Question about DeLonghi AD699 Airstream Digital 1500 Watts Toaster Oven with Convection Cooking
How to change the lower element on a delonghi AD 699 toaster oven?
    President:
  • 1,099 Answers
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Hope this work ..........
    Posted on Jul 07, 2010
    Delonghi xr640 toasting-finished chime not working
    follow this steps and fix it. God bless you
    f the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical service panel and test the electrical cord . If the oven doesn't work on its toaster and oven functions, test the main switch . As needed, check the fuse .
    If the toaster function doesn't turn off unless the door is open, test the solenoid, the switch and if necessary, the thermostast.
    Location of the typical toaster oven's thermal fuse.
    If the toaster oven stays on when the door is opened, check the main switch . If the oven doesn't heat, test the heating elements.
    Oct 27, 2013 | DeLonghi XR640 Retro 1500 Watts Toaster...
    Can I replace elements in my Delonghi convection oven?
    Don't know about every toaster/convection oven but here is an address that has a list of sites that sell parts. If you can replace then someone would sell the elements.
    netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
    ToasterandConvectionOvens.com
    Feb 10, 2011 | DeLonghi AD679 1500 Watts Toaster Oven...
    The lower electric elements are twisted and do not put out the proper amount of heat Can they be replaced
    Go to the DeLonghi website. You can probably email them or maybe even call them. Also, here is an address that will bring up a list of places that sell oven parts. Copy and paste it into the address bar.
    <a href="http"//www.toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
    Feb 01, 2011 | DeLonghi AR680-Stainless Steel Toaster...
    My toaster oven stopped heating all together.
    your heating element has gone bad or there is some bad wiring in the oven itself
    to check open up the toaster oven and look at the wires coming from the heating elements inside to the timer on the front panel if there is no bad wiring then the heating elements are bad and the toaster oven needs to be replaced
    Jan 02, 2011 | DeLonghi XR640 Retro 1500 Watts Toaster...
    Bottom elements on DeLonghi AD699 failed.
    Solution: buy a new toaster oven. I determined that the manufacturer stopped selling replacement heating elements in 2006, three years after the model year (2003). After market parts makers don't sell the elements for safety and liability reasons. So I got a new one.
    Nov 17, 2009 | DeLonghi AD699 Airstream Digital 1500...
    Delonghi AS690 toaster oven lower element won't turn on.
    Cactus Bob Is WRONG. I've had these replaced; and then, when it happened subsequently, bought the part and replaced it myself. You have to take the entire thing apart. but it can be done.
    Mar 13, 2009 | DeLonghi AS690 Airstream Stainless Steel...
    Delonghi upper element warped
    We had a Hometek toaster oven with the same issue. OEMs won't send you spares for health and safety reasons. With care you can bend the element back into approximate shape, take care not to let the element touch any other metalwork in operation.
    Aug 17, 2008 | Toaster Ovens
    Heating elements
    The upper element for AS690 is part# 512623
    Thw lower element for AS690 is Part# 512624
    Available at www.nelsonappliance.com/Toaster+Oven+Parts.html
    or
    http://abtecparts.com/delonghi_toaster_oven_elements.htm
    Jan 03, 2008 | DeLonghi AS690 Airstream Stainless Steel...
    DeLonghi AD699 Airstream Digital 1500 Watts Toaster Oven with Convection Cooking Logo
    503 people viewed this question
    Top DeLonghi Toaster Ovens Experts
    Dave
    Dave
    Angel Joseph Jr.
    Angel Joseph Jr.
    Are you a DeLonghi Toaster Oven Expert? Answer questions, earn points and help others
