Paper jam with epson rx585 but no paper in printer
Hi
I'm getting a message on my lcd that there's a paper jam but there's no paper in printer at all. I've tried turning it off then on again but keep getting same message
  • Anonymous Sep 30, 2008
    yes i have the exact same problem, if i hit it very hard repeadedly and keep turning it off and on eventually it works... until next time, which is usually the next time i use it
  • mjfpgh Nov 23, 2008
    Same thing here, tried to clear everything out of rollers there is nothing in there. Have turned it on and off enough to get a different error msg, but I still have not been able to print anything. I even uninstalled the drivers and reinstalled, nothing. Ready to get a new printer can't keep running to Fedex Office every time. HELP!
JSPCEXPRESS
  • 178 Answers
SOURCE: Dell 3000cn Laser Printer Problem--Paper Jam
Hello how are you Take the tray out on the bottom and see if there is a piece of something in there. Mine does this sometimes. Also on the back there is a drawer open this up and check. Have you taken out the toner yet. Do this and once you check every area as described turn power off to it and leave off for min. Then power back on and push cancel button about 5 times let me know if this works for you. It does for me
Posted on Feb 13, 2008
  • 158 Answers
SOURCE: False Paper Jam Message
Probably a jam sensor is dirty or stuck. Look through the paper path for a stuck plastic sensor arm, or dirt or paper dust on photocell typr sensors.Paper sensors are normally located near where paper feeds, and where it exits the machine. The paper must pass over these sensors as it travels through the machine.If a scrap of paper is left on the sensors, they will report it as a jam. If you can, try manually pushing a sheet of paper through the printer, ONLY in the direction it normally feeds. This may free up a stuck sensor arm, or force out the jammed scrap.
Posted on Jun 09, 2008
SOURCE: keep getting the error message "Paper jam"
mine does too! help
Posted on Sep 18, 2009
  • 14 Answers
SOURCE: Epson RX595 says "Error-paper jam" but no paper in printer!!!
Press the stop/clear button then press the maintaince button(spanner) and the ON button all at the same time in that order.That will reset it.It should work after that.Hope this helps you.
Posted on Apr 26, 2010
SOURCE: HP Officejet Pro 8500 printer message "Paper jam"
An error code showing that there is paper jam alert, but no paper is in anywhere in the machine except in the tray.....I have checked all areas, taken the back carriage of the unit, opened the top and opened the machine. removed the paper tray, everything, but there is no paper stuck in the unit
Posted on Jul 02, 2010
Rx585 paper jam
Turn off the printer and turn it back on. It just needs restarting.
David
Jun 18, 2013 | Epson RX585/RX595/RX610
Epson Photo RX510
Hi when you switch it on have you tried holding down the on off button for about 10 seconds as this often resets most printers.
Also when you sya thier is no paper jammed in printer are you absolutely sure their is not even i tiny bit of paper still stuck as it only takes a tiny bit of paper to make this message appear.
If you are confident in removing the paper feed witch is difficult to do as you need to make sure it goes back perfect as if it isnt the paper wont feed.
Alot of people say their is no paper jammedand they call somebody out to repair the printer and they get charged a fortune for removing a tiny bit of paper.
If holding the button down dont work then try switching the plug on whilst holding down the on off button let me know how you get on ok
Dec 10, 2007 | Epson RX620 All-In-One InkJet Photo...
Epson rx585 paper jam message but no paper jammed.. how can i fix it?? tried switching it off unplugging etc and its still the same..
The micro-switch that detects a paper-jam is still detecting a paper-jam.
Either there is paper-dust in the switch, causing the "false-positive" indication,
or the micro-switch is broken, or there really is a paper-jam that you have not detected.
Check the micro-switch, and look again for a paper-jam.
Aug 18, 2011 | Office Equipment & Supplies
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Paper jamming in rx585
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Oct 13, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
646 people viewed this question
k24674
jasbo
jasbo
