Question about OKI MICROLINE 320 Turbo Matrix Printer
Feed problem I am having an issue with the feeding on my Microline 320 Turbo Dot Matrix. It seems like the something is wrong with feeding the paper..sometimes the next line will print on top of the previous line because of a feeding issue. Can you help. Thank You.
  • 14 Answers
Line gear has a broken tooth on it, possibly. or you have a sliver of paper stuck under the plenum (large black roller that paper wraps around to feed). you can pop the cover off, by pulling the front edge up and away from the base (clips in only, no screws). remove the plenum with tabs that pull up on either side of it. pull out the plenum, and check for any paper under that area. good luck.
chris
Posted on Apr 28, 2008
Oki microline 320 form feed
Am afraid the Power Surge (when the power came back on) has damaged the unit and there is no "Reset" to these printers. You would need to replace the control board but as its a power surge there is a reasonable chance that the power supply will have been damaged/weakened and this will lead to a shortened life span of the printer. I would throw it away and replace with new. sorry, ( I am not a salesman either)
Jul 18, 2017 | OKI MICROLINE 321 Turbo Matrix Printer
Documents wont feed
If not using track feed paper this printer should have a setting for paper height. If its set too high the
rollers wont grab the paper. Also look for any paper that might be jammed or caught up in any of
the roller mechanics.
May 09, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
My printer prints. The problem witht he printing is that it prints every line over the first line. It doesnt move the page up it just stays in one spots and prints in the same spot every time.
Check the lever setting on the right side. It may be in the wrong position. It controls whether it is tractor feed or friction feed by patten roller.
Is there any grinding, this could indicate a problem with the feed gears.
Jim
May 01, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
I try to print and the paper won't advance, prints everything on one line.
The unit needs to be cleaned and vaccuumed, pay carefull attention to the paper feed rollers. You might consider getting a Service Manual for it, if you do here is a link.
http://www.techmanualarchives.com/microline-320_321--turbo-service-amp-parts-manual-25647.html
Good luck.
Mar 13, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
The printer cannot be set to a page length when printing from a dos program. The page length is incorrect but changes with every print even though the same file is printed
Prints from DOS programs do not have a "page length" setting of their own, nor do dot matrix printer have a page length of their own.
Page feed is achieved by sending a special control code (^L), and the meaning of ^L can be set through specific escape codes that the DOS program has to know.
My guess is that you need to tell the DOS program the page size in lines or inches, and maybe instruct it to send a page feed command after each page.
You can try directly programming the printer, but if the DOS program is sending out the wrong codes, this is not going to help. Anyway, here goes. Good luck!
http://www.masondesigns.com/staging/dhl/printer/lasernet/turboset.html
Feb 01, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
I have oki microline 320 elite and printer head jams
In my own experience, Okidata printers have a nasty habit of collecting a lot of paper dust. To start out, I would suggest a really good cleaning, with no paper in the machine, with a can of compressed air. If that does not solve your problem, you might have to replace your feed wheel assembly. Hope this helps!
Nov 09, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata Microline 320 turbo problem
Solved this problem by going into the bios and changing the port from ECP to EPP, and then uninstalling the ECP port in device manager and replacing it with a standard parallel port configuration, no problems since doing that.
May 12, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
We have a microline 320 turbo. we installed a new dell computer and now cant get the printer to print corectly on contineas feed labels. The print head starts on the right side and prints off the sheet...
Try downloading and installing an updated driver for your printer.
Here is the driver download page for your printer: MICROLINE 320 TURBO < Drivers & software
Select your operative system, download the file, then run the installer.
Mar 03, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Oki Microline 320 turbo alarm light
First, make sure that paper feed switch is set accordingly to the paper path you are using (rear feed, bottom feed or friction). If you make a change, turn the unit off and on.
If it is set correctly, there might be an obstruction on the printer top cover that interferes with the cover sensors. This forces the printer to think that the lid is still open and will signal it as you have described.
The last option will be a damage to the sensors or to the mainboard. This is rare, but if the case, you need a repair center.
Be blessed.
Nov 07, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Page comes up blank !!!
check your rribbon.
also cjeck your head.
try to tast page from printer properties.
also try to print from dos .
check your printer datga cable.change it
Mar 25, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
OKI MICROLINE 320 Turbo Matrix Printer Logo
311 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
