Question about Zodiac Baracuda G4 Automatic Pool Cleaner Ne221
My g4 doesn't function for any longer than 10 mins.It is weak and I have tried evrything but can't fix it
  • 819 Answers
There is a rubber diaphragm in the base of the unit that pulses with the vacuum, which is what gives it its movement. these are prone to hardening, and will stop functioning speratically. it is a cheap part and should be available at your local supplier.
FYI these rubber diaphragms sometimes have issues in cold water, as in 65 degrees or lower approx. the rubber is too stiff when that cold to properly function. good luck!
Posted on Jul 07, 2010
My cd/dvd player doesn;t play nor will it eject but evrything elsel on radio works
you can always have the serviced / repaired in order to restore functionality to the cd player.
A breakers yard/scrap yard may have a good/working replacement original....make sure you get a code if it requires one.
Jul 18, 2015 | Cadillac 2007 Escalade AWD
K5 Premium Eco weak pressure
first time use may be sticking valves inside pump head or poor assembly. run for 10 mins first to see if it fixes itself. then remove cover and remove each valve and inspect, it should be obvious.
reply with pump head photo if more information needed.
Mar 29, 2014 | Karcher Garden
JMB Television volume keeps switching off
If it works about 10 minutes and shuts down gradually, the fault must be with its audio output IC. Replace it.
Jun 30, 2013 | Televison & Video
Alero Stalling and Problems starting.
Check your fuel pressure sounds like to me the fuel pump is weak or worn out.
Dec 12, 2011 | 2001 Oldsmobile Alero
I replaced the battery and the sirius radio doesn't work - it is stuck on aquiring signal for over 30 minuites. The owners manual says to wait at least 10 minuites and it should resync but it...
Disconnect the negative battery cable for 10 mins, then reconnect it and try. Sometimes it can lock out the Sirius unit, and by disconnecting the negative battery cable for 10 mins, clears out the whole system so it can be booted properly.
Thanks Jay!
Jun 26, 2011 | 2007 Nissan Murano SE
Every 15 min wii netflex cuts out says lost sig or something like that -try again or reconnect, have to restart comp to get it back every 15 min
what you should do is first contact wii,if they give you rubbish information,tke out your game gently blow into the disc recever or take it apart and give evrything a good old tweak.
note1:do not hit your console ever,never ever,because it could damage your console.
note2:gently tweak evrything otherwise,YOU CAN SAY GOOD BYE TO YOUR CONSOLE!!
thank you for reading.
Jan 16, 2011 | Video Game Consoles & Games
My droid x got wet and after a night in rice it still won't turn on. Any chances of fixing it?
Let it remain in the rice bowl for a bit longer, after per say another night of "cleansing," insert the battery, which should also be in rice, back into the phone and plug it into the charger give it say 10 min, and try to turn on the phone, if this doesn't work, then either your shelling out 80 bucks after insurance for another phone, or god forbid there is no insurance, try going back to a flip phone. They are cheaper and not as liable to leave you stranded on the beaches if it should get wet again :-P
Dec 02, 2010 | Motorola Mobility Droid X
My laptop ibook G4 power button is not functioning even if press
have you got it plugged in too charger, power button wont function if no charge in battery..... easy to forget when your freaking out about your 3k lap top... goodluck Chas
Jan 31, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
It won't turn back on
Change the power supply to start. If the supply does not fix it, the mother board may have a fault. Most of these types of failures are in the power supply.
Jerry G.
Jul 07, 2008 | Apple iMac G4 Desktop
Zodiac Baracuda G4 Automatic Pool Cleaner Ne221 Logo
151 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
