Question about Microwave Ovens
I bought an Ultrex Blender/food processor/juicer from hsn a few years ago . The motor just burned out. Can I buy just the base? The other components are ok
    President:
  • 2,702 Answers
Not normaly,,its all or nothing,,,its a money spinner!
Posted on Jul 07, 2010
Is the blades supposed to come off when I take the container off of the blender.. My blender is brand new sat for 3 or 4 years after I bought it. . The first time I used it , it was extremely hard to get...
You did not specify a brand or model number of your blender; however, most blender jars will lift off their power base without turning or with only very little turning motion to release them from the base. The blade assembly should NOT come off as you remove the blender jar from the power base.
Were you successful in removing the bottom ring which normally screws on to the bottom of the blender jar from the powerbase?
You should make sure you have properly attached the blade assembly for your brand/model.
The blender blade assembly should be held on to the bottom of the blender jar by the bottom ring which screws on clockwise; most will have a sealing gasket that fits between the blade assembly and the sealing surface of the blender jar to prevent any leakage while in use. It will take much more turning to unscrew the bottom ring to release the blade assembly than it should to release the bottom ring from the powerbase.
Assemble your blender jar and blade assembly and try a dry run by placing on the powerbase, giving a couple of bursts of power, and then seeing if you are able to remove without the blender ring unscrewing.
Make sure you are comfortable with the action required to remove the blender jar from the powerbase before you put in to use.
Jul 31, 2011 | Microwave Ovens
Can't get my LOGIK L22FPS10 Food Processor to work properly can get the bender to work but not the food mixer.
Me and my family had the same problem there is noting wrong with it . You have to put the base lid of the blender on so it can work because the mixer and the blender cannot be on at the same time
Jul 25, 2011 | Microwave Ovens
Hi, I have a Bush Fp026 food processor and am having problems getting the mixer/processor element to work. The blender is fine, but how do I get the mixer working!? HELP!!
Are you sure you have the Model Number correct. I believe the Bush appliances are also marketed under the Kewwood brand name. Was able to find information for the Kenwood FP260. When you see the picture on the front you should know if it is applicable to your product,
The instruction book is available here.
The machine will not work if not assembled correctly. Check the schematic provide for assembly and make sure you are putting the processor together correctly. The fact the blender works fine suggests that when you assemble the processor it is not engaging with the safety switch which would allow power to engage.
Information on other models can be found here.
Feb 02, 2011 | Microwave Ovens
I have a Russel Hobbs Cambridge Food Processor and cannot for the life of me get it to even turn on...! YES it's plugged in and turned on at the wall. I have BOTH the blender and the processor on the...
Is this the 14499 Platinume\ Food processor? If so an Instruction Booklet is here. if not the same as your model perhaps similar enough to help out.
Jan 31, 2011 | Microwave Ovens
I have Ultrex II cookware. the nonstick interior is peeling off several of my pans and getting into the food. very disappointed. hope it is not a health problem.
most of this is teflon plastic , you have probably eaten worst . but there is a spray replacement to re-coat your cook work. just heat high and spray on and cool off and done non-stick again foe a few years at least . some can be purchased @ Walmart. or on Ebay hope this works out for you. use only plastic or wooden spoons etc, not metal it scraps it off again ....... >
Dec 20, 2010 | Microwave Ovens
My blender won't power on, the lights don't turn on. I've had the blender for 1 year and have never had any problems with it. In the past month it would only work intermittently, and now it doesn't work...
sometimes something (food etc) gets "stuck" in the lock mechanism, preventing it from turning. unplug the blender and give the locking mechanism a cleaning with a bottle brush or rinsing it under very hot water. also the lock could be broken/chipped, also preventing it from turning.
i must admit that I broke my locking mechanism 5 years ago by not "seating" it correctly and forcing it. my hubby somehow removed! the locking mechanism but now it goes on - turns - as soon as I plug my blender in (because the stop/lock doesn't exist anymore). so I must be very careful to always have the lid on before I plug it in. but it's a braun blender and I love it. so i've kept it all this time.
Oct 06, 2010 | Microwave Ovens
I do have cookwell's foodprocessor *** blender. I do not know why it is not working now. I tried to start it yesterday but i think fuge of motor is gone.Please help me
Mine cookwell food processor is not working when I bought it last week and I found out ths the Micro switchlever in the rimm is not high anough to been switch on by the bowl when you turn into place the bowl. The only way to fix it to keep it supress down and use the front to start the machine.
Thank you
Aug 26, 2010 | Microwave Ovens
Stopped heating
The magnetron (the part that heats the food) may be bad or the circuitry to the magnetron may have burned out. Basically my advice is that if you have no electrical expertise, it isn't worth fixing. The magnetron if bad, costs almost as much as a new microwave. If you open it up (make sure it has been unplugged for a few hours and don't seen any obvious burnt parts, then most likely the magnetron is done and a new microwave is the way to go.
Let me know how this works out for you.
Benjamin
Jul 17, 2010 | Amana LD10 1000 Watts Microwave Oven
Microwave Ovens Logo
114 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
