Question about Envision L32W761 32 in. LCD TV
I have vertical colored lines and cant read menu on my l32w761 envision lcd It seems to be shutting its self off also and the light blinks an orange color in place of the usual green
    President:
  • 1,099 Answers
On all the plasma tvs there are control boards on the lower part of the screen that control the vertical images. If one of the chips on one of the boards fail, have a bad connection, or no ground it will result in a thick black line down the screen.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Good luck and take care in handling it ........
Posted on Jul 07, 2010
I've lost the remote control for my AOC Envision L32W761. How can I change the menu and input source options using the front panel controls? I'm able to access the menu screen but can't figure out how to...
Try navigating the screen using the volume and channel controls. If you still can't get to the left side of the screen then try press the menu button again while on the menu screen to see if it'll navigate you there.
Hope this helps :)
Apr 20, 2014 | Envision L32W761 32 in. LCD TV
Our power light flashes orange when the power is on then after a while the tv automatically shuts off
The set is not making it from standby to on---power supply problem or something pulling down voltages from power supply---voltages would have to first be checked to see which is the case---maybe time to have a technician look at the set?
Nov 03, 2012 | Envision L32W761 32 in. LCD TV
I have a 32" AOC Envision L32w761 LCD hdtv with no
There are only two things that can cause this problem -inverter and T-con. Since you have already replaced the inverter, it can be nothing other than the T-CON or LCD controller. Replacing the same should resolve the problem. On a side note the inverter/T-Con problem can be isolated easily. The purpose of the inverter is only to light up the backlight of the panel. So when it fails you will still have a faint picture that can be seen if you flash a flashlight on the screen. If you would like me to find you the replacement T-con let me know the part number and I will get you the link to the part.
Sep 07, 2011 | Envision L32W761 32 in. LCD TV
No power but yellow light is blinking
call sears they only charge $99 to come out free estimate
Dec 19, 2010 | Envision L32W761 32 in. LCD TV
Screen Size on my Envision L32W761 TV is cutting off the picture.
Look on the remote for a button labelled ASPECT,P SIZE, ZOOM or FORMAT. Press it until picture is desired size.
Oct 04, 2009 | Envision L32W761 32 in. LCD TV
Can't get a connect from my emachine to aco l32w761
2 options:
1) Try changing your screen resolution to say 640x480 or 800x600 ..
2) Try it in safe mode also ..
Jan 21, 2009 | Envision L32W761 32 in. LCD TV
Envision remote codes
Try
10813
11365
10032
10039
10019
Feb 18, 2008 | iLO 3200 32 in. LCD Television
Envision L32W761 32 in. LCD TV Logo
363 people viewed this question
Top Envision Televison & Video Experts
matt martin
matt martin
bigdawg7299
Are you an Envision Televison and Video Expert? Answer questions, earn points and help others
