Question about Hoover Company Wind Tunnel U53019 Upright Vacuum
My hoover has no suction. How do you unclog the hose?
    Genius:
  • 1,075 Answers
Get an old wire coat hanger and straighten it out and unclog you pipe.adrian,,,,
Posted on Jul 07, 2010
  • 34 Answers
SOURCE: no suction throught the hose
sounds like its blocked stick the broom handle thru it , there might be something plugging the hose under the bottom at the connection
Posted on May 22, 2009
reddevil6
  • 1673 Answers
SOURCE: Hoover z400 clogged
There should be a bottom plate covering the brush roll that you can remove, if you can't dig out the what is in there, try using your hose and suck it out from the bottom, maybe you will be able to get it out.
Posted on Mar 06, 2008
  • 4 Answers
SOURCE: no suction from hose
Usually, no easy fix to clogged hoses. In order to clear an obstruction from a hose, one can try to use a small diameter dry garden hose to push the obstruction through or the clog can sometimes carefully be fished out with a manual (not a powered) plumber’s snake. ~ TTURAMBAR
Posted on Mar 27, 2009
  • 175 Answers
SOURCE: hoover empower lost suction
This machine has quite a few airducts to it. You must have a clog up in there some where. Also, make sure that all the filters to this machine are clean. That will help with keeping the vacuum from getting clogged again.
Posted on Nov 20, 2009
  • 4088 Answers
SOURCE: brush spin,good suction at hose, no suction at
Air passage from back of brush head, through the joint, and up to bag, may be blocked.
Posted on Jul 12, 2009
Hoover dm6200 blowing air
check your suction hose again, follow it to where it goes into the body of the machine. I assume this will be near where the bagless cannister is. Remove the bagless cannister and look up inside to where the attachment hose should come into the cannister. I believe you are still blocked up there. using a butter knife or something along those lines should free up the blockage.
Also, if that is all clear, try re-adjusting the dirt cannister as it may not be on properly to create your suction flow through the hose.
Good luck and let me know if I can help further.
Jan 24, 2012 | Hoover Vacuums
Is there a switch to turn-off the tools so that
On the Hoover U6311-900 there is no switch that turns off the suction to the tool hose. That hose is attached to the head of the vacuum on the side via a spring loaded "door". Just twist the hose to remove it, the door will close and you will have full suction again.
Apr 06, 2010 | Hoover U6311-930 Power Drive Bagged...
I have a Hoover steamvac ultra. The handheld hose
If you have installed the hose properly, try to hold your hand over the suction end with the cleaner on to prime the water in the hose. There is no way to dissasemble the hose. You could have a possibility of a few thing that have failed,
1. the pump that feed the hose
2. the valve on the hose end
3. the check valve where you connect te hose to the machine
Also verify that you are dispensing solution to the floor, if so, then the above needs to be checked.
Have it looked at at repair shop for diagnosis
Oct 09, 2009 | Vacuums
I have a hoover spinscrub 800. It washes great
in some cases when this happenes it's usually from a really bad filter or the squeege at the bottom of the nozzle. the squeege is what makes contact with the floor and suctions all of the water up. to take off. take off the nozzle and there will be (3) screws inside of the nozzle. once these screw are removed, the squeege can be removed. at hoover.com the replacement part # is 93001094. ( according to model # H3060 )
Jul 31, 2009 | Hoover H3060 FloorMate SpinScrub 800...
Windtunnel quits picking up
clean or replace the main filter. this filter is non washable. the best way to clean is to use a paint brush or compressed air. hope this helps
Jul 25, 2009 | Hoover U8147-900 WindTunnel V2 Bagless...
Hose that releases the water and cleaner on my Hoover is clogged
Your right the hose is clogged.. Use a portable vacuum to blow the dirt inside the hose.
Jul 24, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Brush spin,good suction at hose, no suction at
Jul 11, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
No suction
Check again for obstructions in the hose. Also underneath where the debri goes when it is being sucked up. Also make sure all your hoses are connected as this could effect the suction.
Nov 29, 2008 | Hoover U6630-900 WindTunnel Bagless...
Hoover Company Wind Tunnel U53019 Upright Vacuum Logo
1,225 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
