Question about Kenmore 75051 Wall/Window Air Conditioner
Kenmore 8000 BTU A/C runs, but won't blow air
A/C started after being in storage for a year, then gave a loud noise and now starts, but won't blow air. Help!!
  • 674 Answers
Sounds like a problem with the fan. There maybe something caught in it. If you had it stored is an outdoor environment then some wildlife (rodents) may have nested in it. You need to remove the cover and do a visual inspection. If nothing is caught in the fan then try turning it by hand and see if it spins freely. Some units have just 1 motor that turns the evaporator and condenser fan blades; others have 2 seperate fan motors.
Posted on Jul 07, 2010
I am hearing a little bit of squealing noise when running the ventilation fan in my house.
Sounds like you have a bearing going in the blower unit or a loose belt. Get it serviced by a reputable service company.
Oct 20, 2014 | Carrier Weathermaker 8000 Gas Furnace 125k...
I have an older 8000 btu unit - i have no manual. its 98 outside - when i start up this unit , should i have it on hi- med - or lo ? if i run it too hard will i freeze it up?
If everything is clean and the unit is properly charged with freon then it should not freeze up and I would start it anywhere you want to as that just controls the fan speed. It's108 here. Best of luck and thank you.
Jul 22, 2011 | Kenmore 8,000 BTU Single Room Air...
I have a single room 8000 btu kennmore air conditoner was making loud squealing noise when compressor kicks on and now it makes no noise and does not cool at all please help
sounds like the compressor may have died on you. the compressor isnt running you might as well trash it sorry for the bad news but it probably isnt worth trying to replace a compressor in a system like that it would drive you crazy and take forever if it could even be done.
Sep 17, 2009 | Kenmore 8000 BTU Single Room Air...
Kenmore 76081 cycling rapidly
check voltage when it shuts down possible motor overheating
Mar 09, 2017 | Kenmore 76081 Wall/Window Air Conditioner
A/c won't blow any air
check the status of the blower, if it is not working than try to open the front panel of the ac and check the wiring of the fan......or else contact the service authority. i'm sure that there will be any lose connection or the wire is disconnected/cut..............have a nice day :-)
May 14, 2009 | Fedders A6P09S2A Air Conditioner
2 Air Conditioner Problems
Whinny noise is probably motor which needs some motor machine oil (hardware store).
Freezing is probably caused by bad de-icing switch or poorly insulated de-icing switch.
If you want to further pursue, let me know.
Apr 30, 2009 | Heating & Cooling
Noise
Adding cloth or any other sound absorbing material will not work. There is not enough room to add anything appreciable in the fan area.
Jul 22, 2008 | Frigidaire FAC107P1A Wall/Window Air...
Kenmore 75051 Wall/Window Air Conditioner Logo
129 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
