and parts manual.
Jun 25, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Garden Logo
491 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
