Mitsubishi vs-6043 Has faint black horizontal lines and a faint high pitch noise that fades in and out when the picture changes. Could there be some cold solder joints I can check?
I agree look for leaky capacitors on the main board
Posted on May 06, 2008
    Problem Solver:
  • 6 Answers
The problem sounds to be in the horizonal oscillator. It could be cold solder joints, but it is no doubt a leaky caracitor in the oscillator circuit. Check caps close to heat sources like heat sinks, power transistors and power resistors.
Posted on Apr 26, 2008
Plz check the stk ic,s
Monoscope signal how to get it Mitsubishi VS-6043 rear tring to adjust the picture its all warped looking got tv out of ditch tring to make it work
does the convergence align or move? how is the picture distorted? if the picture aligns but is just warped, use a jig or some string to have some straight lines to reference for your geometry and convergence. the monoscope signal is hard to find and mits had it on a vhs tape back in the day. it really just helped you get the horizontal and vertical size and get a round circle to fix the warp.. just try to make all the grid points about the same distance apart and make it an even grid.
May 26, 2010 | Mitsubishi VS-6043 60" Rear Projection...
MyMitsubishi VS-6043 Big screen TV just started to black out while we were watching it.I would turn it off and back on the picture would be there. Now the power light goes on but the screen is black. Is...
Not sure on that one. My local repair guru tells me the 6043's are constantly having problems. I've got one that I'm looking for board parts for, so if you end up not wanting to fix yours, I'd love to get your board set for some parts.
Nov 11, 2009 | Mitsubishi VS-6043 60" Rear Projection...
Vs 7070 no blueuntilwarm and has dark picture
Might be it is worth the buy a new TV,but it is not worth the money to fix it. It is a serious problem!
solutiondoct
Nov 10, 2008 | Mitsubishi WS-55809 55" Rear Projection...
No picture or sound
From the symptoms you describe, it seems the high voltage flyback autotransformer has failed along with the horizontal amplifier (they are slaved to each other). The sound comes from the flyback unit.
Well, the only way to solve this is to get a technician take a look at the set, I'm afraid. Repairs could cost upto $100 or more, depending upon the number of components that need to be replaced,
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
May 20, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Mistubishi 6043 A
Is there anyway you can post a picture of the lines on your screen?
Feb 23, 2008 | Mitsubishi VS-8087 80" Rear Projection...
No Picture
Rarely picture tube also shows the same symptom. High pitch sound is due to through deflection area LOT power supply is loaded. Compulsary horizontal output transister short. From your statement i think Lot puncture takes place. Change LOT and horizontal output transister and check tv is now working.
Aug 23, 2007 | Zenith A32B86R 32" TV
Black horizontal lines on mitsubishi VS-5043
Is the noise in all inputs (line, tumer) ? If it is in the tuner alone, check the coax lug to see if you knocked it loose. This could be the problem. Check you picture with a DVD player on the Video input. Let me know what you find.
Jul 03, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi vs-6043 turns itself off.
On this set it could be 1 of 3 common problems. first it could be the regulator ic in the sets power supply. It could also have a shorted horzontal output transistor because of cold solder connections on the horizontal drive curcuit. and finally could be cold solder connections on the colis and or the high wattage resisters in the sweep power supply and horizontal output section. You should first put the set if you can on a variac transformer and lower the ac voltage to 85 to 90 volts ac and see if set comes on. If it dosent static check the voltages on the pwer supply when powered up if they are there then check the horizontal driver and output problems.. If you understand what im saying and have the proper tools good luck to ya but if you dont it would be best to take or have a pro come and check it for you.
Apr 10, 2006 | Mitsubishi VS-6043 60" Rear Projection...
Televison & Video Logo
114 people viewed this question
Top Televison & Video Experts
