Question about Minn Kota Maxxum 55 Freshwater Bow Mount Trolling Motor
Propeller/motor does not work
Motor was not working at all, then cleaned the pins and leads and now the steering works but the propeller does not. I can hear a clicking in the motor area when I step on the control pad but nothing happens. Battery shows a full charge on charger and on test button on trolling motor. I think all connectors are clean now and I'm clicking noise in the motor makes me think that the electrical connections are OK and trying to start the motor. Any advice?
Also, the plug is wired with a Red, Orange, and black wire going to a 3 prong male plug. I want to hook this up to a battery in the garage to test so I do not have to take back to the boat. How do I do that? Is the Red positive and the black neg and the orange an on/off switch wire???? Can I directly wire the black and red pins to the battery leads?
5 Suggested Answers
  • 4 Answers
SOURCE: minnkota trolling motor prop removal
remove the nut and the prop will come right off. Just be careful not to loose the shear pin.
Posted on Apr 30, 2009
  • 10 Answers
SOURCE: Hook up for one battery operation for minn kota trolling motor
I am not sure which trolling motor you have but click the link and scroll down to select your trolling motor the battery hookup is the last page
Posted on May 08, 2009
SOURCE: My trolling motor makes a roar type sound when I
There is a plastic race that holds the rear of the armature inside. It can get worn out and sloppy. My 40 AT was doing this and like yours, when it's out of the water it's fine. You only hear/see the problem when the motor is under load. Mine was caused by leaving it in the water when running around the lake with my 6 hp outboard. A good MinnKota repairman can fix if he knows what he's looking for. I had to take mine to two different dealers before the problem was found. Hope this helps.
Posted on Jun 19, 2009
SOURCE: bought a 1995 Four Winns boat inthe dash it has a
I own a 1995 Four Winns and what you need is a Lowrance LSM-1 depth finder unit. It accepts the two pin lead from the transducer and send the depth reading to the dashboard display via the 6-pin connector. There is also a three wire harness (red/blk/wht) that connects to a power supply.
The reason I know all this is my depth finder fried a couple years ago so I removed the Lowrance LSM-1 from the boat in order to find a replacement. Unfortunately, this was an OEM part that is not available from Four Winns or any aftermarket source. Probably your best bet is to look in a boat salvage yard or purchase an aftermarket depth finder.
Posted on Sep 19, 2009
My windshield washer is not working correctly.
Assuming you have washer fluid and you can hear the pump with no flow at the main line I would guess the turbine has separated from the pump shaft.
Sep 30, 2014 | 2006 Ford Focus
Boat propeller shaft seems to bind
Fishing line/net or another rope in the propellor??
Jul 17, 2017 | Boating
Horn working only when i turn the steering
then you need to remove the steering wheel and clean the tarnish off the brushes (springs and pins pressing against concentric copper circles) that lead to the wiring harness.
Nov 01, 2013 | Mazda Cars & Trucks
Power steering not working
Sirion 2006 model power steering system have some failure in EPS motor. remove your power steering motor and clean and fix it. power steering system will ok.
if it is not good tell me please what is the error code
if you don't know what is the error code you can check that your self's
Feb 03, 2013 | Daihatsu Sirion Cars & Trucks
Omg, i have had nothing but problems with my Dolphin Robo Kleen automatic pool vaccum and am so dissapointed. Is great when it works, but not working is what it does most.Barely get to use it each season....
possible bad drive motor if first power pack under powered motor and ruined it see if manufacturer will cover sounds like both motors bad tell them you need another unit
May 23, 2017 | Smartpool Dolphin Robo - Kleen Above...
Ex40-2 slow on one track motor,may be loosing digging power when working hard,have change hydraulic filter and track motors oil
I am assuming this is a Hitachi EX40-2 mini-excavator. Two tests that need to be run. First is the propel motor pressure equal to both propels? Secondly, but possibly more important is to check the slow propel motor for excessive case drain. This would indicate the propel motor is worn out. Find in your hitachi service manual the accepted amount of case drain for that model, disconnect the case drain line from the propel motor and cap the line. Install another hose to the case drain port with the other end in a 5 gallon bucket. Start machine and run propel for 30 seconds. Shut off and check amount of oil in bucket as compared to acceptable amount of leakage from machine spec book. All this does is measure the amount of leakage past the propel motor slippers, which gives an indication of excessive wear tolerances. Replace propel motor if needed.
Jan 04, 2010 | Garden
My power steering in my fiat punto has stopped working? The fluid is fine but the red steering wheel is alight on the dashboard?
either pump no pressure but no leak or steering rack failure,is power steering belt tight and spinning ok???
Oct 22, 2009 | Fiat 124 Cars & Trucks
Steering wheel is electric and is stuck in the down position.
it can be a relay, or the steering motor itself. the motor can be removed, but it is tricky to access. 2 holes need to be made in the lower panel to access 2 of the 4 screws holding it on. then, the motor can be taken apart and cleaned. this usually works. if the relay is bad, you have to locate it, it is down by the brake pedal, kinda hard to describe where in print.
Jun 10, 2009 | 1997 Mazda Millenia
Minn Kota Maxxum 55 Freshwater Bow Mount Trolling Motor Logo
71 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
