Question about Car Audio & Video
I need to replace blown speakers in 2002 landcruiser
  • 2,272 Answers
The procedure is as follows:-- Step 1: Remove the arm rest bit. Carefully insert a flat-head screwdriver and gently pry up the soft bit. It comes off quite clean but be careful. Step 2:Do the same with the door controls block. Careful not to scratch this as it can get damaged very easily! You should now have a fully exposed arm rest. Step 3:Remove the wing mirror bit. This is only clipped in with a plastic washer thing at the top and its held in at the bottom by the actual door panel. Just pull at the top corner and it will come away from the door. Step 4: Remove the screws holding the door panel to the door. Step 5: Now Pry away the whole plastic door panel. You will find it easier to start from the inside edge and just give it a quick sharp pull.It will eventually all be loose and you then just lift it up and out from the top and away from the door (Below). NOTE: The white fixers along the bottom edge of the panel. Remove Speaker Cover
Insert a screwdriver (with the tip taped) between the door trim and the speaker cover to pry out and remove (don’t laugh at my blown speaker and missing cover). Check fig:--
Remove Armrest
Insert your screwdriver between the armrest and the armrest panel base to pry out and remove. Check fig:--
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Jul 07, 2010
My 89 landcruiser won't come out of 4wheel drive
Disconnect the Manual Lever and turn it by hand, if you can not... then you may have a failure of your Transfer Case.
Apr 15, 2013 | 2002 GMC Envoy
I have a 2006 Toyota Landcruiser Deisel 100 series. replaced battery now aircon, radio and all electrical not working... replaced all blown fuses and same result??? please help....
sounds like you hooked up battery backwards and cooked the wiring. why were there blown fuses? make sure it is connected with the +to+ and -to-.
Mar 24, 2013 | Cars & Trucks
Replaced my battery how do i resync my power windows on a 2003 prado landcruiser
dont need to. if they arnt working your fuse or braker is blown
Mar 12, 2013 | Cars & Trucks
2002 Ford Explorer Sport - Blown Subwoofer
yes you can replace it but is gonna be costly,because your gonna need a box plus the new woofer,any after market will not fit plus will require more power ,so your gonna need a bigger amp,plus wiring etc,,,,,re consider using a factory sub again or replace the sub plus the amp..check the replacements and amps at crutchfield..good luck
Jul 10, 2009 | Car Audio & Video
2002 toyota diesel landcruiser tdi
no filter in tank, replace the inline filters under the hood
Jan 30, 2009 | 2002 Toyota Land Cruiser
Car Audio & Video Logo
47 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
