Question about Roper REX4634KQ Electric Dryer
Wont turn on checked outlet and breaker - Roper REX4634KQ Electric Dryer
  • 273 Answers
Check the door switch with an ohmmeter AFTER removing power from the dryer. The switch should read zero ohms when the plunger is pressed into the switch.
Posted on Jul 07, 2010
Oven wont start
Owners manual? troubleshooting section? Check outlet to be sure it has power. No power? Check the circuit breaker for that outlet if its special or higher amperage. Reset breaker, it pops again, you have a serious problem either in the oven or the wiring to the outlet serving the oven. No manual? Try manualslib.com Possibly switch is bad inside oven.
Apr 02, 2015 | Blodgett Mt 1820e Countertop Conveyor...
My oven won't turn all the lights are on
If you started to say that the electric oven wont heat, but the lights are on, I"d like to start by asking if youve checked the outlet to make sure it was getting 220 v. If its getting only 110v, it would explain why the lights come on.. lights work off of 110v, but heating element requires 220.. if only 110v is showing on volt meter, id be checkin your breaker, look for half of a double pull breaker to be tripped...turn off, then on both of them..same thing if its a single pull 220 breaker.
If youve got 220v at the outlet, I"d personally touch the element to see if it gets warm at all the instant someone turns the oven on. See if it has any heat at all.
Check the element termilals for corrosion...check element for brittleness or curling...check for 220 v at the element terminals...if nothing..it suggests the dial or thermostat
Sep 09, 2014 | Kitchen Ranges
MY JETS WONT TURN ON
The threaded knob should not be related to the problem, it just controls how much air gets mixed into the water jets. One possibility is that the electricity is off. These tubs should receive power through a Ground Fault Circuit Interrupter (GFCI) type of circuit breaker for your protection from electrical shock. Check your circuit breaker panel(s) for a breaker with a little square white or yellow "test" button. Refer to the label (if it is there) to see if it refers to "tub" or "spa" or "bath" or something like that. You may have to turn the breaker handle off (push extra hard to make it reset) and then back on again. If the breaker handle is in the "on" position and the "test" button does not "trip it off," call an electrician. If no luck there, check the bathroom for an electrical outlet with GFCI protection, again looking for white or yellow (or red) buttons - one should be engraved "test" and the other "reset" as the electrician (I hope it was an electrician) may have supplied the tub from this outlet (not actually up to code). Plug an appliance or light into the outlet. If it doesn't work, push the reset button on the outlet and test again. If working, now test the spa. If that doesn't work, test every other GFCI outlet you can find - in the kitchen, other baths, garage, outdoors, basement, etc. using the same testing procedure. If you find a GFCI breaker or outlet "tripped" that restores the tub, that indicates there is something wrong with your electrical system that could cause you to get electrocuted, and requires that you hire a qualified electrician to investigate the problem. The same is true for any GFCI outlet that does not "trip" and/or "reset." If this doesn't fix the tub, the problem may not be electrical but some other problem with the system, indicating a plumber or spa tech may need to be consulted. Note: these GFCI breakers and outlets are supposed to be tested and reset once every month. How many of us do that? Well, at least as often as we test our smoke detectors, I suppose.
May 20, 2013 | Home
Start button wont respond.Ultra wash s/n 15801805808
Check to see if the electrical breaker is working for that circuit. Next check the outlet that the machine is plugged into (115Vac). If all is, so far, copescetic, Turn off the breaker and pull the control panel. Test the "button" with a multimeter. If it is solid state, turn the breaker back on and CAREFULLY test to see if there is voltage coming into the panel. If not, look for a blown fuse. If no blown fuse and voltage is there, replace control board! Good luck!
Dec 27, 2012 | Dishwashers
The power wont come on we've cheked the power point and it's fine. Just the walker wont start no lights no sounds
Dear Sir:
Thank you by your question, here some answer:
PROBLEM: The power does not turn on SOLUTION: a. Make sure that the power cord is plugged into a surge suppressor, and that the surge suppressor is plugged into a properly grounded outlet . Use only a single-outlet surge suppressor that meets all of the specifications . Important: The treadmill is not compatible with GFCI-equipped outlets. b. After the power cord has been plugged in, make sure that the key is inserted into the console. c. Check the reset/off circuit breaker located on the treadmill frame near the power cord. If the switch protrudes as shown, the circuit breaker has tripped. To reset the circuit breaker, wait for five minutes.and then press the switch back in. d) Please check the power cord maybe is broker Testign with DVOM(Digital Voltimeter). e) Test the circuit breaker of the House, and Reset, see in outlet box if some wiring is loose.
Thank you in advance, sincerely. Blessing.
If you need additional Help, please contact me.
E.CUADRA Managua, Nicaragua.
Sep 25, 2011 | Proform CrossTrainer Treadmill
Frigidaire fghd2433kf dishwasher. less than a year old. flashed PF. the power hasnt been off. now whole unit is dead. no lights or movement.
Hello bidness_67 please check inside of the sink cabinet look for a switch on the back wall. If there is one flip it. Many new building electrical codes require a switchto turn off power to the dishwasher. Sometimes when putting items in the cabinet the switch is hit unknowingly. If there is no switch check outlets (the GFCI ones)and press the reset then check the dishwasher.if not those two items check breaker box for a tripped breaker.
Aug 15, 2011 | Frigidaire FGHD2433KF Builtin Dishwasher
I havn't used my dish washer in over a year and it wont turn on. Why?
check to make sure you have power to the outlet, it should be located under the sink,, if you do not have power at the outlet then check the breaker in the breaker box.
c...
Jan 02, 2011 | GE Nautilus 24" Built-in Dishwasher
Wont turn on
if it's a 110 volt AC - you could try plugging another electrical device, i.e. hair dryer into the outlet to see if the outlet is working or not.
good luck!
Apr 24, 2010 | GE AGQ10AJ Wall/Window Air Conditioner
If your dryer was working and then just wont turn on after that, what could it be?
If it is an electrically heated dryer, check the dryer breaker pair in the house electrical panel--push off, then on. If the breakers hold, try the dryer again--if works, ok! If the breakers trip again, then the heater element in the dryer is likely shorted to ground. To service the elements, the drum must be removed.
If this is a gas fired dryer, check the electrical outlet with a working lamp. If nothing, check the breaker for this circuit.
Aug 28, 2009 | Dryers
My dryer wont come on at all
see if the electrical outlet is working.plug something else into the outlet,if it is dead, check to see if the
circuit breaker tripped.if it is working, then you need to call a repairman.
wg
Feb 15, 2008 | GE Profile Harmony DPGT750EC Electric...
Roper REX4634KQ Electric Dryer Logo
118 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
