Question about Maytag MDB9600A Jetclean II Built-in Dishwasher
Soap Does Not Always Dispense from the Soap Dispenser
Body:
Maytag Dishwasher, built-in, Model MDB6000AWB
How do we correct a problem when the soap does not dispense from the soap dispenser? It sets up like putty in the dispenser.
It will be fine for a few days then will have the problem for a day or two and then be okay for a few days. We have the problem 2 to 3 times per week.
  • lamarday Jul 07, 2010
    I will work with this for a few days and see if i have any more problems.
    Thanks.
  • 6,784 Answers
Hi. If there is still detergent in the dispenser when the load is done, make sure the cycle has actually finished, and make sure that nothing has blocked the dispenser cup from opening fully. Otherwise, you may have old detergent crowding your dispenser. Discard the old detergent and use fresh detergent if this is the case. With that said; If the detergent cup doesn't open, check the detergent cup, the bi-metal switch or wax motor, and the main control device. Make sure that no dishes are blocking it from opening.
The bi-metal switch I mentioned above is activated by the main control device and is an electrically operated device that bends when energized. It uses two different metals that are bonded together. As they warm up, they expand at different rates causing the metal to bend. The degree of bending can be set with a high degree of precision. There are many devices that use the bi-metal switch technology. A lot of newer dishwashers use a wax motor instead of the bi-metal switch. The wax motor has a wax block that warms up when the main control device energizes it. The wax expands as it warms up, and it pushes a plunger that opens the detergent dispenser door. Depending on how your dishwasher is wired, the switch may be wired through the motor circuitry or through the heating element. If the heating element is broken, there will be no electricity to properly energize the switch or heat the wax block in the wax motor to open the cup. If the motor is not energized, properly, the bi-metal switch will fail to operate properly, or the wax motor wax block will not warm up to expand and push the plunger, correctly.
On many dishwashers, an actuator arm links the main control device to the detergent dispenser cup. When the main control device reaches the correct time of the cycle, it activates a lever that opens the cup. If this link is broken or in any other respect faulty, the cup will stay closed,thus, not dispensing the detergent into the dishwasher. Check this linkage for faults. If there is a fault in this area, repair it or replace it.
Posted on Jul 07, 2010
  • Michael Masters
    Michael Masters Jul 07, 2010
    NOTE_ In your case, the wax motor will be the culprit or the connecting wiring at the motor circuit or heating element. I suspect that this may be a near by dish obstruction that is intermittently blocking the door on occasion.Run the unit empty for a couple of washes. if the dispenser works perfectly during the empty washes, this will confirm that there are dishes blocking the door when it is loaded form time to time. If you experience the same dispenser faults when the unit is ran empty, this will isolate the problem and confirm that the wax motor is damaged.
Door does not open to dispense soap
Often times the latch needs cleaning from the accumulated calcium and soap caked around the latch. Use an old toothbrush or sometimes something a little stiffer to scrub around the latch, the dispenser cups and in the general area. If there is still accumulation a small amount of CLR [calcium-lime-rust] remover will break down the accumulation. We had a Kenmore running in very hard water situation that wouldn't open and we just left it open and didn't worry about the dispenser door releasing. We did this because we always scraped off all the food in the sink before putting dishes in the dishwasher and then ran on the water miser setting which requires only one of the soap dispenser wells to be filled.
Nov 04, 2010 | Kenmore 15954 Built-in Dishwasher
Our soap dispenser doesn't always dispense soap
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 17, 2010 | GE Dishwashers
Model MDBF550AWB, soap dispenser is not emptying. Soap door opens but soap does not disolve.
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 05, 2010 | Maytag 24 in. MDB3700 Built-in Dishwasher
Washer will not dispense soap from dispenser.
make sure that the soap dispenser if clean and free of residue build up. if this is clean you need to replace the dispencer
May 19, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Soap does not dispense from cup.
heatman101
Sep 07, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
Dishwasher won't release the soap packet automatically?
There may be hardened soap caked in the works that must be dug out. If that doesn't work, the soap dispenser must be replaced.
Jul 30, 2009 | Maytag PDB3600A Built-in Dishwasher
Soap doesn't dispense
Make sure you do not have a cookie sheet or something tall on the bottom rack that is stopping the soap dispenser from opening. This happened to me and I returned 2 brand new dishwahers back to the store thinking they were faulty until I made this discovery.
May 04, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Rinse Aid does not dispense
http://www.partselect.com/ModelFrames.aspx?ModelID=149370&ModelNum=PDB2600AWX&mfgModelNum=&ManufactureID=1&Selected=54869&Position=1&mfg=Maytag&Type=&Mark=3
From diagram RINSE AID & SOAP DISPENSER, replace 138912t.jpg PS138912
Wax Motor for Detergent Cup Actuation.
Feb 20, 2007 | Maytag 24 in. MDB4100 Built-in Dishwasher
Maytag MDB9600A Jetclean II Built-in Dishwasher Logo
111 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
