Question about Weber Genesis Gold B Grill
The infrared does not seem to be working
I have turned the gas on at the vaulve. I do not know if I am supose to hear it, but I dont. Can you give me some pointer on where I shoud look for the potential problem? Thank you
  • Gary Kenady
    Gary Kenady Jul 07, 2010
    Is it NG or Propane gas!
    Champion:
  • 274 Answers
If you don't hear gas, it could be the regulator and hose on an LP grill, or the regulator on a NG grill. Replacing them is fairly easy and inexpensive. It could also be a blockage, but you have to take the grill apart to check each valve for a blockage. If you do not hear gas at any of the valves, try the regulators first.
Posted on Jul 12, 2010
Generac GP5000 will turn over but will not start, If I spray start spray it turns over for a few seconds and stops. someone told me to use sea foam because it had been un-used for about 6 monhs. Ccould...
FRIST O FALL CHECK TO SEE IF THERE IS A SHUT OFF VAULVE UNDER THE GAS TANK SEE IF THIS IS OPEN ALSO HOW OLD IS THE GAS , DONT LEAVE GAS IN THE GAS TANK THE GAS TODAY DOES NOT HAVE BUT A MONTH OF SHELF LIFE. YOU MAY HAVE TO PULL THE CARB DOWN AND CLEAN THE BOWL AND THE JETS IN THE CARB ALSO START BY PUTTING FRESH GAS IN THE TANK
Aug 04, 2013 | Generac 5724 GP Series GP3250 Portable Gas...
Where are the timming mark for 1993 nissan quest
ignition timing is normaly on the harmonic balencer (the pully on the crank that drives fan belt).if not it will be on the fly wheel and there will be a small inspection plate and pointer.if your looking for vaulve timing / cam timing remove timing cover on the front of engine block (dont mess with this unless you know what your doing)..if your engine is belt or chain driven over head cam never ever turn engine backwards or the timing belt/chain can slip/jump and then the vaulves can hit the pistons upon starting ruening the engine
Aug 13, 2011 | Nissan Quest Cars & Trucks
I need to adjust vaulves on my 1996 king quad what is the gap suposed to be thanks
Hey there sorry for the late response
what do you have for a motor in the quad?
Mar 26, 2011 | Suzuki GT 380 Motorcycles
Our pilot light remains lit, but the logs will not light.
is the thermopile generating more then 600mv? If you dont know how to test that Id call a qualified service provider. You are dealing with a combustible appliance
Oct 17, 2009 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Hello i have a 2003 kia spectra, first i am very machanically inclined just not sure exactly could be wrong, car will start right up idle fine, but once you give it gas engine does not respond or rev up,...
check your w.o.t. (wide open throttle) paddle switch it is located in your intake (remove the airfilter hose and look inside engine side) it signals the computer (tells it the throttle air volume so the engine doesn't stall from too much air/ too little fuel
Aug 30, 2009 | 2003 Kia Spectra
I have a dodge grand caravan 2003, and it has a problem. when i turn ignition it wont start.normaly when i had turned the key before to ignition i hear the fuel flow because fuelpump is sending fuel to...
i would first check the fuse for the pump.then if it is good .i would replace the filterbecause it may be cloged and building pressure to that point which is why you just hear the click.hope this helps
Jul 22, 2009 | 2003 Dodge Caravan
Manual doe not give vaulve clearance for the GX120 honda engine
I managed to find a free Download of the technical manual on the internet so this covers all questions about the engine
Apr 28, 2009 | Honda 8 HP Engine
Sharp LC-45D40U Won't Power On! Need Help!
If doesn't give error code most probably is something wrong with 5 and 3.3 volts lines. Check first the power supply and try to start the tv with all connectors removed. Let only the one between main pcb and power supply. Look for shorted voltages lines.
Apr 10, 2008 | Televison & Video
Grundig Satellit 500 loses reception
Hi
I had such a pb.
IC 103 CX7961 stopt to oscillate after ~30s ...
so the plls ref was out
I changed it without results
In fact the plastic trimmer C138 (4-20pf) was bad???( insulation?)
Since changing (10 years ago) : no problem
Good luck
Dec 13, 2007 | Grundig Satellit 800 AM/FM/SW Radio
Weber Genesis Gold B Grill Logo
151 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Weber Grilling Expert? Answer questions, earn points and help others
