Question about Gateway NV5215u Notebook
Reset Bios Password
I had to replace the hard drive for Gateway NV52 but I dont know the Password for the bios and well i tried the battery removal and no luck. So what can i do to reset the bios password?
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 59 Answers
At command prompt type debug
you will get a - prompt where you can type the fallowing (<enter> means hit enter, not type enter*)
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
<ENTER> just hit enter on this line
G <ENTER>
Q <ENTER>
Basic BIOS password crack - works 9.9 times out of ten
This is a password hack but it clears the BIOS such that the next time you start the PC, the CMOS does not ask for any password. Now if you are able to bring the DOS prompt up, then you will be able to change the BIOS setting to the default. To clear the CMOS do the following:
Get DOS prompt and type:
DEBUG hit enter
-o 70 2e hit enter
-o 71 ff hit enter
-q hit enter
exit hit enter
Restart the computer. It works on most versions of the AWARD BIOS.
Flashing BIOS via software
If you have access to the computer when it's turned on, you could try one of those programs that remove the password from the BIOS, by invalidating its memory.
However, it might happen you don't have one of those programs when you have access to the computer, so you'd better learn how to do manually what they do. You can reset the BIOS to its default values using the MS-DOS tool DEBUG (type DEBUG at the command prompt. You'd better do it in pure MS-DOS mode, not from a MS-DOS shell window in Windows). Once you are in the debug environment enter the following commands:
AMI/AWARD BIOS
O 70 17
O 71 17
Q
PHOENIX BIOS
O 70 FF
O 71 17
Q
GENERIC
Invalidates CMOS RAM.
Should work on all AT motherboards
(XT motherboards don't have CMOS)
O 70 2E
O 71 FF
Q
Note that the first letter is a "O" not the number "0". The numbers which follow are two bytes in hex format.
Using the jumpers
The canonical way to flash the BIOS via hardware is to plug, unplug, or switch a jumper on the motherboard (for "switching a jumper" I mean that you find a jumper that joins the central pin and a side pin of a group of three pins, you should then unplug the jumper and then plug it to the central pin and to the pin on the opposite side, so if the jumper is normally on position 1-2, you have to put it on position 2-3, or vice versa). This jumper is not always located near to the BIOS, but could be anywhere on the motherboard.
To find the correct jumper you should read the motherboard's manual.
Once you've located the correct jumper, switch it (or plug or unplug it, depending from what the manual says) while the computer is turned OFF. Wait a couple of seconds then put the jumper back to its original position. In some motherboards it may happen that the computer will automatically turn itself on, after flashing the BIOS. In this case, turn it off, and put the jumper back to its original position, then turn it on again. Other motherboards require you turn the computer on for a few seconds to flash the BIOS.
If you don't have the motherboard's manual, you'll have to "brute force" it... trying out all the jumpers. In this case, try first the isolated ones (not in a group), the ones near to the BIOS, and the ones you can switch (as I explained before). If all them fail, try all the others. However, you must modify the status of only one jumper per attempt, otherwise you could damage the motherboard (since you don't know what the jumper you modified is actually meant for). If the password request screen still appear, try another one.
If after flashing the BIOS, the computer won't boot when you turn it on, turn it off, and wait some seconds before to retry.
Posted on Jul 07, 2010
Can't install new hard drive because of a bios password. How do I remove it?
Remove CMOS battery; after some time BIOS should reset to fabric conditon, without password
May 13, 2015 | Dell Inspiron 15 (N5050)
Why does my laptop alway boot up with a bios password, i tried removing it but no means, how do i remove it?
If the password is in the BIOS, then most likely disconnecting the CMOS battery for a while (notebook turned off, of course) will reset it, along with any other BIOS setting. If it is a password on your hard disk (ATA password) then you need to know it to remove it, or you're basically left with replacing your hard drive.
Sep 09, 2014 | Computers & Internet
How do i reset the bios password for my lenovo a310?
User passwords:
Power on
BIOS execution can be controlled by a Power On Password. This password is set in the BIOS Configuration screen, accessed by pressing the F1 key after pressing the power on switch to turn on the PC. If the person at the keyboard does not know the Power On Password, then BIOS execution halts.
Hard drive
The hard drive is controlled by the Hard Drive Password. After the Power On Password is entered, the person at the keyboard must be able to enter the Hard Drive Password, otherwise the disk drive will not spin up for use. Like the Power On Password, the Hard Drive Password is set in the BIOS configuration screen.
Administrative passwords:
Each of the two user passwords can be controlled by a Master or administrative password. If the administrative password is not set, then anyone who knows the user password can change it in the BIOS configuration screen. If the administration password is set, then it is impossible to reset the user password unless you know the administrative password. The Supervisor Password is the administrative password for the Power On Password. The Master Hard Drive Password controls the Hard Drive Password.
Password Recovery is a feature of Client Security Solution 6.0. This makes it possible for an end user to recover from the problem of "I forgot my Power On Password or Hard Drive Password."
c.gif fw.gif Client Security Solution
Mar 13, 2011 | Lenovo IdeaCentre A310 Laptop
Lost Bios Password for Gateway Solo 1450. I have removed the CMOS battery for 5 min; that didn't work. Removed it again for an hour and that didn't work! I have tried all the back door pwds for the Phoenix...
From my experience there is no way to retrieve or remove a unknown hard drive (HDD) password. The bios passwords and windows passwords are no problem to remove, but the HDD password cannot be removed. Only option I know is to replace the hard drive. I have done this on about a dozen PC's
Dec 06, 2009 | Gateway Solo 1450 Notebook
On my gateway laptop, I have an all black screen with a blue 4 inch box that prompts me for my HDD password. I don't have that password at all.
Hard drive passwords cannot be broken or gotten past. There are no special tricks unfortunately....most people that have an unknown hard drive password are forced to get a new drive and start over. If you know what the old BIOS password was, sometimes when people make a bios password they make the hard drive password the same. BIOS passwords and user account passwords can be reset......hard drives cannot. If you need the files from the hard drive....you might be able to access the files by removing the drive and using an IDE / SATA to USB adapter and connecting to a different computer.
Nov 11, 2009 | Gateway 450ROG Notebook
Gateway Laptop - HDD Password locks me out! Help
if the hard drive has a locked password on it, you cannot remove it unless you have the password. you might try using some SMART disk utilities, but in my experience, it has no worked. Some hard drives have a list of reset passwords, but I have never had success in getting these to work.
try downloading Hiren's boot cd. (gogle search it) it has many utilities for hard drives on it. iyt may have something to help.
alternatively, buy a broken identical model on ebay and swap the PC board. make sure to have the same hardware revision level and model.
Sep 10, 2009 | Gateway MT6707 Notebook PC
Trying to find a way to reset or bypass the HDD1 user password on my Toshiba A135-4527 laptop. It was reset somehow to something we do not remember. Hoping I do not have to replace the harddrive. Saw...
The hard drive password is set from the BIOS configuration where the hard drive was installed and you need to know the password to remove the existing password. You can only remove the password from that computer's BIOS and moving the hard drive to another omputer will not allow you to remove the password or access any data on that hard drive because the password is stored in the hard drive's firmware. This password protected hard drives prevents unauthorized access to the data on that hard disk.
Removing the BIOS battery will reset the BIOS but will not remove the password.
Some computers have been setup with Power On Passwords and/or hard drive passords and it is possible to hack/read the Power On Password that is stored on an EEPROM chip on the laptop, but it is not a simple process.
You will need to buy a new hard drive and now you also have a nice paper weight.
Feb 19, 2009 | Toshiba Satellite A135-S4527 Notebook
Reset bios password
try to remove the cmos battery from the motherboard and insert again...it will reset ur bios password...
Jan 19, 2009 | Computers & Internet
Gateway MX6030 bios/boot password reset
How long did you leave the battery out?
To discharge the BIOS you need to short out the battery contacts, or disconnect the battery for 1/2+ hours.
If this does not work the it is near impossible to remove because the password would be stored on an EEPROM chip.
Check with Gateway, they might suggest a motherboard replacement just like IBM.
Jan 19, 2009 | Gateway MX6030 Notebook
Gateway NV5215u Notebook Logo
1,713 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
