Question about Kenmore 75085 Air Conditioner
Wont get cool, can you refill?
Wont get cool
  • 31 Answers
Does AC turn on at all? if yes, remove front cover, do coils get cool at all? if no, thermostat may be bad telling unti that the desired temp reached is satified.. or.. you have the desired temp too low, if you have it set for 75 degrees, and it is 72 in your house, the fan will run and no cool air will be present.
Posted on Jul 07, 2010
Why wont my fridge cool?
Hy Tony,
Compressor is a pump and operates by a motor. Cooling is initiated by the coolant. If your fridge runs low in the coolant, it won't give you a satisfactory result. Have a qualified technician check and if need be, refill the appropriate coolant.
Oct 12, 2014 | Refrigerators
A/c wont work at low speeds
it might be a good idea to have a shop take a look at the system to diagnose it correctly. Perhaps it needs to be refilled or recharged.
Aug 23, 2014 | 2000 Mitsubishi Montero Sport
Replacing engine coolant
depending on what happened I'd do all of it! Before refilling hand flush with garden hose& plenty open cockpit at bottom or side drain rest close fill w/ water run 5 min turn off cool empty repeat at least twice before refilling with cold water for any debris proper antifreeze and amount after wards// as scale can form inside radiator a good flush wont hurt it and prolong life of radiator
Jul 14, 2014 | 1998 Jeep Cherokee
Runs but wont cool
dear sir/madam
i think your freezer have short gas problem there can be possible any leakage so please contect to your service technician for refill the gas .
thank you
please vote!
Sep 04, 2010 | Magic Chef Freezers
The ac in my tiburon wont cool, i can hear and see the compressor working but when i hit the a/c button the air isn't cool and i hear a hissing sound from inside the dash.
the refrigerant in your a/c system is low, I rec taking it into a shop and having it inspected for a leak and repaired & refilled
Jun 16, 2010 | 2006 Hyundai Tiburon
How do i refill the coolant in the car after replacing upper hose
hello, your car has a reservoir tank were you put the coolant in at all you have to do is start your car and it'll draw coolant from there after your car runs a few minutes check your coolant reservoir tank it;ll probably be close to empty also since you took your hose off you'll have air in your system that you'll need to bleed out of the system otherwise your car will over heat and you wont get proper coolant flow the bleeder valve is a small brass bolt that you can use a wrench to open and close it with, with your car running just open the valve until you see coolant flow out then close it do this till you get a solid stream of coolant flow and check your reservoir often while doing this keep it full.
Apr 05, 2009 | 2005 Dodge Magnum
Heaterblows cool air my temp gauge showing truck is overheating
change the thermostate and gasket after you change it let the truck heat up then cool then refill the radiator again after the thermostate opens do not open the radiaator with the truck hot or the upper hose hard
Dec 10, 2008 | 1992 Ford Explorer
Kenmore 75085 Air Conditioner Logo
189 people viewed this question
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
