Question about Ingersoll Rand Type 30 Reciprocating Air Compressor 5 Hp, 80 Gallon, 230 Volt 3 Phase, Model# 2340N5
Connecting the compressor to a tank
I need to run the lines from the compressor to their destination on an Ingersoll Rand 230 air compressor
  • 760 Answers
You left that question rather vague. Are you asking what material? or What size? I normally would run one size larger pipe size than the outlet on the tank, unless the distance is great. You would connect to the tank outlet which is usually 1/2 way up the side of the tank. Use only black iron or copper pipe, plastic pipe is not strong enough for compressed air. There is some plasic tubing rated for air, but that looks sloppy and isn't inexpensive eitehr. Also put a "FRL" between the compressor and piping (FRL=filter regulator lubricator).
Posted on Jul 07, 2010
I need a manual to rebuild a Type 30 Model 2475 ingersoll rand air compressor. Thanks
Dear Joe Bell,
This is Rodciel L. Camacho of VISMIN compressed air care center we are specialize in ingersoll rand air compressor.
You mean a overhauling kit?The part number of that is 34319469.
Hope i can help you..
May 07, 2012 | Ingersoll Rand - Rand Type - 30...
I have an ingersoll rand 30t model 253 compressor 80 gal tank. what should the start and stop pressure settings be? what is the run time to fill tank and cycle off?
Hi
I'm not sure but I operate my'n at about a 145/150 top and about 110/120 min.
However others my have a differant perspective
Cheers
John
Jul 09, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
T30 model 2475N7.5 Ingersoll Rand will not bleed off head pressure when up to 145psi shuts down but will not start when at 95psi takes out breaker 50amp
If air continously comes from the bottom of the pressure switch (bleeder valve) you have a bad tank check valve. The check valve is located on the receiver tank where the copper line from the compressor head goes to the tank. The brass hex between the copper line and the receiver tank is the check valve. Remove it after making sure all pressure has been bleed off the tank. Then you can inspect it. I recommend replacing it unless there is something obviously stuck in it that can be removed with no damage to the check valve. Another way to see if it is the check vale is to loosen the nut on the copper line at the HP head that goes to the receiver tank. If air continously blows from the copper line the check valve is leaking.
Apr 29, 2011 | Ingersoll Rand - Rand Type - 30...
Trying to rewire my ingersoll rand air compressor motor, psi switch motor starter, need some kind of diagram, it has a 5hp single phase 220
Please check out the Web Site Below. It is a Quick Start manual for IR Compressors.
It should have everything you need. It DOES NOT Show you any wiring connections AT the motor.
Hope this helps....Jim
http://www.irtechpubs.com/ir_pdfs/Compressed%20Air/Air%20Compressors/Reciprocating%20Compressor/80445703.PDF
Feb 18, 2011 | Ingersoll Rand - Rand Type - 30...
I have a ingersoll rand 30, srats for 20seconds then trips breaker,,,runs great when running
Sounds like the unit is pulling to many amps during start up. Possibilities are: breaker under sized, wire under sized, to long of a run of wire from breaker for wire size,Tank check valve bad. I would check the amps during start up and while running and compare to motor name plate information. Remember at start up the motor may pull 1.5 to 2 times the rated amps on the name plate. Also if this unit has a magnetic starter wire connections may be loose or overloads to small.
Dec 07, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
Tank noise
Check for air leak,it might be a pop off valve,or the check valve,or the relief valve for the head pressure.
Jun 13, 2010 | Ingersoll Rand - Rand Type - 30...
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
Ingersoll Rand Type 30 Reciprocating Air Compressor 5 Hp, 80 Gallon, 230 Volt 3 Phase, Model# 2340N5 Logo
194 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
