Question about Little Giant Submersible Fountain Pump
Fountain pump motor runs but no pressure to push water
I have a garden fountain with a little giant model PSM-006 pump. I hear the moto but it doesn't cycle the water through enough to get it to flow.
  • 990 Answers
You can try to force prime with a garden hose. Put the hose in ether side suction or discharge.
Posted on Jul 07, 2010
How to disassemble Little giant pump model#psm006?
thats why i like the little giant pumps they are put together with phillips screws not glued like them other guys , i do suggest that if you dissasemble pump and water has gotten inside , replace it not just seal it up and go , wont last long as that means the pump shaft seal has leaked , ther e has been a few folks that add dietary mineral oil to the inside , for use in very deep ponds (over 3 feet) they believe that helps keep the water out
Jun 11, 2014 | Little Giant Submersible Fountain Pump
Rival beverage fountain the moter pump not working for
if this is the type with the open frame motor (meaning its got no round cover) then i suggest you soak the pump (not the motor ) in hot/warm water for a bit , sugar from drinks mix has dried up inside pump not alowing pump to turn , hot water will soften sugar and allow motor to turn
Oct 30, 2013 | Little Giant Garden
How do I take apart model PES-80-PW
nothing to take apart on this one it's a mag drive pump , if somehow the housing requires cleaning , backflushing down the outlet pipe is about the only way to do it , unit is sealed otherwise
mag drive means that a magnet is used to couple pump to motor so a direct connection is not needed so no drive shaft seals to fail , mag drives should never never be run dry with low to no water in pond , they use the water for cooling and will fail beyond repair if allowed to melt
Mar 31, 2013 | Little Giant Submersible Fountain Pump
Waterfall pump hums but won't pump
this sure sounds if the impeller is blocked and not being able to turn ,Dont let it run this way , can dammage motor of pump , remove intake cover (unplugged) and wash out with garden hose real well , see if impeller (black plastic blade) can turn with your finger (unplugged) , should move easy ! this might be an indacation of need for a filter on pump inlet !!!
Oct 14, 2012 | Little Giant Submersible Fountain Pump
Water pressure too much with PEM 070
a device called a flow restrictor is needed in this case , pond supply places can source this device as it needs be sized for the size of hose your using
May 10, 2012 | Little Giant Garden
Have a little giant 4-mdqx-sc that I bought used I plugged it up dry just to make sure it runs and it is making a horrible noise from the impellier not the motor will this go away when it is in line with...
yes it should go away, this is a magnetic drive pump so it needs water to lubricate the porcelain shaft, it's not good on it to run it dry for long period of time just a short time, these pump eventually wear and will need to be replaced. they seem to last 2-5 years .. and back pressure is not good, so if say running a fountain bleed off excess water do not use a valve to restrict flow.. this is how we get the 5 years instead of the 2 ! .. jay the pump guy longwood fl
Jan 24, 2012 | Little Giant Garden
Pump runs for a few minutes becomes hot and stops then starts again
Pump motor is overheating or drawing too much current and the safety is shutting the motor down. After a period, it automatically kicks back in (quite common). Replace motor (and safety which probably comes with, or is actually contained inside motor).
:o).
Jun 04, 2011 | Little Giant Submersible Fountain Pump
OASE fountain pump fluctuates height every other day.
No there is not 2 speeds. That model is asychronous so power fluctuations can affect pumping. How clean is the plug end and how dry is the receptacle? Is there is chance a extension cord is used [code violation almost everywhere] in this hookup? Perhaps it's just debris circulation and restricting intake?
Jun 21, 2009 | Little Giant Submersible Fountain Pump
Need a water pump
you can get an equivalent size pump at a store like home depot or Loews.
May 15, 2009 | Little Giant Submersible Fountain Pump
Water fountaian will not work
The curcuit should be simple. The pump is the heart or this system it draws water to the pump(if it can't then the hose is plugged, or damaged) or the pump is bad. If the pump is working then it should be pushing water to its destination. if the water comes out the pump but wont or cant push the water to its destination then the impeller is bad.
Apr 26, 2009 | Beckett Water Gardening Beckett 7124110...
Little Giant Submersible Fountain Pump Logo
880 people viewed this question
Top Little Giant Garden Experts
Jim Goldsmith
Jim Goldsmith
Mike Squire
john h
Are you a Little Giant Garden Expert? Answer questions, earn points and help others
