Question about Amana ATB1504AR Top Freezer Refrigerator
The Freezer works great, however the refrig just wasn't cold.
    President:
  • 1,099 Answers
You need to check the temperature settings and see if there is enough air flow in the refrigerator . You need to check for air flow restrictions in the vents and clean the compressor coils. The door seals, door switch, defrost heater and timer has to be checked. Also clean the clogged drain tube and refrigerant leak.
ALSO NOTE THAT
A refrigerator not cold is a hassle, because you are at risk of spoiling the foods you store in there. Most often, this problem is caused by something easy to fix.
1. Faulty Door Gaskets
The door gaskets in a refrigerator ensure a sealed closure every time you shut the door. Torn or loose gaskets on the door of the refrigerator can result in a leak in the cold air. As a result, the refrigerator is warmer. Repetitive and frequent opening and closing of the refrigerator is also a possible cause, because the warm air from outside replaces the cold air in the refrigerator every time you open it.
2. Dirty Condenser Coils
Dirty condenser coils can result in improper functioning of the refrigerator. These coils are located on the back or the underside of refrigerators. If you find this to be the cause of the problem, unplug the refrigerator before you attempt any cleaning.
3. Frost-free Feature not Working
If the frost-free feature fails, it causes a buildup of frost around the evaporator coils in the refrigerator. This causes a malfunctioning of the evaporator fan that blows cold air around. The fan can also be damaged if it hits the frost.
4. Faulty or Incorrect Temperature Control
A faulty thermostat can lead to a refrigerator that is not maintaining the desired coldness. Check for this problem and also ensure that the temperature is set to the correct level. Normally, refrigerators are set to a temperature of about 0°C, whereas the freezer sections are around -17°C.
5. Inadequate Air Flow inside Refrigerator
A refrigerator that is loaded with too many food items can fail to maintain an adequate level of coolness across all the items kept in it. The surface items tend to be colder, and the items underneath do not become as cold. A refrigerator that has very few items in it can also fail to function efficiently. Try to ensure that your refrigerator has enough food in it at all times, but is not so loaded that the air flow gets constricted.
6. Vents between Freezer and Refrigerator Clogged
The vents between the freezer and refrigerating section blow cold air from the freezer across to the refrigerator. If these vents are clogged with ice, the air is blocked and the refrigerator does not cool down. If this is the case, you can unplug the refrigerator, wait for the ice to melt and then connect it back to the power supply.
7. Faulty Door Switch
The door switch is found on the bottom of refrigerator doors. It turns off the light in the refrigerator and resumes cooling action when you close the door. If this switch is not functioning properly, the refrigerator will not be cold and it will also be affected by the heat of the interior light.
8. Refrigerant Leak
A refrigerant leak is very unlikely. This problem can cause malfunctioning of your refrigerator. If you suspect this to be the cause, contact a service technician.
Hope this helpout.......
Posted on Jul 07, 2010
The freezer is great but the refrigerator section will not get cold
Refrig gets cold arir from freezer. Check the control that diverts cold freezer air into refrigerator compartment.
Jun 17, 2017 | Refrigerators
My refrig and freezer wasn't working good, i replaced the heater that goes underneath the coils. now my problem is the freezer is on 0 degrees and the refrig is on 60 degrees, i noticed the flap that...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 28, 2011 | Refrigerators
Freezer and refrig not able to set cold enough (freezer at 30 refrig at 49)
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Mar 06, 2011 | Arctica Refrigerators
Hi, Have a kenmore bottom freezer refrig. we moved and it powers up, fan works but both the freezer and refrig. part get cold. worked great before we moved it
Refrigerator
heatman101
Feb 14, 2011 | Refrigerators
Freezer cools great other side does not
the damper vent door between the refrige and freezer is not opening and letting in cold air from the freezer,they freeze up or the cold control isnt working to control the damper door
Mar 31, 2010 | Whirlpool Refrigerators
MY SIDE BY SIDE REFRIG IS NOT COOLING ,THE FREEZER WORKS GREAT BUT THE REFRIG ISNOT COLD WHATS THE PROBLEM. THANKS JOSIE
check to see if fan in freezer is blowing... if not then that's most likely your problem... air passage to refrig side may be blocked if it is blowing
Sep 24, 2009 | Refrigerators
ED25PQDW01 side by side refrig -freezer is inconsistent. Need to have full cold to maintain freezer temp. cleaned coils, but still an issue.
Do you see a light coat of frost in freezer section about 12 inches up (defrost problem indication) ? Has the icemaker slowed down a bit in ice production ? What is the refrigerator control set on ? When you turn the freezer up completely , it cuts off the cold air flow which cools the refrig section . If refrig control is set mid way , turn it up higher , so refrig will run longer , but lower the freezer setting so some cold air will enter the refrig section . Also check to see if the freezer fan is working .
Aug 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE PROFILE REFRIGERATOR-PSC25MSTA NOT WORKING
check to see if the fan by the compressor is working when the compressor is running if not you have the problem control board .....replace board
Jun 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a Domestic 2804 frig in my RV, The freezer works great but the frig part will not cool at all, can you help
All cooling takes place in the freezer. The refrig/fresh food side is a parasite, depending on cold air circulation from the freezer side. The fan in the freezer provides that circulation, and usually the freezer control setting determines how much air is moved into the refrig side.
If the fan is up to speed and the both controls are set in a middle position, the refrig side should be fine. if the problem continues, replace evaporator fan motor or clear the blockage preventing circulation (usually frost build-up from a defective defrost system part or blocked defrost drain).
Jun 13, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Amana ATB1504AR Top Freezer Refrigerator Logo
37 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
