Question about Dishwashers
My dishwasher is stuck in the rinse mode. The model # KUDD01DPPA.
    President:
  • 1,099 Answers
Yes, there are 2 stats, hi limit and operating. You should find them attached to the pump housing. It gets a little tricky but the problem will boil down to one of the stats is bad or the heating element itself is bad [or something like a wire burned off at the element which will be obvious]. It can get a little tricky. I would start by checking to see if the element gets hot during operation. If no, ohm test the element itself. If ok, ohm test the high limit stat, it should be closed at room temp. If ok, try bypassing the operating stat and see if the element now gets hot during operation. Replacing the element and/or stats is not too hard except for the limited space to work underneath the machine.
Good luck...
Posted on Jul 07, 2010
Stuck on rice cycle both drawers
Rice? Rinse? Or is it the DRAIN motor that is constantly running. This might be due to a leak and water collecting in the base.
Sep 10, 2014 | KitchenAid 23 in. KUDD01DPPA Stainless...
Kitchenaid kuddo1dppa
test this steps and fix it. God bless you
Water Inlet Valve
The dishwasher has an electrical water valve called a water inlet valve. If the dishwasher won't fill with water, the water inlet valve might be defective. These valves are not repairable and will have to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Float
The float assembly is normally inside the dishwasher near the door on the floor of the dishwasher. If something gets stuck underneath it and holds the float assembly up, the dishwasher won't fill with water. If the float assembly moves freely up and down, the float switch might be defective.
Float Switch
The float switch is actuated by the float assembly. It is a protection device designed to prevent the dishwasher from overfilling. If the dishwasher won't fill with water, it may be because this float switch is defective or stuck.
Water Supply Problem
The dishwasher is connected to the hot water supply from the house. Check to be sure the household water supply valve is turned on. Over time, calcium deposits can build up in the water supply valve or in the small filter screen inside the water inlet valve. The water supply line may need to be removed from the water inlet valve of the dishwasher, then run some water into a bucket to see if there is enough pressure. Be certain to turn off the water before working on the water line.
Jul 22, 2013 | Dishwashers
The dishwasher gets stuck in rinse/ dry mode . It should complete full cycle in about an hour, but it washes and then does not rinse/ dry and go to OFF. Please advise
not a expert but id guess with my electrical knolage that a part needs replaceing proberbly obvious but without having a wireing diagram of that exact make and model sorry but thats all i can say my advice get a pro to look at it weigh up between cost of repair and a new dishwasher if u have a warrenty use it
Oct 30, 2012 | Dishwashers
Model#KUDD01DPPA Both Drawers keep reverting to light/china error code
Hi. I have the same problem. Were you able to find a solution? This error code means "motor failure". But how can both motors fail at the same time?
May 14, 2011 | KitchenAid 23 in. KUDD01DPPA Stainless...
My sr24h hobart undercounter dishwasher is stuck in a mode where all it does is drain water out. Will not do anything else...???
Hello There; If your unit stuck on the wash cycle and not advance to rinse cycle because the rinse water is not up to 180 degree . You've to check out the booster element and the rinse temp. I hope this will help.
Sep 19, 2010 | Hobart SR24-H Built-in Dishwasher
Kitchenaid superba kuds01ijbs0 rinse only light flashes
Hi there.See if you can find the reset button.If you can't find that unplug it and plug it back in to reset.That should fix the problem
Apr 01, 2009 | KitchenAid 23 in. KUDD01DPPA Stainless...
Dishwashers Logo
102 people viewed this question
Top Dishwashers Experts
Owen Barnes
