Question about Kenmore HE2 Plus Front Load Washer
What is F35 means?
The Message F35 shows after we load the clothes and the door is locked.
  • bonscho Jul 07, 2010
    Thank you very much Techbuster!!
    I will check it out tonight. Is that something I can be able to fix since I am not very good at fixing machinary..... How much you think it will cost to call for a technican to fix?
  • 5,081 Answers
The F35 indicates that the main control board detects a problem with the analog pressure sensor (water level pressure switch) in the washer. This component senses and controls water level in the washer. This failure could be caused by a pinched or broken air hose between the air trap at the bottom of the washer tub and the analog pressure sensor. It can also be caused by a clogged air trap or a failed analog pressure sensor. If you are able to unplug the washer and pull off the top panel, you can check for the probable cause of this failure.
To remove the top panel, remove the screws on the very back of the panel that secure it to the washer cabinet. Pull the top panel back slightly and then and off of the washer. It is on the side wall just behind the expansion control board. You can check the air pressure hose connection and the wire harness connection on this component.
This component costs around $99.This information was based on the general description of the washer model that you provided (Kenmore Elite front load washer). There are several different models of this washer.
The following link explains the error in more detail and how to correct:
http://www.fixya.com/support/r3608687-sud_error
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code can be generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
COURTESY:jsrock - A senior expert of fixya.....
Posted on Jul 07, 2010
  • INDIRA KUMAR
    INDIRA KUMAR Jul 07, 2010
    You can see the procedure in the link i have given and about the cost i am from a different country and i dont know thw exact cost in your country.
    Champion:
  • 274 Answers
Try running machine without load,bleach out machine you might be able to free what ever is causing the problem.
Posted on Jul 08, 2010
We have LG top load waveforce washer showing error code dL. At start there is a few seconds noise then error code appears. The washing cycle does not start. What is the problem and how do I fix it.
most likely a Door Lock error. means that the door lock is not working. fairly easy replacement if necessary. might check the lock first to make sure it has connector plugged into it. and that nothing is jammed inside of it. good repair videos at repairclinic.com and appliancepartspros.com or online at youtube.com
Oct 30, 2016 | LG Washing Machines
Washer is vibrating badly. it shows a cod f35
The F35 indicates a water level pressure sensor failure. The SUD is normally displayed when there is excessive detergent suds in the tub. Make sure you are only using the recommended amount of HE detergent. Then run the washer without clothes on a drain and spin cycle.
Jan 10, 2011 | Kenmore Front Load Washer
F35 message, will not run through cycle. Starts to and then the F35 starts flashing and eventually shuts off.
Check between door boot seal and drain hose in basket. If this is clogged with lint or sock, towel it will code f35 or sud
Oct 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The F35 signal is still showing on our washing machine. We checked the drain from the machine to the wall. It is clear. We took out all the clothes and ran the water seemed to be ok and then the Sud...
To cure the F35 with the occasional SUD fault showing in the display the problem means that you need to unplug the machine from the mains and turn off the water supply. Then remove the lower cover, looking at it from the front where the glass door is, so you can see the water pump. On the water pump there is a round cover, turn it counter clockwise to get it loose, then the the filter will come out. You may find some interesting things in there! Clean it and screw it back on. Make sure the machine is powered off at the mains for 30 minutes in total to reset the computer and clear the fault display. Reconnect the mains power and turn the water supply back on. The machine should now operate correctly.
Oct 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washer is giving me a F35 on the screen and not working. I can hear her trying to start but after a while the F 35 shows up and I have to unplug her in order for the lock to release and the machine to...
Washing clothes all day have an F35 flashing
F35
ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer
component detected by the Steamer Electronic Board.
Possible Causes/Procedure
1. Check if pressure hose is fixed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked.
Check these problems.
Plesae leave a solved rating before you leave the site
Jan 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GE Energy Star WBVH5200 Front Load Washer
My GE Energy Star Front Load Washer is reading 5.9 instead of 59 minutes and not washing clothes. We cleaned the filter and still no luck. Please help.
Jul 30, 2008 | GE Energy Star WCVH6260F Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
139 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
