I have a 2001 Ford Mustang, v6 3.8 5 speed manual transmission, shifts hard
sometimes have to turn off to get into first gear, sometimes shifts ok
Hi Bobby, I found this bulletin on I believe the problem you are talking about. Hopes this helps ya put.. Cobra.. Please read..
FORD:
1999-2004 Mustang
ISSUE:
Some 1999-2004 Mustang vehicles equipped with a T5, T45 or TR3650 manual
transmission, may exhibit a hard to shift condition into first or reverse gears
from a stop. This may be due to an incomplete disengagement of the clutch (lack
of clutch pedal reserve).
ACTION:
Refer to the following Service Procedure. It may be necessary to adjust the
clutch pedal down-stop and the clutch pedal shaft nut to gain full pedal
travel.
SERVICE PROCEDURE
The clutch is not fully releasing. You can try putting it into some other gear first, then rapidly moving to first gear, but really, you need to either adjust the clutch, or get it repaired.
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html
transmission sticks in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html
Transmission not engaging in first
gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html
Vehicle only goes
in First gear?
http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html
Car is stuck in park
and the shift will not move?
http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html
Engine will not go out of park mode?
http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html
Car stuck in park?
http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html
Car will not come
out of Park?
http://howtobyme.blogspot.com/2011/11/car-will-not-come-out-of-park.html
Automatic
transmission will not go into high gear?
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Car wont downshift
sometimes?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-downshift-sometimes.html
Transmission
will shift into drive?
http://schematicsdiagram.blogspot.com/2011/12/buick-park-avenuetransmission-will.html
Auto wont shift
from park?
http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html
Car Transmission
will not go into Park mode?
http://schematicsdiagram.blogspot.com/2011/12/car-transmission-will-no-go-into-park.html
Shift indicator
directly goes to 2nd when key is turned ON?
http://schematicsdiagram.blogspot.com/2011/12/shift-indicator-directly-goes-to-2nd.html
Third gear missing
and engine losing power?
http://schematicsdiagram.blogspot.com/2012/01/third-gear-missing-and-engine-losing.html
Vehicle has whining sound in gear?
http://technoanswers.blogspot.com/2012/01/chevrolet-silverado-has-whining-sound.html
Hard to shift gears on Manual
transmission?
http://technoanswers.blogspot.com/2012/01/hard-to-shift-gears-on-manual.html
Car hard shift at slow speeds?
http://technoanswers.blogspot.com/2012/01/car-hard-shift-at-slow-speeds.html
Automatic transmission shift lever
hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
Gear shifts hard?
http://schematicsdiagram.blogspot.in/2012/02/2000-nissan-maxima-shifts-hard.html
Vehicle noticed sluggish
delayed shifts while driving?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-noticed-sluggish-delayed-shifts.html
This will help.
Thanks.
