Question about Samsung SyncMaster 910MP 19" LCD Monitor
Can Samsung syncmaster 910MP be used in Europe? 50hz, 250V input?
    Genius:
  • 1,478 Answers
Yes, it will work fine in Europe, the voltage rating is a good specification with the European rating.
in this case, your Samsung syncmaster 910MP will do fine in Europe.
Take care.
Posted on Jul 17, 2010
How much can u sell it for if it is used in very good condition
As your Samsung SyncMaster 910MP 19" LCD monitor was probably manufactured around 2005, has the old 4:3 aspect ration, is a TV without a digital tuner, and is lastly a "touch screen" which has very limited applications usually targeted to special needs (i.e., digital kiosks, point of sale, or other specialized applications.) These displays aren’t meant for standard desktop computing environments.
I have found brand new touch screens for as little as $95 to over $500. My recommendation would be to target a mid-range price that you feel comfortable with but understand that savvy shoppers will most likely not purchase it when they can have an up-to-date 2010 model with a manufacturers warranty.
The last SyncMaster 910MP sold on eBay on April 22, 2010 for $92.00
Best of Luck!
May 07, 2010 | Samsung SyncMaster 910MP 19" LCD Monitor
My Samsung SyncMaster 910MP has thin colored lines all over the screen, both horizontally and vertically. this problem came up instantly. Any ideas where i can look for this failure ? Unfortunately i...
This is either loose cable connection or faulty LCD. Try and take your screen apart. It's pretty easy normally get rid of all the screws and take plastics apart. Look for loose cable connection and resit any visible connectors. If this isn't working you more likely need new monitor. Good Luck
Apr 28, 2010 | Samsung SyncMaster 910MP 19" LCD Monitor
What is the power input voltage required to operate the phonic 1805x audio mixer? is this an AC, or DC input? unit missing power supply and needs to be bench tested for possible future use. no manual...
i have seen the manual. most mixers use ac mains supply with smps inside with +48V for phantom and ur mixer is one of those. u will see a three pin mains connector at the back. but phonic made these mixers for different countries. for us/canada 110~120Vac/60Hz - for uk/australia  230~240Vac/50Hz, europe/ asia 220~230Vac/50Hz.
Look for these or a voltage selector near the power input terminal. if u do not find any of these one sure way of finding which mains supply u should use is to open the case and look at the biggest rectifier filter capacitor on the smps board. 110~120V supply will have capacitors working voltage around 250Vdc and for the others around 400Vdc working voltage. (eg 1000uF, 250V or 1000uF, 400V)
so depending on the DC working voltage of the filter capacitor and country u either step up or step down the mains supply.
18Vac supply will never work.!
the rated mains voltage sometimes are printed on the smps board itself. Hope this helps.
Mar 13, 2010 | Electronics - Others
How to remove stand from a samsung syncmaster 910mp
It's usually 2 screw at the base of the TV, at the rear. Loosen or remove the screws and the base should slip right off
Sep 01, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
Hi, did you solve your Samsung SyncMaster 910MP problem? I have the same problem, I can't see TV but I hear the audio; do you know if it's only a setting problem or i have to bring the monitor in a service...
I had what you describe here, I could hear audio, see the menu, all was there but no picture. Then I found out that my 910MP had done a spontaneous reset of the Contrast/ Brightness/ Color/ Sharpness to 0/0/0/0 by itself. I have raised the settings again and the video is back.
May 13, 2008 | Samsung SyncMaster 910MP 19" LCD Monitor
Samsung SyncMaster 910MP 19" LCD Monitor Logo
117 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
