FQ106D1 Main washsoap dispenser always has soap in
FQ106D1 Main washsoap dispenser always has soap in it.checked water pressure and inlet pipes.almost feels like the soap is not being used.
    Genius:
  • 1,075 Answers
Remove dispenser drawer and give it a good clean.adrian,,,,
Posted on Jul 07, 2010
Water not draining from my dispensers
Water pressure or blocked inlet valve.
Take out the soap drawers and have a look up at the inlet holes.
Mar 16, 2016 | Washing Machines
Soap dispenser is opening late. The soap tablet does not get used. It barely gets wet.
Check inlet water supply. Clean the strainer attached to the inlet hose pipe at the machine back side end. Straner is submrged inside the pipe on the machine . Pull it to clean. It is a small one with tiny holes or filter.
Try again! If water pump is not developing pressure also this could happen.
Sep 27, 2010 | GE Dishwashers
My new LG washer always has water in the soap dispenser, bleach dispenser, and fabric softener dispenser after the cycle has finished. Is this normal?
Mine too!! Very annoying, especially since the water then drains down onto to floor and has actually made the door hinges stiff! I just use powdered bleach now.
Aug 22, 2010 | LG Washing Machines
No high pressure water
I have a SIMONIZ S2000 electric. I bought the unit about 8 weeks ago used it once. On the second use yesterday the unit didn't work as well, the pressure seemed only a bit better than hose pressure and soap did not dispense at any pressure. SO.... after much thought I turned the hose/tap pressure down so that I only got about 2-3 GPM instead of the typical 5-6GPM normally coming out of my hose....... it worked! Soap dispenses and spay is way better! It seems that if if the inlet hose pressure is high the pump doesn't work as well... go figure.
Jul 01, 2010 | Karcher 1550PSI Pressure Washer
Soap dispenser doesn't always open and the tub doesn't always pump out the last rinse.
check the supply voltage going to soap dispenser and inlet solenoid valve, if no voltage replaced the timer
Jun 04, 2010 | Dishwashers
Soap is left in the dispenser and the top rack doesn't get clean.
the inlet water pressure need to check i think there is weak level of water , check 1st nearest tap to sea normall flow of water is good or not ?
> if it is weak so the problem outside the dishwasher it is plumbing problem
>if it is good so the problem relate to dishwasher so chech the whole path of inlet water> i think this will solve the problem
thanks
Jul 13, 2009 | Whirlpool GU2400XTPS Built-in Dishwasher
LG 2077 CW-has IE code issue as well as soap dispensing problems
IE is an inlet error indicating that the machine has not filled up to the correct water level within 10 minutes. Could be a bad inlet valve, low water pressure or a problem with the inlet hoses (do not use anti flood hoses with these machines, use only the included fill hoses).
It sounds like all of your problems lie with the water fill. If the dispenser compartments do not get water added to them then the soap, bleach, and/or softener will not dispense properly. Then it will still be present and may dispense on the next load instead.
It is also VERY important that you use an HE (high efficiency) detergent and the correct amount (2-3 tablespoons per load). Otherwise you could end up with oversudsing issues which can also keep the bleach from dispensing properly.
Also make sure to not use GEL bleach, GEL detergent or GEL softener as they are too heavy and will not dispense properly. If all of these recommendations do not help then there is a definite issue with the incoming water supply from the inlet valves (especially if the IE errors continue). In that case you will need a technician to check the inlet valves inside the machine.
Hope this helps, please rate my solution.
Jan 04, 2009 | LG WM-2077C Front Load Washer
Dishes not thourghly cleaned on top sheelve
generally dishwashers rely on the pressure supplied by the water supply line. check to see if it is enough or if inlet pipe is of sufficient diameter for needed flow.in some instances i know of seperate lines needing to be run directly instead of coming off of supply to sink area.
Apr 07, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Water in soap holder after washing.
my washer is about 1 year old. It started leaving water in all the the compartments,soap,bleach and softner. I tried everything also. Nothing seemed to work. I finally took the hoses off the back of the machine, and the cold water hose screen was clogged up going into the machine. I cleaned all the screens and haven't had that problem again. I think there wasn't enough water pressure to flush out the containers. I dont think its gravity or suction, its water pressure. unless you get a blast of water into these compartments, there will always be water left in these containers.
Oct 27, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
179 people viewed this question
Top Washing Machines Experts
