Question about White Sewing Speedylock 1600 Mechanical Sewing Machine
White serger skips stitches
734D Superlock --- always very reliable, but now it's skipping stitches. I had it in for repairs, but the tune-up didn't last. I have put two brand new needles in it, and followed the threading directions to the letter. Also tried adjusting the tensions. I am tryng this out on cotton fabric, well-loaded with sizing. Nothing seems to help. What is wrong?
  • 185 Answers
SOURCE: White Superlock 1934D Serger Manual
You can get one from Central Sewing Machines.
1-877-486-0047 they have the book in stock. I just talked to them.
Posted on Feb 19, 2008
  • 106 Answers
SOURCE: bernina 1300 dc overlocker skipping stitches
Make sure the chain stitch thread is threaded exactly as it should be, make doubly sure the thread comes off the bobbin vertically and runs through all eyes smoothly. Any faults in the threading causes extra tension at the needle despite what the tension is set on.
If this is not the cause then the needle depth and the looper timing needs checking.
Rob
Posted on Mar 30, 2008
  • 4 Answers
SOURCE: is there a downloadable instruction manual for White Superlock 2000 ATS serger?
you're in luck, I have the same model and manual, I can copy it and put it to you in a file and email it to you if you want.
Posted on Apr 26, 2008
  • 15 Answers
SOURCE: I have a white superlock 228 jaguar serger problems with right needle
Couple of things I could think of: tension disks need cleaning, there is a site that tells how to clean them, maybe 2 as I recall. Other thing is it is a much older serger, (I have one I am slowly working on to bring up to working level), so it could be that a tension spring internally has lost its tension. It might need a trip to the repair man if that is the case. Another thing is are you using correct needles for the machine? Have you changed them recently? Even new needles can be bad, so if you have to change three times to triple check it can be worth it.
Posted on Sep 09, 2008
  • 43 Answers
SOURCE: skip stitch
The three most obvious causes (other than that of the machine possibly being slightly out of time) are:
1) Too small of a needle size - increase the size.
2) A needle that has a flaw / defect - change the needle.
3) Needle not inserted correctly, either not pushed all the way up into the needle bar, or not installed facing the correct place. On this machine, the small "scarf" in the needle (an indent just above the eye) shouldface the right side of the machine.
Posted on May 07, 2009
My brothers serger is skipping stitches
Many problems can cause a serger to skip. Start with the correct new needles and good quality thread. Skips can be tension a clearance or timing issue or the amount of thread pulled out by the thread guides. This is not something most consumers can repair. Even with the service manuals they can be difficult. I have spent thousands of hours working on sergers.and skipping at high speed can be difficult to solve. Some brands are more user friendly to service. This like will show some of the common settings and tools needed for a serger service.
Oct 13, 2013 | Sewing Machines
I have re-threaded, changed needles, adjusted the differential and cutting width but cannot sew a single seam without the stitches skipping, sometimes several in a row and sometimes only one.
SKIPPED STITCHES ON A SERGER
1. Is the needle bent or worn--replace
2. Is the needle inserted correctly into the needle holder--check needle
3. Is the Serger threaded correctly--rethread
4. Is the presser foot pressure right for the fabric--adjust
5. are the needles the correct ones for the serger
6. Possible timing problem--need to be checked at a sewing machine shop
Sep 18, 2013 | White Sewing Speedylock 1600 Mechanical...
Singer Stylist 11 Serger problems with right need skipping stitches how can I solve the problem
Jan 04, 2013 | Sewing Machines
My White SUPERLOCK serger, when I sew for only a minute or so, the stitch length does not stay at 3 but keeps going back to 1.
truthfully it sounds like the machine needs to be checked at a
repair shop because the stitch lengh should not change on it's own
Aug 21, 2012 | Sewing Machines
Jukie serger skipping stitches
have you tried changing the needles?
if you have changed the needles & it's still skipping stitches the serger needs to be serviced
Apr 16, 2012 | Sewing Machines
My machine is skipping stitches
Lower the pressure on the feed dogs, use a stretch stitch, and longer stitch length. Be sure to use a good quality thread, and maybe go lighter weight thread.
Oct 25, 2017 | Janome Memory Craft 9000 Computerized...
Lost manual for my white superlock serger model 2500
This may be another phone number to the same place, I'm not sure. But I lost my White serger manual, I called White Sewing customer Service at 800-331-3164, and they sent me to a website where I could download it for free. She searched for a minute, so it may vary by model, but I was directed to singerco.com and searched under manuals for "wsl734" for my White superlock 734dw. Wanted to share!
Jul 25, 2009 | White Sewing Speedylock 1600 Mechanical...
White Serger 1934D not stitching
No, Sounds like the loopers are not passing properly to pick up the thread, from off the needles.
Jan 11, 2009 | White Sewing Superlock 2000 ATS Mechanical...
White Sewing Speedylock 1600 Mechanical Sewing Machine Logo
301 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
