I need help to rewire my digi box, tv and video recorder up using scart leads
I eventually stopped panicking and then tried out as many different ways of connecting up the tv with video and digi box possible and eventually one of them worked.
So as Peggy Lee say's I'm a WOMAN..W..O..M..A..N !
Posted on Apr 19, 2008
How can I set up a Bush Digi Box with 2 scart sockets to a Sony combined DVD & Videao Recorder with 2 scarts to a Sony TV with 3 scarts
Bush Digi box - 'TV' SCART to TV
Bush Digi box - 'VCR' SCART to DVD/Video recorder 'TV' SCART
The digibox will pass through when the DVD/VCR is playing.
Aug 30, 2014 | Televison & Video
No instruction to set up the freeview box digihome dvb 915 can you help
Set up should be quite straightforward assuming you have all the bits.
You will need
  1. a standard co-axial aerial lead from your TV antenna to the female socket on the Freeview Box
  2. A scart to scart lead to connect the Freeview box (tv out socket) to the television.
If you wish to connect a video recorder or other equipment you may also need a second coaxial lead (male to female) for the RF through socket to connect to the aerial in socket on the video recorder.
If your TV does not have a scart socket you can connect the scart lead to the scart socket on a video recorder and then use the normal method of watching videos to view the Freeview TV pictures (here you may need to press the PAUSE button on your video recorder to prevent it going back into standby-mode after a few minutes).
Simply connect the box to your TV, turn on the power and the auto channel-scan will immediately detect and install all available channels.
If the Freeview box has been previously used in a different location / with a different TV transmitter you may need to re-tune it. Press the menu button on the remote control, scroll through the menu to set-up. Follow on screen prompts.
Feb 09, 2011 | Televison & Video
How can I set up my set top box so that I can still record shows from the TV on my VCR?
Take the main aerial and plug it into the digi box,then take a male to female fly lead from the digi box and plug into the vcr,then take another fly lead from the vcr and plug into the tv.Connect the digi box to the tv using a scart lead.
Jan 06, 2010 | Televison & Video
How do i set up atv without inbuilt digital a seperate digital box and a video recorder?the tv digital tuner and video all have scart leads.Should the aerial cable go to the video or digital box?
Aerial to digi box first then video then tv (not strictly necessary)
Depending on what you want to do with the vcr and the digi minimum scart connection is
digi to video - video to tv
Nov 08, 2009 | Computers & Internet
Is it possible to record and play dvd through a set top box....on a tv with only 1 av channel
If you take a scart lead from av1 on the dvd into the tv,then a scart lead from the digi box into av2 on the dvd,you will then be able to watch dvd and digi box,also you can record from digi box on channel av2 on the dvd.You may have to turn off a unit to watch one.
Nov 01, 2009 | Televison & Video
How do you set up digi box with VHS recorderand Tv. Digi box has two scart leads
Take one scart from the digi-box & connect the other end to the TV, & the second scart on the digi-box can connect to the VCR. To record from the digi-box, the VCR must be set to the AUX input (or AV ). The TV will also be set to the AV input, this set up will let you watch digital channels & to record a digital source. Be aware depending on your type of digi-box, you may not be able to record & watch two different digital channels at the same time.
Oct 14, 2009 | Electronics - Others
Equipment and Locations (Denons are physically 15ft apart) Room 1 Sky Plus Satellite Digibox; (without HDMI outlet), but with one optical, one scart-video, and two Scart outlets. Panasonic DMR-EX77EB DVD...
Hi Martin,
A wiring Schematic is not that you should be looking. What you need is large feeders to understand hot to connect to various ports to give your desired output.
Jul 03, 2009 | Denon Audio Players & Recorders
Hii i cannot connect my tv to the dvd player , can u tell me how can i fix this problem
I wrote this down to connect at Digital Freeview box to TV and to Video. It works for me on a portable TV and I am a grannie so if I can do it ............ I did buy one of those scart boxes which allows 4 scart leads just like an electric plug multi socket, very cheap price. Hope this helps and Happy New Year.
Take the scart connector box lead to the digi box.
The scart from the TV and the scart from the Video both go to scart box.
TV aerial itself not plugged in or used.
Bottom video aerial to right digi hole
Another aerial lead (not aerial) from TV hole to left digi hole
Jan 02, 2009 | Insignia LCDTV26 26 in. Television
DVD recording.
Sounds like the DVDR is recording from the digi-box through the TV, so when the TV is switched of or into standby the signal is lost, causing the recorder to pause.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
Feb 05, 2008 | Philips DVDR3380/05 DVD Recorder
Can't tune stations from freeview box to DVDR3380/5
You can only record freeview channels through your box.
If you are doing timer recordings, you will also need to leave the freeview box on the channel you wish to record, or set the freeview box timer.
Dec 15, 2007 | Philips DVDR3380/05 DVD Recorder
Televison & Video Logo
Top Televison & Video Experts
