Question about Whirlpool Duet GHW9150P Front Load Washer
Get error code DLF Hear a clicking sound in the rear of the machine. Model # ghw9150pwd Serial @# csr 3710302
  • 5,911 Answers
"Fdl" is a door latch error code. This is an indication of either a defective door latch, defective Central Control Unit (CCU), or an interconnecting cable problem between the two. The "clicking" sound you hear from the rear of the washer could be the relay on the CCU. The following link explains how to troubleshoot the problem:
http://www.fixya.com/support/r4490349-fdl_error_code
I have included parts resources, if required, and the steps required to replace any defective parts. Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
In some cases, the error can occur when the washer is in the middle of the wash cycle. If the door remains locked and will not open, the following link explains how you can use the manual release to get the door to open:
http://www.fixya.com/support/r3576511-door_jam_on_kenmore_elite_and_whirlpool_
You may want to try using a wet/dry shop vac to pull a vacuum on the drain hose to try to pull as much of the water (if any) ot of the wash tub BEFORE opening the door.
NOTE: The error codes are NOT listed in the Owner's Manual. For a complete explanation of all the error codes, each one of these appliances comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to accurately troubleshoot this problem.
Read through the information provided and let me know if you need further assistance. I hope you find this information helpful.
Posted on Jul 07, 2010
Whirlpool front loader washer error code ef9
Hi Justin, we are sorry to hear you have an Error Code on your Washer. We would advise to unplug the Washer for a least a minute to see if it will reset. If that does not work we would advise scheduling service with an authorized servicer. For scheduling service please email us at Whirlpool_Reviews@Whirlpool.com with your name, address, phone number and model/serial number.
Apr 11, 2017 | Whirlpool Washing Machines
Error code 51 f for whirlpool cabrio was machine
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at Whirlpool_Digital@Whirlpool.com with your name, address, phone number and the model & serial numbers of the Washer.
Mar 23, 2017 | Whirlpool Washing Machines
Whirlpool Duet Washer door will not lock. Get a DLF default code
If you remove the kickplate thats located in the front lower part of the machine you will find a tech sheet in there with directions on how to activate the diagnostic mode and have the machines cpu run test on all the parts and tell you what the problem is
May 18, 2012 | Whirlpool Duet 3.8 cu. ft. Front Load...
Picture went out and red light on the stand by button blinks ten times and stops for sec and starts the ten blinks all over. When I turn TV on I can hear sound of the tv trying to turn on but no sound or...
10 blinks on KDP-57WS655 model no. is an error code for "High voltage protection". I can tell you exactly which part gone bad and assist you to fix it yourself. Click it here.
Jdvillanueva
Sep 29, 2011 | Sony Grand WEGA KDP-57WS655 57" Rear...
I have a Lenova Y460 laptop and Nokia BH 503 Head Phone. Pl advis me from where I get driver for Nokia BH 503 My head set is not connected and neither he hears my sound nor I don't hear sound from the...
Hi, Here is the site where u can download your software and install it accordingly.This will fix ur problem. http://www.broadcom.com/support/bluetooth/update.php http://76.73.5.11/csr-bt-1.0.0.376-x64.html or u can download as a torrent file.Download csr bluetooth driver from the following site and install it . This will fix ur prob. http://download.cnet.com/USB-Bluetooth-Driver-CSR/3000-2112_4-73867.html
Regards, sathyamoorthy
Nov 15, 2010 | Computers & Internet
What is code DLF
are you hearing a clicking sound and possible f11 as well with the FDL?
DL means door lock failure but if you are hearing a clicking sound that is comeing from the back of the unit toward the center rear that is your control board.
inspect your door lock first
at the top of the door lock you should see a button that you can press in and out is it still there?
if yes you have a bad control board
let me know how it goes
Feb 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite Frontload Washer not working
If you already changed the door lock the only other thing that controls that is the control board... It might be faulty.
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
DLF error code. What does that mean?
DLF probably means Door Latch Fault.
Jun 22, 2017 | Washing Machines
Error code dLF
"Fdl" is a door latch failure error code. This is usually an indication that the door latch requires replacement. The manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. In some cases, the washer will experience momentary "glitches" and can be cleared using this method. You may also want to inspect the door latch wiring to ensure all the connector plugs are intact and not loose or broken. You can access the door latch wiring harness by removing the top panel of the washer. Removing the panel is simple. Just remove the three screws that hald the panel in place in the rear of the washer. With the screws removed, the panel will slide back, then lift off. Locate the door latch assembly behind the front panel on the right hand side. Trace all the connectors from the door latch to the Central Control Unit (CCU) and make sure they are properly seated at both ends. If these preliminary steps do not clear your problem, it is recommended that you replace the door latch. The following link explains how:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
You can find a replacement latch assembly at searspartsdirect.com or repairclinic.com if you wish to order online. Just type in your complete model number. I hope you find this information helpful. Let me know if you require additional assistance. Hopefully you can solve your problem without requiring parts.
Sep 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
267 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
