Question about HP Pavilion dv6000z Notebook
Speakers are not working from rear panel - HP Pavilion dv6000z Notebook
  • 77 Answers
Check sound properties and some sound drivers come with some applications. these applications is started along with your computer boots. for details check on taskmanager near to your system time. In that also some settings are there. check that also
Posted on Jul 07, 2010
My headphones will work but my desktop speakers will not why?
If your speakers work fine when plugged into the headphones socket on the front of the system, then there is no fault with them.
If the sound through the speakers is very low when plugged into the rear panel socket, that would suggest that you may be plugged into the line out socket rather than the speaker socket and that there is a mismatch of the impedence between the socket and speakers.
If you have three audio sockets on the rear panel, try the speakers in the second output socket (but not in the microphone socket) and see if it makes a difference.
You could try the same test using the headphones - do you still get good sound levels with the headphones when plugged in to the rear panel socket?
If neither the speakers nor headphones give good sound when plugged in to the rear panel, then you may have a problem with either the sound card if the sockets are on a separate PCI card, or with a poor connection on the cable to the socket header bracket from the motherboard pins for audio for integrated adapters.
Dec 23, 2011 | HP Compaq dc5000 Microtower PC Desktop
2007 avalanche rear speakers have no sound output. I don't believe they both could blow at the same time.... the rear radio is not on so it isn't that muting it. Is there some issue where they may mute...
I too have no sound from rear speakers...I bought speakers thinking they were simply not there. Went to install them and found that there all of a sudden was sound there. Put the rear door panel back on and it still worked until the next day. No sound from either side on rear again. I read somewhere that a seatbelt could be damaging a wiring harness causing it so I took off the panels covering the seat belts and found no way that the harness could be damaged from the belt. Weird how they worked momentarily when i had the pass rear door panel off though.
Aug 27, 2010 | Car Audio & Video
I dont know how to install stereo speakers in my citroen saxo VTR near the rear seats. how can i do this?
First you have to remove the old ones...
You cannot just clip out the rear speakers, as the cover over them is attached to the rear panel (2 door Saxos)
In order to take out the rear speakers, from what I remember...
1) Take out rear seats
-Get yourself in the car through one of the front doors
-Once inside face toward the rear seat
-Reach for gap between where the upper and lower parts of the seat join
-Pull the bottom half up and towards you
-Once it is vertical lift straight up to detach from pivot
-Get it out of the car to give you space
2) Undo 2 bolts
- Having just removed the lower part of the seat there are now 2 bolts visible 1 located each side of the car, next to the rear speaker panel.
- Undo the bolts, they are long so require lots of twisting until free
- Remember where the washer sat and place in safe location out of car
3) Lift up rear window seals
- Open rear windows
-Lift up the rubber seal which lies on the bottom part of the window
-(It is attached all the way round the window trim, only lifting it up is neccessary)
4) Remover upper seatbelt bolts
- Locate rear seat belts (side belts only)
- Locate top of seat belt fixing point
- Remove circular plastic covering on top joint of each belt (1 each side)
- This reveals seat belt joint bolt (1 each side)
- Undo bolts and place safely outside of car
- (Same for front seat belts required)
- Locate front seat belts
- Locate front seat belt joints at top of belt.
- Remove circular plastic covering (1 each side)
- This reveals bolt (1 each side)
- Undo bolt and place in safe location
5) Lower rear seat
- Open the boot
- Clamber in
- Locate where rear seat meets plastic trim (each side of car)
- Locate small plastic lever (each side of car)
- Push small plastic lever towards the front of the car (both sides same time)
- Meanwhile push rear seat gently towards front of car (helps if have a friend)
- This will lower seat
- (You do not want seat lowered completely, once seat is free in movement leave resting in normal position)
6) Remove rear speaker panels (requires trusted + competant friend)
-Friend Get in car sit where rear seat was on driver side (for space)
-You sit front seat passenger side
-You locate where rear speaker panel ends beside front door
-You pull rear speaker panel away from end at door towards opposite side
-You will notice part of rear speaker panel detach from car
-Friend and You pull off remainder of speaker panel from its poppers
-Notice lump of plastic preventing complete detachment from car
-Careful to prevent damage Friend and You need to move rear speaker panel towards front of car and up
-Remember plastic will flex, but is also capable of snapping
-Manipulating this action will get rear speaker panel detached from car...although still on the seatbelts themselves.
Notice how speaker is joined to hidden part of rear panel, rather than metal body work.
To remove rear speaker undo the 4 torx screws holding speaker in place, alongside wire joint (wire with plastic adaptor at end)
Do what you needed to do, and then return car to normal state by effectively reversing the above instructions.
(I accept no liability for any action you undertake from following these instructions.....yadda yadda)
If any problems contact a Sax-p I.C.E section expert, or if incounter any difficulties that the above cannot solve, any car audio installer can help, alongside most garages, including Citroen Dealerships.
The instructions above probably took longer to type than to actually perform, estimated time for completion is 40mins-1 hour.
Oct 24, 2009 | Car Audio & Video
A digram for the factory wireing for the radio
This color code works for 87-93 mustang factory radio; it might work on yours as well. I'm not sure if it has the same fuses though.
Radio Connector:
Light Green / Yellow - Hot at all times (Fuse 8)
Yellow / Black - Hot in ACC or Run (Fuse 11)
Light Brown / Red - Goes to instrument panel dimming rheostat (Fuse 4)
Red - Ground
White / Purple - Hot in ACC or Run (Fuse 11)
Speaker Connector:
White / Light Green - (+) Right Instrument Panel & Door Speaker
Dark Green / Orange - (-) Right Instrument Panel & Door Speaker
Brown / Pink - (+) Right Rear Speaker
Pink / Light Brown - (-) Right Rear Speaker
Pink / Light Green - (+) Left Rear Speaker
Tan / Yellow - (-) Left Rear Speaker
Light Brown / White - (+) Left Instrument Panel & Door Speaker
Orange / Light Green - (-) Left Instrument Panel & Door Speaker
Hope this helps.
Aug 15, 2009 | 1991 Ford Econoline
No sound from rear speakers Boston Acoustics BA 7800
check whether the wire is connected properly on both the ends
Aug 08, 2009 | Boston Acoustics (BA7800) Computer...
Need color code diagram for sterio
I'm not sure what year you have but this color code works for 87-93 mustangs.
Radio Connector:
Red - Ground
Speaker Connector:
Hope this helps.
Jun 19, 2009 | Ford Escort Cars & Trucks
Speakers no longer work when front panel audio cable connected.
Thats the point of the jumpers. They need to be connected to make the connection so the rear is disabled when you plug things in. Here is where your jumpers should be placed:
Basicly every other bank needs a jumper.
May 01, 2009 | ASUS K8V-MX Motherboard
Trouble with rear speakers
This may be a software issue. If you only had two speakers before, the software will not use the rear speakers.
Go to Control Panel. Click on "Sound and Audio Devices". Under the Volume Tab, at the bottom, you will see a picture roughly representing the type of speakers.
Click on the Advanced button.
Click on the arrow in the pick box, and choose Surround Speakrs or the 5.1 Speakers.
Click Okay. Try the speakers again.
Apr 06, 2009 | Boston Acoustics (BA7800) Computer...
Sound system Configuration !! only rear speakers working !
The "control panel" has things like "sound effect manager" or "sound max" in case of intel chipsets. Thru this you can configure the audio in and rear from laptop to act as front and rear outs.
The two can function cariably not always as rear and audio in!
Thats what my frnd did once to get quadrophonics to work.
Hope that might work for you too.. All loes in how you confiogure the sound effect manager or similar thing in the control panel..
Hope it works for you
Apr 12, 2008 | Computers & Internet
HP Pavilion dv6000z Notebook Logo
54 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
