Question about Maytag MAT12PD Top Load Washer
Spin cycle not starting
The washer fills up with water but fails to proceed to spin cycle. The barrel seems to be loose as well.
    Genius:
  • 1,075 Answers
Sounds like the main bearing is broke needs replaced.adrian,,,,
Posted on Jul 07, 2010
My washing machine stopped working in mid-cycle. No agitation is going on and I could not drain it but putting to spin.
Make sure the washer fills with cold water from the beginning of the cycle because most washers have a cold only rinse cycle and if your cold water valve is bad then the machine will stop mid cycle because it cannot fill the washer for the rinse cycle. Secondly, it helps to know which washer you have so please enter more info next time you ask a question. Good luck.
Jun 28, 2015 | Whirlpool Washing Machines
Spin cycle does not remove excess water (worked great till recently)
EITHER A LOOSE WORN OR BROKEN BELT, A LOOSE SLIPPING CLUTCH A BAD DOOR SWITCH
Apr 09, 2014 | Frigidaire GLTF2940ES Front Load Washer
The washer fills agitate but won't spin & drain
Possible fault with the program controller unit. You need to check the program cycle outputs using a multimeter connected to measure the output voltage. On start the inlet should open and then close as the water level sensors works and then proceed to wash. So this much seems OK. Now in the next step the drain valve must open to drain off, then fill once again with the inlet working and water level being sensed. If there is no output in this section cycle then the prrogram controller has errors within the memory . You can remove the panel and reset all connectors and connections.
Oct 30, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
I put a load of wash in the washer filled with
im guessing this is a performa? if so you may have something cought in your pump. remove the obstruction and check to make sure the pump is free, then replace the belt. the belt should seem a little loose as it needs to slip to get the machine up to speed in the spin
Feb 07, 2010 | Washing Machines
Washer filles with water but wont change cycles
start filling the washer on the warm cycle,turn washer off,if the water keeps filling then you have a bad water inlet valve,if it turns off then you have a loose water level hose or the water level switch is bad-mike
Jul 21, 2009 | Kenmore 22422 Top Load Washer
White flakes in circular pattern under washer of 7 years. Time to replace?
First we started hearing a grinding sound during the spin cycle. My husband replaced the belt, which was loose and not helping the spinning of the tub any, thus much wetter clothing after spin cycle. The belt gave us another week of use out of the machine and did drain the tub better, but then water started leaking into the tub from the water inlet (or area where water rushes in to fill tub), and was not up to the usual "rush" of water, when filling up. The grinding sound started again during the spin cycle, and so now we are assuming it is the ball bearings or the brakes and perhaps the water pump as well. Estimates for these jobs on the boards seems to run from $400-500.00. The machine is only 7 years old, but after reading so many posts, maybe I should count my blessings that it lasted that long! This was an all mechanical machine, which I loved. Atlantis Maytag, a very sturdy and solid looking machine. Never did really clean that well though. SOLUTION: we are getting a new machine.
Jun 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
GE Profile washer won't spin cloths after wash or rinse cycle
My GE washer model number WLSR2000G3WW washes and pumps water out but will not spin...can someone help me to solve my problem PLEASE?
Jan 23, 2009 | GE WBSR3140DW Top Load Washer
Indesit Washing Machine not proceedding with the cycle programme after filling with water.
Cant understand how the machine will revolve on the 'spin cycle' & yet you can hear the motor on the 'wash cycle' but yet it doesnt revolve!!
Nomally if the water fills, & the tub revolves without the programmer advancing, its because the heater is not working. ie faulty thermostat, heat element, or maybe a wire burned off in the 'heater circuit'. Check if you have 240 volts at both ends of the heat element, with a meter or 240 volt bulb
                         !! BE CAREFUL OF 240VOLTS!!
Oct 29, 2007 | Indesit W 123 Front Load Washer
Maytag MAT12PD Top Load Washer Logo
70 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
