I have a Go-Video DDV2110 dual-deck VCR. It worked well for years until: when I try to record from TV to video tape it shows RECORD, then records for two or three seconds, then IDX flashes on the screen, then STOP and recording stops. Will appreciate any help, Thanks! Walt Casey
    Genius:
  • 3,422 Answers
HI,
I'll let you know if there is a manual available for your model and you can then try out troubleshooting steps from there.
You can also try out a hard reset to see if it fixes the problem.Just unplug all the cords from back for 30min and then plug it back and see if it helps..
Goodluck..
Posted on Apr 18, 2008
  • Priya darshan Apr 18, 2008
    Go0t the manual.Please CLICK HERE
    Its a PDF file..Hope you have adobe reader to view it..
    Genius:
  • 3,587 Answers
IDX...hmmm..that is from a code that suggests a format issue. Anything different about the input you're using?
    Genius:
  • 1,665 Answers
Does it play and no record a tape?
How do I get the DVD to record what is on the VHS tape not the TV?
You can record from an external component, such as a camcorder or VCR, connected to any of the Recorder's external inputs.
1. Make sure that the component you want to record from is connected properly to the Recorder. See page 14.
2. Press AUX repeatedly to select the external input to record from.
• AV1: Audio/Video Input mounted on back panel.
• AV2: Audio/Video Input mounted on front panel.
• DV: DV Input mounted on front panel.
page 37 from manual:
http://resources.jvc.com/Resources/00/01/15/LVT2016-001B.pdf
If this fails, try to disconnect the tv input cable and connect the vcr cable.
Feb 04, 2016 | JVC DR-MV150B DVD Recorder/VCR
Vcr won't record
first try a new set of connecting wires these are the usually cheap wires that will give out easily. if that don't work ,its most likly gonna be the tape recorder itself. how old is it.
Jan 21, 2012 | GoVideo DV1130 DVD Player/VCR
I have a dvd/vcr rrecorder with no coaxial connection. How can I tape or record a TV program?
Hi,first of all I assume that your Magnavox DVD/VCR Dual Player has the recording features as well..othervise you cant do anything"NEGATIVE" ..If yes than follow the procedure below..
If you want to record your TV program while watching to your DVD/VCR system you need to connect "Video - Audio Output " RCA jacks or "Optic cable output" of your TV or CABLE box to "Audio-Video input or "Optic Cable input" of the DVD
There you go..Your TV's video and sound is on the
DVD/VCR Dual Player Receiver..of course your DVD source input should correspond with the jacks you used on the back...push "RECORD" button it should start for recording the coming signal into DVD
when you recording the output RCA jacks of DVD will generate the signal of whatever records that can be monitored with another TV set after properly connected..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 15, 2011 | Philips Magnavox DVD/VCR Dual Player
Recording from VHS to DVDR was going fine,then I stopped getting a picture. DVD player is fine plays back recordings etc. However tape player starts to play shows picture then stops showing video and...
Possibly dirty video heads. I would suggest that you run a head-cleaning tape through the VCR deck to shift surface dirt off the heads. If that doesn't work, or it sort of works, but not satisfactorily, unplug unit, carefully remove top cover, and with the VCR deck in view, gently clean the heads with a soft cloth or special cleaning stick (these look like flat q-tips but are intended for VCRs - available from electronics/hobby stores) and some alcohol (methylated spirit will work if that's all you got - but isopropyl alcohol is recommended - available from the same places as the sticks) clean the guides (gently so as not to disturb their alignment) clean the pinch roller/capstan shaft - CTL (on the right-hand side of the drum) and FE (left side) heads as well. The whole tape path should be carefully cleaned. Refit top cover (carefully), plug unit back into power, wait until it completes its startup/loading procedure, then put a tape in. You should now have a playback picture with the sound. You only need to do this as required if head-cleaning cassettes don't work properly.
If none of the above cures your problem, then the heads are abraded/worn - let's hope that isn't the case here. This model does not use a built-in head cleaner.
Feb 21, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
DV220MW9 DVD/VCR: won't record video on VHS
your cable tv connect into dvd/vcr,video/audio out connect to av in your tv,solved
Jul 06, 2009 | Philips Magnavox DVD/VCR Dual Player
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
Tuning channels in VCR mode to record
wich deice are you trying to record shows onto the vcr or dvd recorder? what is the brand and model of the unit?
Dec 19, 2008 | Televison & Video
Vcr will not record
THE CABLE OR ANTENA NEED TO SCREW INTO THE INPUT OF YOUR UNIT THEN A SMALL WIRE OUT TO THE TV FROM YOUR UNIT PUSH RECORD WHEN SHOW IS ON TV !SO ITS CABLE INTO VCR INPUT THEN CABLE FROM OUTPUT OF VCR TO TV ....TV ON CHANNEL 3 AND VCR UNIT ON CHANNEL 3
Dec 07, 2008 | Philips Magnavox DVD/VCR Dual Player
Memorex MVD4544 VCR will not record
Take the unit back to the store and exchange it for an other unit of the same. The likelyhood of two units not working is very slim, and good luck with your new unit.
Jan 26, 2008 | Televison & Video
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
