Question about Hayward SP3207EE TRISTAR PUMP .75 HP, 115/230V - SP3207EE
Was pumping good, water level got low and pulled air. Pump now has very low flow. Pump is a SP3207EE
  • 990 Answers
If it ran very long you could have overheated the plumbing and now you might be leaking air. If you can get it to run right by putting glue around the suction pipe at the pump while running this is your problem. If so you will need to replumb pump. Do the suction and the discharge as that will probally leak also.
Posted on Jul 07, 2010
Why has the circulation flow decreased
Your pump pushes "Unfiltered" water thru the Filter. Your filter then "Cleans / Filters" all of the microscopic particles of dirt out of the water. This will eventually clog your filter as the pressure will then obviously climb. Basically, doing the job it was intended to do! As this occurs the water flow will be reduced and at times, dramatically! The fix: clean the cartridges, backwash your sand or D.E. Filter.
Another possibility is the flow is restricted due to another type of clog: Plugged pump impeller, clogged & dirty skimmer or pump baskets, etc.
Or low water level. Sucking air with water.
Jun 10, 2014 | Hayward Pool & Spa
My intex 637r pump is not pulling the water through to the filter and letting it discharge back into pool could it be that the pump and hoses are sitting to high on the ground and not far enough under the...
Air release valve for air trapped inside filter chamber
Intex 1000 GPH Easy Set Pool Filter Pump Instructional Guide 637R
The link has a set-up video for the 637R pump. Make sure water flows out of the air valve on the top of the filter cover. This will purge air out of the filter and prime the pump. Hope this helps you....
May 13, 2014 | Intex Krystal Clear Model 635 Pool Filter...
Pool cleaner starts and then stops working
Check for water flow / water flow restrictions / and water flow blockages.
Many things create water flow reductions: Dirty filters, plugged impellers, packed with debris baskets - both skimmers and at pump, closed to partially closed valves, air suction leaks: worn shaft seal, worn orings at pump lid or pump volute body, low water level, stuck skimmer weir blade/gate in the up position & skimmer empties and air is sucked into the system which may cause the pump to lose prime. This a problem that goes un-noticed and is hard to detect even by some service technicians!
Jan 31, 2014 | Pool & Spa
Low flow message on balboa 500z system
The low flow message on any Balboa means that you are having an issue with the flow of water through your heating unit. This can be caused by a few things.
  • Low water levels
  • Dirty filters
  • Something is impeding your water flow
Top up your water level and make sure it is where it needs to be, clean your filters or replace them, and check that nothing is impeding your water flow at the skimmer or water intakes.
Here is a link to water flow issues.
F2 Error Code Trouble Shooting
Dec 24, 2013 | Intex 2500 Gal Easy Set Swimming Pool...
2000 vw beetle 2.0 L, low level coolant light...engine mil code 1256
not the pump but air in the system or a broken wire to the coolant level sensor
that sensor at the top of the radiator tank has to be completely immersed in coolant or the circuit is broken and the light comes on
same effect id the wire to that sensor is broken in the insulation
Jun 16, 2017 | Cars & Trucks
How do I remove air from pool filter lines?
with out seeing your set up not to easy,but lets try
1 your pump room is below surface of pool, make sure your pool level is high enough to return water to pump via the skimmer hole in side of pool at surface level. water should fil pump basket. check that you have a good seal on glass cover. no water in basket check if valve from pool is open still no water close valve fill filter chamber with a hose close glass cover start pump and open valve immediately.
2 pump room above pool level, close inlet valve fill pump filter with water close glass cover securely start pump and open valve.
a good drawing of you equipment and its position relative to pool how and ware u connect vacuuming hose
May 30, 2012 | Hayward Pool & Spa
Low water level in saniflo toilet
Is it always low? Could be a partial blockage in the out flow pipe, causing the pump to stay on, or a sticking/dirty pump switch.
Apr 19, 2012 | Saniflo & Saniplus& Macerator Pump
I returned from vacation and the water level was adequate b/c it had just rained a lot. I think the water may have gotten low when we were gone. Now there is not enough pressure in the pump and the...
Any air getting into the suction line of the system can cause a low flow. If too much trans is in the skimmer basket or pump basket you cna get a low flow. If junk is in the pump impeller or the filter the flow can be low. Check each of these possible problem and you will likely resolve it. I hope this helps.
Aug 12, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP 2 HP...
Car overheating no heat coming from vents just cold air
NO heat because there is no coolant flowing throught the heaster core. Car is overheat since there is no coolant circulating in engine water jacket.
Check the coolant, if it is low, then check the oil level. If oil level is high then the head gasket is blown so coolant gets into the engine therefore there is not enough coolant to cool the engine.
If the oil level is OK and coolant level is OK then Need to check 3 following things:
-Bad thermostat is not open causing coolant stagnant then engine overhet.
-Bad water pump is not pumping coolant so there is no coolant circulating to disipate the heat.
-Bad radiator blocks the coolant flow from top to bottom radiator.
Good luck.
Dec 15, 2009 | 1998 Oldsmobile Aurora
Chevy 1500 Heater problem
It sound's like a problem with the water pump, thermostat, or drive-belt, drive-belt tensioner and pulley, check the tension on the drive-belt, if it has good tension check and or replace the thermostat, if your still having cold air coming out at low rpm's it could be a bad water pump. you can check the water pump by looking to see if there's coolant leaking from the weap hole, or listen for a squealing noise from the water pump when the vehicle is running, there's also a possibility of air in your cooling system which usually occur's when you have the coolant system opened up for repair's, if there is air in the system it could keep the coolant from flowing properly, only way to get it out is to bleed it out using the bleeder valve, im assuming the coolant level is at the proper level,
I hope this was helpful. Good luck.
Apr 04, 2009 | 2000 GMC Jimmy
Hayward SP3207EE TRISTAR PUMP .75 HP, 115/230V - SP3207EE Logo
54 people viewed this question
Top Hayward Garden Experts
Dennis Key
Dennis Key
john h
Are you a Hayward Garden Expert? Answer questions, earn points and help others
