Question about Garmin Nuvi 660 GPS Receiver
Having problems with the touch screen. I am trying to touch the screen to enter my destination and nothing happens. I tried shutting it off/on and that didn't work. I also tried the reset button and still nothing happens when I touch the screen.
  • Garmin Master
  • 2,130 Answers
Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Posted on Jul 08, 2010
X544dn scanning and Windows Server 203
Scanning documents at the printer
1 Load the document into the scanner.
Note: Documents may be loaded into the scanner in multiple ways. For information on the different methods of loading documents into the scanner, see the User's Guide that came with the printer.
2 Touch Scan to Network. If prompted, enter the user name and password used to access the printer. Contact your system support person for login information.
3 Select the destination where you want to receive the scanned document. If prompted, enter the user name and password required to access the destination. Contact your system support person for login information.
4 Some additional job options may be available depending on how the application has been configured. Follow the instructions on the screen to update the options. Contact your system support person for more information on each option.
5 Touch Scan It. Depending on how the application has been configured, you may have the option to preview and make adjustments to scanned pages.
6 To scan additional documents, load the next document into the scanner and select one of the following from the confirmation screen:
• Touch Yes, to same destination to scan the document to the previous destination.
• Touch Yes, to a different destination to scan the document to a different destination.
• Touch No to finish the operation and return to the printer Home screen.
Jul 23, 2012 | Lexmark X544dn All-In-One Laser Printer
Hi I recently purchased a garmin nuvi 1410 and tried programming several sites in. however when i left one site and wanted to navigate onto the next, it kept trying to bring me back to the previous site...
Hi, there are 2 possible solutions to your problem.
1. Press WHERE TO and enter your first address. Instead of pressing GO press SAVE, at the bottom of the screen. This will save the site in your FAVOURITES folder. Repeat for each destination. Then when you want to go to one of these addresses just press WHERE TO then press FAVOURITES and select the address from it. If you're going to use these addresses fairly often then this is probably the best solution. When you reach your destination sometimes the satnav doesn't realise you have as, for example, you could be on the wrong side of the street to where it expects you to be or the satnav could be out by a few yards. When this happens it tries to get you to go back. To stop this press MENU at the bottom of the screen and then press STOP. (The STOP icon only appears while the satnav is trying to take you to a location) Having done this you can then select your next destination.
2. The second option for solving your problem is to enter your last destination first and press GO. Then enter your second last and when you press GO again it will ask you if you want to set this as a VIA point. Select YES. Add each destination in turn making them all VIA points. When you do this the satnav will take you to the last via point first and then each of the others on the way to your destination. The advantage of this method is that you don't have to set destinations when you're traveling. As soon as you reach one it adjusts to take you to the next. The disadvantages are that if you want to go to the same destinations again you need to re-enter all the information again. Also if the satnav thinks you have not reached your via point, when you have, pressing STOP cancels the whole route.
Entering the places into FAVOURITES is probably the best option. Note once they're in FAVOURITES you can rename them if you wish or you can delete them. You'll find details of how to do so on page 12 and 13 of the manual available in Adobe Reader format from http://static.garmincdn.com/pumac/nuvi_1100_1200_1300_1400_OM.pdf
May 09, 2011 | Garmin Nuvi 1410 Car GPS Receiver
MSI K9A2 CF motherboard powers up, but nothing happens
try to get into the bios and see if the function of the power switch assigned differently. there are MB that use the a hotkey in the keyboard to power-up the system. It should be there in bios. Read the MB's manual too. On OFF state, try typing "O" and "N" then hit enter
Aug 10, 2009 | MSI K9MM-V Motherboard
Touch screen controls offset by an inch
To Try To Test It,Go To Main Menu Then,Seting Then,Systum Settings Then Move Over 1 Then, Press Dionostics Then Touch Screen
Jul 11, 2009 | Magellan Maestro 4040 GPS Receiver
I can't scan.
The Scanning feature must resolve the name you have entered into the host location in the one touch screen. If the system is not able to resolve the name to an address it will fail. The easy way out of this is to enter the destination IP address. The hard way is to fix the reason the printer can not resolve destination name to an Ip address. That will require fixing a DNS problem on your network
Mar 27, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Nothing happens when you touch the screen
If you used it connected to your computer, for upgrades etc., reconnect it and shut it off through the computer before you unplug it. They get captured by the computer if you just unplug them.
Jan 30, 2009 | Tomtom ONE 3rd Edition GPS
Touch screen won't work
I had the same problem so i went searched to see if i could find a new touch screen which they call a digitizer. Every where i looked they costed about 110 bucks! good thing i did some digging there is this site call fonlogix.com......they have phone parts and the digitizer cost 20 buck plus about 10 buck freight through usps. i also recommend getting a screen protector. it works great now!
Jan 22, 2009 | LG Vu CU920 Cellular Phone
My screen doesn'i work
try removing the battery and then start up. Good luck
Oct 07, 2007 | Alpine PMD-B100 GPS Receiver
Tomtom one problems
Hi Dave "Has anyone else had these problems?" If it's any consolation I've just experienced a similar problem but the letter was "f" and not a "k". I couldn't get past this screen and had to switch it off and even then it sometimes remembered the fault. I took mine back because it was only 6 days old and asked for a full refund, which I received. I'm undecided what to do next, either buy a new one or wait till they settle down or try another manufacturer. Could there be a faulty batch out there?
Aug 25, 2007 | Tomtom One Europe v2 GPS Receiver
Enter location message
Joe, have you tried the external yet? Did that fix it? This sounds like a Hard Drive problem, but I would try re-loading /reflashing nand flash before I went the hard drive route. Do you have the software?
Nov 15, 2006 | Magellan RoadMate 700 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
128 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
