Question about Karcher 2500 PSI Pressure Washer
My 2500psi unit will only reach 1000psi when i pull the trigger
  • Ian Summerfield
    Ian Summerfield Jul 08, 2010
    is it at full throttle?if the jet is worn,which they do frequently,youll get more flow,less pressure.try new jet at end of lance.make sure lance is adjusted for max pressure,smallest jet of water
    Problem Solver:
  • 13 Answers
Suspect an unloader valve problem.
Posted on Jul 16, 2010
How to fix a seized engine on a HONDA XR2500, 2500psi,2.5 gal, 5.0HP?
for an engine to seize ,it indicates a problem of melted bearings, damaged crankshaft, valve stems jammed , rocker gear jammed
You can pull the motor down and price the repairs but the cost will be close to if not exceeding a new motor
however it may not be the engine as they are direct coupled to the pump so pull the engine from the pump and then make that decision as it could be a problem pump
Aug 11, 2015 | Honda Cars & Trucks
My hitachi miter saw started to buzz when plugged in. It's seems to work normal when trigger is pulled but starts to smoke when I release the trigger. Bushing poor good. I have no idea what is wrong?
have it investigated by an appliance repair shop
the system is this
plug in --no noise
pull trigger -- blade spins and makes running noise
release trigger and blade stops -- no noise
anything else indicates a serious problem with the unit especially if it is smoking.
May 20, 2015 | Saws
Why won't my Gamo big cat not **** when I fold barrel.
The three reasons that stop a springer cocking are
1 main spring has broken and stopping the piston reaching the trigger sear and engaging . remove spring to check
2 trigger is jammed and not allowing engagement of sear or trigger unit is broken (may be a spring broken easy fix )
3 piston engagement slot damaged broken ( replace piston)
If it is trigger wear problems think about getting it repaired or replaced depending on length of time owned
Apr 05, 2015 | Gamo Optics
How do I adj. the trigger pull on my wetherby .204 cal. rifel
If it came with an adjustable trigger easy to do take action out of stock and check trigger for adjuster screw should have +/- arrows and don't go below 16 oz pull
if not the rifle will have to go to a competent gunsmith or to a wetherby service centre to have the trigger faces honed
Or fit an aftermarket adjustable unit like timney
Feb 21, 2015 | Optics
No high pressure
These pumps are notorious for seasonal problems.
Tip the unit to the point you can pour engine oil into the water inlet connection. What your attempting to do is free up the ball seats in the pump. They get corroded when they sit and lock in place. Adding the oil or a vast amount of WD 40 to the water inlet often does the trick for loosening up the seat balls and springs.
After you add the oil (3 - 4 ounces) or WD 40 to the water inlet line just slowly pull the engine through with the ignition switch off. As the water inlet cavitates add more oil.
Let it sit over night and then take a block of wood and a hammer and tap on the power head. Don't over do it and do it in such a manner your not going to shear off any bolts or break anything. But... be serious with the hammer and block of wood.
Then connect inlet water hose, the pressure hose and test the unit. You may want to purge the oil lubricant into a bucket before you start the engine.
Give it a try and see what happens.
Thanks for using FixYa,
Kelly
May 04, 2010 | Karcher 2500 PSI Pressure Washer
New Troy-Bilt 3000 psi - Very Hard to Hot Start
When you run the unit and shut if off, release the pressure from the spray wand before trying to restart the engine. This built up pressure will cause it to be very hard to start as you have found out. If it does not start on the second pull release the pressure again. Another option is do do what I did on mine. I simply put a pull tie on the handle so I can pull the trigger back and use the pull tie to hold the trigger open. Make sure if you do this, that you remove the high pressure orifice from the end of the wand before attempting to start the engine. Otherwise the pressure will come on abruptly and could injure you or do property damage.
Apr 25, 2010 | Briggs & Stratton Prosumer 20324 Gas...
NO PRESSURE
check the coupling or the belt between the engine and pump. unsure which this washer uses. the pump may also have failed, usually it is the coupling or belt broken or slipping
Jul 09, 2009 | Briggs & Stratton Garden
Trigger not working correctly
You might need to de-scale the unit to free the stuck valve.
Keep the unit unplugged.
Fill the unit with a vingar and water (filtered or distilled is best).
Screw the cap back on and place the unit in a sink upside down to allow the vingar and water to reach the valve.
After a few minutes press down the trigger several time to work the solution into the valve.
Hope this helps.
Sep 15, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
Karcher 2500 PSI Pressure Washer Logo
109 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
