Question about Epson TM-U220 Matrix Printer
Epson TM-U220 not working with window 7 - Epson TM-U220 Matrix Printer
Download this driver APD-406aE i did it and it is working perfect with my windows 7 on a TM-U 220B
Posted on Jul 23, 2010
May i know what type of cable are you using to epson TM-U220 printer.. i am using windows 7 and the cable type is serial to parallel. i have problems with printing.. need help
Posted on Sep 07, 2010
  • 10 Answers
SOURCE: Epson TM-U220 Matrix Printer not printing in WinXPP
hi basiime
possible issue is port configuration. if the generic text driver works, apd driver should work too.
what may be happen is that when you install the apd driver the other printer drivers that you have were still using the same port that your apd driver were using. example, you have generic txt assigned to lpt1 and then the apd were assigned on the same port, this is were you get the trouble.
what you must do is, first, check any printer driver that you have using the lpt, say for example, you generic text is using lpt1, when you install the apd driver set it to lpt2. apd drivers will create a new port normally called esdprt. try to use that port but if that will not work reassigned the port of your apd driver to lpt2 printer port then uncheck bi-directional support. from there you should be able to print..
hope that resolves your issue.. =)
Posted on Feb 24, 2008
  • 10 Answers
SOURCE: My Printer EPSON TM-U220 does not print....HELP!!!!!
if you are using lpt1 we expect that your printer is using a parallel cable. make sure that your printer is indeed using parallel cable and then check if there's a communication in between the 2 devices. to find out open your command promt then type in, dir>lpt1, your printer should print with or without a printer driver. if it will print, then possible issue is port configuration.. just make sure from the printer properties that you are using lpt. you can use esdprt lpt1 with bi-dir or lpt printer port without bi-dir support. you should be good to go from there. otherwise you may uninstall and reiinstall your printer driver..
Hope you can now use your printer..=)
Posted on Feb 23, 2008
Basti
  • 1447 Answers
SOURCE: epson tm u220
What type of interface card are you using to connect printer to your computer?
Posted on Apr 04, 2008
acdr
  • 1913 Answers
SOURCE: i m unable to install the epson tm-u220 printer in windows 2003
http://www.barcodesinc.com/epson/tm-u220-drivers.htm
download driver and install from here
Posted on Jan 24, 2009
SOURCE: Epson printer TM U220 (User Intervention Required)
I spent a good week trying to find an answer to this problem... and finally I HAVE THE SOLUTION!!
it's to do with the Port settings.
go to BIOS and change the port settings on your computer.
there are a number of different options that can be selected, just try them one by one, the one that worked for me was "Normal" try that one first, but it may be differnet depending on the printer.
if your LPT port is using it's own driver (not using BIOS to run) you cant change the settings using the BIOS. see if you can change it useing the settings for the dirver. if not try updating the driver. if that doesn't work, and nothing else works, reinstall Windows, that should fix the problem as a last resort.
good luck.
Posted on Jul 23, 2009
Unable to install Epson TM-U220B[U220 with UB-U02III usb interface] on Windows 7 AND XP!
Hi!
Are you using a third party USB adapter or a USB interface? On the self test page that you printed does it say USB connection or something that will say about USB? or does it say parallel or serial connection? try to check the dip switches setting if its configured properly. visit epsonexperts.com site for more info.
Dec 24, 2011 | Epson TM-U220 Matrix Printer
I need driver for Epson TM-U220PB (Windows 7 64 bit)
https://download.epson-biz.com/modules/pos/index.php?page=prod&pcat=5&pid=42 is the location for the drivers for the TM-U220 printers.
May 27, 2011 | Epson TM-U220PB Matrix Printer
I need driver for printer tm u220 for install for O.S windows server 2003
You can download the appropriate driver on the following webpage:
May 05, 2011 | Epson TM-U220 Matrix Printer
EPSON TM-U220 with Windows Vista
http://www.fixya.com/support/r672065-epson_printer_drivers
follow link to epson expert website
May 07, 2009 | Epson TM-U220 Matrix Printer
TM-U220PD oN WINDOWS VISTA STARTER
Hi, you should try these drivers for Vista...has a preety nice install wizard (works on vista for me).
http://rapidshare.com/files/167170222/TM-http://rapidshare.com/files/167170222/TM-U220.zip.htmlU220.zip.html
good luck
Nov 17, 2008 | Epson TM-U220 Matrix Printer
Epson tm u220
Mar 14, 2008 | Epson TM-U220 Matrix Printer
Change port to Printer port Lpt1 not the esdprt. then uncheck enable bidirectional support/ Restart computer and then try to do a windows test page
Jan 14, 2008 | Epson TM-U220 Matrix Printer
Epson TM-U220 Matrix Printer Logo
5,629 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
