Question about Kodak EasyShare DX7630 Digital Camera
Kodak EasyShare camera turns on, then right away shuts off. Same problem as two others posted here.
Most likely the battery Latch and spring are broken or lose.
Posted on Apr 15, 2011
When I turn on my camera it shuts off right away,i charged it many time for many hours, but no luck,it kees shutting down
by now you may have "cooked the battery!" you can over charge a battery,,,and if you do its then a dust bin job,,,try a new battery in it first,,,,
Aug 30, 2010 | Kodak EASYSHARE M1063 Digital Camera
Tip
Kodak EasyShare Z740 Turns Off Fix Does your Kodak EasyShare Z740 Turns On...
Does your Kodak EasyShare Z740 Turns On Then Turns Off right away?
Does your Kodak EasyShare Z740 Turns Itself Off with new AA batteries in it?
Many of these Kodak EasyShare Z740 cameras that shuts off right away and will not stay on, will actually stay on if you select FAVORITES to view pictures, but just flash back and turn off if set to auto or camera mode. Try this.
If the lens cannot extend, the camera will turn itself off. You can try giving the camera a thump with the heel of your hand, but I would recommend servicing the camera rather than smashing a delicate digital instrument. After trying the steps below, a last chance alternative that works for some people is to grab and actually PULL the lens out as it tries to extend itself. Again, its delicate; if you can afford it, maybe pay for servicing before hitting and pulling on your camera.
However, before servicing your Kodak Z740 try this fix:
  1. Hold down the Time/Ascending Folder button (the button under OK on the circular panel)
  2. While holding that down, press and hold the ON/OFF button.
  3. The camera may turn itself on and stay on this time, acting normally again.
If this doesn't work for your try this:
  1. Hold down the '>' button (the one that brings you to picture review)
If that doesn' t work, try again with the 'Trashcan' button, and ON/OFF button.
I hope that helps.
____________________________________
Kodak EasyShare Z740 Manual Download
on May 01, 2010 | Cameras
Tip
I hope that helps.
on May 01, 2010 | Kodak EasyShare Z740 Digital Camera
My camera turns on but turn off right away why?
I may be able to help with your Kodak EasyShare Z740 that turns itself off.
It may be a 'lens extending' problem, or it might be fixed with a combination of button presses to reset it while turning it on.
Try these steps to fix your camera.
I hope that helps.
_____________________________________________
Apr 27, 2010 | Kodak EasyShare Z740 Digital Camera
My daughter has a Kodak Easy share M863 when you turn it on it shuts off right away. Why?
this is normaly flat batterys they only like high power batterys in them
try a better set of batterys first,,, good one's!
Nov 12, 2009 | Kodak EasyShare M863 Digital Camera
I have the EASYSHARE M1033 Digital Camera
Mine did this as well. I now have it plugged into my PC with the usb cord. I think the ac charger that came with the camera is not functioning. Try charging it from your PC.
Aug 01, 2009 | Kodak EasyShare M1033 Digital Camera
Kodak EasyShare V530
Make sure batteries are NEW! Even half-way dead batteries will have negative actions on camera. Also if you have a memory card, try removing it and see if your camera act normal now. Some memory cards have different impact on digital cameras.
Kodak will fix any camera for $40.
May 13, 2009 | Kodak EasyShare V530 Digital Camera
When I turn the camera on the following message appears- high camera temperature, camera will shut off. The camera is a Kodak easyShare Z710
Have Kodak Easyshare V1253 with same, "high temp.," error then shutdown. Kodak batt. showed 25% charged. Charged batt 100% & temp. error went away. Batt. internal shows camera if batt. too hot. Try new batt.
Sep 12, 2008 | Cameras
Not staying on
Does this happen right away or after a certain amount of time? If you go into the menu and then into the Set-Up menu and then into Auto Power-Off you have the option of changing it to the time you want to camera to shut down. Hope this helps!
Aug 02, 2007 | Kodak EasyShare V603 Digital Camera
Kodak EasyShare DX7630 Digital Camera Logo
51 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
