Question about Sony Computers & Internet
My quick web button won't launch. I'm on ADSL+ and am putting in my network password, but it won't connect? The password appears to have to be 5 characters long, is there another password it is referring to?
    Champion:
  • 200 Answers
Try admin or nimda
Posted on Jul 07, 2010
Linksys sd208 reset
The reset button is usually at the back of the router. If you are unable to locate it you can reset it using a web based set-up page. Make sure you connect your router to a PC using wired connection and perform the following steps:
Step 1:
Launch a web browser like Internet Explorer.
Step 2:
In the Address bar, enter "192.168.1.1" as the router's default IP address then press [Enter]. If this doesn't work or if the IP address of your router has been changed, enter it instead.
Step 3:
Enter "admin" in the Password field then leave the User name blank. If you have set up a User name and Password for your Linksys router before, enter your personalized credentials instead.
QUICK TIP: For Linksys Smart Wi-Fi Routers, you can enter "http://myrouter.local" on the Address bar to access its web-based setup page.
The router's web-based setup page should now appear from here you can reset the router.
for more info browse this link: http://kb.linksys.com/Linksys/ukp.aspx?pid=80&vw=1&articleid=3676
Sep 19, 2013 | Computers & Internet
How do i change my nat to open
1 Make sure your ZyXEL Device hardware is properly connected (refer to the Quick StartGuide).
2 Prepare your computer/computer network to connect to the ZyXEL Device (refer to theQuick Start Guide).
3 Launch your web browser.
4 Type "192.168.1.1" as the URL.
5 A window displays
6 For administrator access enter the default admin password 1234 to configure the wizardsand the advanced features.(or if you already changed your password, enter that password)
7 On the right hand side of the screen you will see a drop down menu. click onNETWORK.
8 Then click on NAT.
You should be able to adjust your NAT settings from this page.
Sep 25, 2011 | Zyxel P660HW-D1 Router
How to change NAT status to open?
5 A window displays
7 On the right hand side of the screen you will see a drop down menu. click on NETWORK.
Sep 04, 2011 | Zyxel P660HW-D1 Router
I need to change the modulation type on my modem to select g.dmt to make my internet connection more stable HELPPPPP!! i have NO clue how to do it. it's an ADSL 2+router DSL 504T.i am computer...
To configure the modem You will need to use the cd provided.
ftp://files.dlink.com.au/products/DSL-504T-GenII/QuickInstallGuide/DSL-504T_C3_QIG_v2.00.pdf
Or to configure without the cd follow the steps below:
  1. Connect the Adsl router with your computer.
  2. Use the network cable provided with the router.
  3. Connect the power cable to the modem, it will light on firmly with a green button on.
  4. Open your web browser and type the ip address: http://10.1.1.1
  5. Default username and password is:
  6. User-name: admin
  7. Password: admin
  8. Use the quick setup wizard.
  9. It will be more easy for you to configure it.
  10. Be sure to have the username and password from the ISP for the internet access, you may need to reconfigure it from start. or if you may need to reset the modem
  11. At times to access your modem you will need to set the ip of your network card to the same range.
  12. To set the ip go in control panel then open network connection
  13. Doulbe click the local area connection.
  14. open Internet Protocol Open Tcp/ip
  15. then set your ip Like: 10.1.1.5
  16. ok
  17. ftp://files.dlink.com.au/Products/DSL-504T-GenII_NZ/Manuals/
I am enclosing a manual for you.
If you Need further help do not hesitate to revert back
Ok cheers
Uttam
Feb 13, 2010 | Computers & Internet
How do you manually connect a computer to the router? Trying different cables in port 1 but does not register to the computer. Please help!
You need to connect a standard network patch cable between port 1 and the ethernat port on your computer. To access the Web-based Utility, launch Internet Explorer, and enter the Router’s default IP address, 192.168.1.1, in the Address field. Then press Enter. This should bring up the router confiuration web page.
The password request page should appear. Leave the User Name field blank. The first time you open the Web-based Utility, use the default password admin.(You can set a new password from the Administration tab’s Management screen.) Then click the OK button.
Nov 08, 2009 | Linksys Wireless-G WRT54G Router
No activity on my new speedstream 4200
Ethernet and DSL lights are indicating you have ADSL available on your line, and that you have computers connected to the router.
What has probably happened is that Optus did not set up the new router with your username and password. Go to thw following website for details on how to setup the modem.
http://help.optuszoo.com.au/help/dsl/connected/windows/optus_modems/speedstream_4200
Manual Modem Settings The Optus DSL Broadband self-installation CD configures all the necessary settings for your DSL Broadband service. You do not need to manually configure your modem if you have run the self-installation CD. While the following information is provided for your reference, using the self-installation CD is the recommended method for configuring your modem.
The Siemens SpeedStream 4200 ADSL modem can use either USB or Ethernet to connect to your computer.
  • If you are connecting via USB you will need to run the self-installation CD to install the USB driver before you connect your modem. The Siemens SpeedStream 4200 ADSL modem supplied by Optus has been customised for the Optus DSL Broadband service. Only the USB driver supplied on the self-installation CD will work with the Optus service. If you do not have the self-installation CD, you can download the latest drivers from the Siemens website.
  • If you are connecting via Ethernet it is possible to manually configure your modem without the self-installation CD. Only a web browser is required.
After connecting your modem there are two key steps to manually configure your modem for the Optus DSL Broadband service:
  • PC settings - Configure your computer's Ethernet network interface.
  • Configure Your Modem - Set the password in your modem's configuration pages.
top
PC Settings Step by step instructions are provided for each of the supported Windows operating systems:
  • Windows 98/Me
  • Windows 2000
  • Windows XP
  • Windows Vista
top
Configure Your Modem To configure your modem settings you must now access the configuration manager using your web browser. This is done by entering the IP address in the address bar of the browser window as follows:
Note: If you are updating the password in your modem, please complete steps 1 to 3 only.
Step 1 of 5
  • Enter http://10.1.1.1 (Default IP address of the Optus Supplied Siemens SpeedStream 4200) to access the modem Configuration software. You may wish to add this page to your Favorites for easy access later.
  • The following modem System Summary screen will appear.
ss4200_home_disconnected.gif Step 2 of 5
  • Click on the word Setup in the green menu of options on the left side of the web page. An expanded set of options will be displayed.
  • Click PPP in the list of options that appeared below the word Setup.
  • The ISP Password page will appear:
  • Replace the default username (john_citizen@optusnet.com.au) with the username provided for you by Optus DSL Broadband.
  • Replace the default password with the password provided by Optus DSL Broadband in the Password field.
  • Note: You will find your Optus DSL Broadband username and password on the letter you received with your self-installation kit.
  • Save these details by clicking the Save Settings button.
Step 3 of 5
  • The next screen will ask you to disconnect and reconnect to the Optus DSL Broadband service.
  • Click the link to return to the System Summary page.
  • Click the Disconnect button to disconnect the modem from the Optus DSL Broadband service. The text on the button will change to Connect.
  • Click Connect to reconnect the modem to the Optus DSL Broadband service.
Step 4 of 5
  • Click the word Mode in the green menu of options on the left side of the web page.
  • Confirm that Optus Bridge is the selected operation mode.
  • If Optus Bridge is not selected click the radio button next to Optus Bridge to select it.
  • Click the Apply button.
  • Click the Reboot button to restart the modem using your saved settings.
  • After about a minute the modem will return to an operational state and connect to the Optus DSL Broadband service.
ss4200_reboot_3.gif Once the modem has rebooted and the ADSL connection has been successfully established the DSL LED indicator will light steady green.
Your modem is now connected to the Optus DSL Broadband service.
Jul 25, 2009 | Siemens SpeedStream 4200 (13A4200001)...
WiFi Password error Msg 5 or 13 ascii characters or 10 or 26 hd
hi there,
go to the router settings page on one of the computers connected to the network.
open the web browser.
go to http://192.168.1.1
username and password is: admin
then on the tabs you should see secruity and your password will be in there.
just remember when you connect you need to maybe press a button on the router to put it in pairing mode.
hope this helps
Apr 06, 2009 | Toshiba Satellite A75-S209 Notebook
Zoom router
Have you tried configuring the ADSL modem router for the internet connection?
Its possible that since you have changed the ADSL modem router, you may have to configure the ADSL modem router for it to work fine. The configuration depends on what Internet provider you have but you may try these steps for now:
1. Make sure the connections are correct. Connect the computer to the LAN port and the ADSL line to the port assigned for that behind the device.
2. Launch an Internet browser and access http://10.0.0.2 and press enter. If a dialog box appears, set the user name as admin and password as zoomadsl and press enter.
3. On the basic setup page of the ADSL router, set the appropriate encapsulation and other settings based on the settings of your provider. If you do not know the settings for your provider, there is a table specified on the user guide for the ADSL router. Here is the link: http://zoom.com/documentation/adsl/5590_UserGuide_EngD.pdf
Jul 19, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Secure wireless internet
The D-Link is configured using a Web browser. After you have connected your computer to the D-Link router, follow these steps: 1. Launch your Web browser. Enter "http://192.168.0.1" into the address bar and press the "Enter" or "Return" key.
2. A logon pop-up screen will appear. Type "admin" for the username and leave the password field blank.
3. Click "OK". A D-Link configuration screen will appear. All changes to the D-Link configuration are made here.
Enabling WEP* (Wired Equivalent Privacy) will require anyone wishing to access the Internet through your wireless network to enter a password. After the correct password is entered, a connection is established, and all data sent from the D-Link to the computer and back is encrypted. From the D-Link configuration screen:
1. Click the "Home" tab.
2. Click the "Wireless" button.
3. Click the "Open System" button next to "Authentication".
4. Set the "WEP Encryption" to "128 bit".
5. Set the "Key Type" to "ASCII".
6. Type a 13 digit password into "Key 1".
7. Click "Apply".
8. When you connect to your wireless network from a computer, you will need to enter the 13 digit password.
*Note: If your computer's operating system supports it, enabling WPA-PSK is more secure than WEP. The steps above can be modified to set up WPA-PSK.
May 10, 2008 | D-Link AirPlus DI-524 Wireless Router
Wireless security
Hello sir,
GETTING STARTED How to Physically Connect the D-Link
1. Plug an Ethernet cable into the DSL modem. Plug the other end of the cable into the "WAN" port on the D-Link.
2. Using an Ethernet cable, plug any wired computers into any of the 4 Ethernet ports on the D-Link.
How to Access the D-Link Configuration Screen
GENERAL SECURITY MEASURES
Change the Admin password
Leaving the password blank is not a good idea. It should be changed to something more secure. To change the password, go to the D-Link configuration screen and:
1. Click the "Tools" tab.
2. Click the "Admin" button.
3. Under the "Administrator" heading, enter the new password, and a second time to confirm.
4. Click "Apply".
5. The next time you access the D-Link configuration screen, you will need to enter the new Admin password.
Disable the Wireless LAN
If wireless access is not necessary, you should disable the wireless part of the D-Link. This will prevent anyone from accessing the network wirelessly. (If you are using the wireless features, please skip down to "Wireless Security Measures".) From the D-Link configuration screen:
3. Click the "Disabled" button next to "Wireless Radio".
4. Click "Apply".
5. You are done securing your wired network. No further action is required.
WIRELESS SECURITY MEASURES
Enable WEP
7. Click "Apply".
Change the SSID
By default, the D-Link is set to advertise the existence of your wireless network to computers. It does this by broadcasting an SSID (Service Set Identifier), also called a "network name" because it identifies your wireless network. Changing the SSID makes it easier for you to distinguish your network from surrounding networks. From the D-Link configuration screen:
3. Change the "SSID" from "default" to an SSID of your choice.
4. Click "Apply".
Please don't forget to comment this
Good luck
Cheers!!!!!!!!!!
Oct 26, 2007 | D-Link Securicam Network DCS-950G Wireless...
Computers & Internet Logo
85 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
