Question about Bryant 463AAC008BA Air Conditioner
I have a Bryant model 597CN048-D that quit working suddenly. All circuit breakers recycled. Any suggestions? Also what is the tonnage for this model?
  • 43,501 Answers
That is a 4 ton unit...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Aug 16, 2010
What seer and tonnage is a Bryant condenser unit model # 561CJ048 and serial # 4598E06708?
According to the specifications here: http://dms.hvacpartners.com/docs/1009/public/01/pds561c.18.10.pdf , all Bryant 561C air conditioners are 10 SEER. The 048 model has a 4 ton nominal cooling capacity.
I hope this helps.
May 04, 2017 | Bryant Heating & Cooling
My main breaker a bryant bj2200b breaker is buzzing why is that
This could be a loose internal breaker contact or connection between the electrical panel and the breaker itself. This is particularly troubling if the breaker is warm / hot. You should have it checked by a competent electrician.
Oct 04, 2013 | Bryant /murray Bj2200 Main Circuit Breaker...
Our hot tub circuit breaker will not reset. It is a Cutler-Hammer 120/240. It is two years old. Any suggestions?
turn it to off position and then back, if it still wont reset it has gone bad and needs replacing
Sep 04, 2013 | Bryant /murray Bj2200 Main Circuit Breaker...
How to replace a Bryant GFCB120 Circuit Breaker
If you have a Bryant load center, you can use other breakers in it, including the Eaton GFCB120 GFI since several companies unified their design. The GFI (ground fault interrupter) or GFCI (ground fault circuit interrupter), same thing, may be required for a device you are installing, such as bathroom, kitchen or outdoor fixtures.
The Eaton series includes very clear installation instructions, but if your problem is that they are missing, then all you do is install the breaker in a open slot in the breaker panel, but you have to attach the neutral [white] wire differently. On regular breakers, the neutral goes right to the ground lug in the panel. With a GFI breaker, it goes through the breaker, and then is connected to the ground lug.
Mar 09, 2012 | Eaton Corporation GFCB120 GFI Circuit...
Is bryant breakers ok in a murray box
Look on the label inside the door on the circuit breaker panel. It should list part numbers for acceptable breaker. The key is the part number. Bryant is now owned by Westinghouse. Murry is now owned by Siemens. While many breakers will fit in other brand panels, they are only code compliant if they are listed for that panel in which they are installed. Since names have changed go by the breaker numbers. If the breaker number you have is listed on the label then it would be ok. Breakers aren't that expensive, if you have doubt, go to your supply house that carries Siemens and buy breakers listed for your panel.
Jul 11, 2010 | Bryant /murray Bj2200 Main Circuit Breaker...
I have a Murray panel and Bryant circuit breakers. the service is approximately 40 years old. I tried to replace the Bryant 15/15 and 20/20 with a Cutler hammer and Murray circuit breakers but they just...
It used to be you could never install more than 42 circuit breakers in a panel. If you have that many spaces you cannot install "twin" breakers in the panel. There is a rejection feature for this. Some panels will have a portion that allows twins in part of tha panel, but not all locations so you cannot exceed 42 breakers. You can sometimes tell by the legend that willshow a space divided on some positions and others not. There are many different brands that will "fit" into your panel (GE,Bryant,Murry,Arrrow Hart, Crouse Hinds, Siemens), but only use breakers listed to be used in your panel, or you will not have the protection intended. If it's 40 years old maybe it's time for an upgrade. Be careful in that panel and be aware of arc fault protection when working on engergized equipment.
Jun 24, 2010 | Bryant /murray Bj2200 Main Circuit Breaker...
Circuit breaker only half working - reddish flag?
A red indicator means a circuit overload has tripped the breaker. You mentioned a heater? Does the circuit tripping coincide with the heater running? There may be too much load on that circuit.
Contact the original electrician to see if he will come check it out ( licensed, reputable electrician should have no problem with this). If he gives you the run around, find another. Was any aluminum wiring found in the home inspection?
May 01, 2010 | Bryant 40 Amp 2 Pole Br240 Type Br Ni...
Am having problems with a 347002k, we have this recycler for some time and have replaced even the compressor. I think we need the digital control board with the input command (where you input the steps)....
You may did something wrong with your machine! Please try the following: 1# Switch ON the main power.2# Re-set (booth) circuit breaker (press booth breaker at the same time) & see if the screen is appear.3# If the screen is not appear after re-setting circuit breaker then you have to replace new control module.Hope this will help you.
Feb 18, 2010 | Robinair Cool Tech 34700Z Recovery,...
What is the seer rating and tonnage of a bryant model fb4anf030
The Tonnage appears to be 2 1/2 ton,
024=24,000 BTU=2ton
030=30,000 BTU=2 1/2ton
036=36,000 BTU= 3ton
I dont think you have the correct Model Number, Look
on the outdoor unit, the model number might start with a 38. Hint Carrier and Bryant Products are the Same, just different nametag
Feb 17, 2010 | Heating & Cooling
Heating & Cooling Logo
431 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
