Question about Hitachi 57F510 57" Rear Projection HDTV-Ready Television
Will not turn on when you turn it on it goes right back off
No Power
Posted on Jul 13, 2010
Dodge grand caravan when I turn my right turn signal on its normal then it will flash on the left side 3 times then it goes back to the right normal then the left side will flash 3 times again then it goes...
make sure each of the light bulbs on all signal lights, park lights, running lights, brake lights.
if they do --
pull the flasher relays and replace them.
Dec 17, 2014 | Dodge Grand Caravan Cars & Trucks
Tv goes off by it self but i can turnit back on
Short circuited component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 26, 2014 | Proscan 26LB30QD 26 in. LCD HDTV
Turns on for a few then goes right back off'
Sounds like you have a short causeing the TV to over heat and turn it self off too cool down.
Sep 12, 2012 | Sylvania LC320SS8 32 in. LCD Television
Turn on my tv and it goes right back off
tried to disconnect all the output connectors from the power supply board, then make a voltage checking if output voltage is available. if no output dc voltages or drop you have bad power supply board.
Sep 03, 2012 | Sanyo DP46849 46 in. HDTV
When I turned it on, it goes to the screen that has start windows
sounds like your boot record on hard drive is bad or hard drive turn on computer and hit like f10 or f12 it will tell you right after asus screen what key to hit for restore, if this doesn,t work hard drive is bad. hope this was helpful
Apr 15, 2010 | ASUS Eee PC 1000H Laptop
Mitisubishi 60607 will come on the go right back off
you have a component failure. begin checking the on-board fuses. that should lead you to the circuit that failed. most often it is the convergence circuit. 2nd most is a loss of vertical deflection. this is a tube protection circuit that shuts the set off before it destroys the crt's.
Jan 06, 2010 | Mitsubishi VS-60607 TV
While watching tv it just turned off, we turned it back on but no pictures but there is volume. also to turn it back on we see red light and green light together flashing then it turns off. i just replaced...
MY TV TURNS OFF AFTER WE TURN IT ON IT GOES BACK OFF A FEW TIMES AND THEN STAYS ON. AND WHEN I COME HOME FROM WORK IT STARTS ALL OVER AGAIN, THAT HAPPENED FOR 2 WKS NOW IT JUST GOES OFF YOU ONLY SEE THE GREEN LIGHT ON THE FRONT COME ON(POWER LIGHT) AND IT GOES RIGHT BACK OFF IT WILL NOT STAY ON
Sep 18, 2009 | Toshiba Televison & Video
Stuck in standby
Sorry about that. When the tv goes bad like not turning on, the green light will blink, and goes right back to red standby light while the dtv letters will briefly show on the lower right of the tv screen, then go back to blank screen. The tv will need to be taken to an authorized service center for repair. Common causes are a bad inverter/power supply, power control board, or circuit board.
May 16, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Olympus FE-190
on the right side of the camera where the memory card goes in thats where it is usally loose it it does that. try not to touch the part that slides out when you take the pictures or turn it on and it will be back to normal.
Jul 08, 2008 | Olympus FE-190 Digital Camera
Hitachi 57F510 57" Rear Projection HDTV-Ready Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
