Question about Garmin nuvi 205W GPS Receiver
Garmin will not come on. Hasn't been plugged in for a month.
Our original charger got messed up. We purchased another one from
Walmart. Still nothing. My daughter has the same nuvi, we tried her
charger still nothing.
  • 10 Answers
Given that you've tried other chragers, it seems likely the problem is battery related - especially if you've already tried steve's suggestion. How old is your nuvi? It is not uncommon for GPS batteries to go down after a year or two as they are subjected to temperature extremes and repeated charges and discharges. If the battery is the problem, it makes more sense to replace it for $30 than to spend another $300 on a new GPS. This can be done easily enough:
The company that produced the video sells a kit which includes the battery and tools necessary to do this yourself if you'd like. See: http://www.newpower99.com/ProductDetails.asp?ProductCode=GARMIN+NUVI+205W&Show=ExtInfo
I hope this helps. Happy travels!
Best,
Rob
Posted on Jul 13, 2010
  • Garmin Master
  • 3,287 Answers
Connect the GPS to your computer via the supplied USB cable overnight. The USB port on the computer will "reset" the battery to allow it to charge via cigar lighter when in the car or via an included (not all models included an AC adapter) AC adapter.
After an 8+ hour connection to the computer, the GPS battery should be able to receive charges normally again. If at any time if the future, the GPS will not charge, perform this charge method again.
It is also possible that the internal battery is now depleted and will no longer accept charges. In this case, you might want to contact Garmin Customer Support at the link below:
http://www.garmin.com/garmin/cms/site/us/support/supportcontact
Their telephone support is free and is the quickest way to review options or arrange for factory repairs.
Please rate this reply if you found it helpful - good luck!
Posted on Jul 08, 2010
I was told by Garmin that I would have one free map update after purchasing the unit. We tried to download the update, but it did not take and would like to know how to re-try the down-load. Can you help...
Yes, just redo the download. Be sure the unit is hooked up via USB and navigate to the Garmin site. The download and install take a REALLY LONG TIME. It is not grab a download and run. Up to hours...you just have to be patient.
Jan 01, 2011 | Garmin Nuvi 200 200w 205 265wt
I just purchased a germin nuvi 255w gps, at wallmart, they didnt tell me how to or that i have to charge it. i am in rural area and one hour from walmart. i have a charger for my hearing aids it looks like...
hi jadister
you should of got a car charger and a usb cable with your 255W...you can use the usb cable to plug in to your unit and the other end in to your computer USB port...let it plugged in for a few hours to charge it good.
bill
Nov 27, 2010 | Garmin GPS
Just purchased a Garmin 255W. Works fine if not attached to the car charger. Attached unit to the charge and normal navigation screen disappears. Shouldn't a person be able to drive/navigate and charge...
Hi sudavis70,
yes, you should be able to use your 255w while driving...if its going to the garmin screen ( or the screen with the computer icon) when plugged in to the car charger, then the car charger is probably either bad or not compatible with your unit..if its the original charger, i would buy another one thats made for a garmin.
the only time you shouldn't be able to use your 255w, is when its hooked to your computer.
i fix these and many other gps daily so when considering my advice , please understand i do not google my solutions.
let me know if you need more help or info
bill
Standing Member of G.O.T.
Nov 04, 2010 | Garmin nuvi 255W GPS Receiver
Garmin 13 00 will not turn on
CHECK THE FUSE IN THE TIP OF CAR CHARGER & THE BATTERY ON UNIT - IF THOSE ARE OK THEN CONTACT GARMIN FOR REPAIR BUT YOU HAVE TO HAVE YOUR PROOF OF PURCHASE TO DO THIS 800-8001020 OR GARMIN.COM/SUPPORT
May 09, 2010 | GPS
My garmin nuvi, which I purchased less than two months ago, no longer loads. It appears to start up with the introductory screen then goes blank. The charger is hooked up and is apparently working.
the battery is either to low or shot,
plug it in to either the home charger, car charger or usb for a few hours and try it again. once it starts, go in the gps main menu and see what the battery meter tells you (what does it look like, is the meter moving ect)
Jan 23, 2010 | GPS
I have a Garmin 760 did not come with a ac
The AC charger plugs into the mini-USB port on the bottom of the unit. The term AC is somewhat misleading as the AC charger plugs into an AC outlet but provides +5VDC to charge the units internal 3.7VDC battery.
You can purchase an OEM AC charger here:
http://www.sharc.net/gps_repair_prices.htm
- Jim
Aug 23, 2009 | Garmin Nuvi 760 Car GPS Receiver
2006 ford Explorer cigarette lighter won't charge my Garmin please help me trouble shoot
if lighter works, it usually means your charger plug in is not making contact with the center contact in the socket
Jul 28, 2009 | Ford Explorer Cars & Trucks
Is there a plug in charger
You can purchase a Music Power Duet USB AC Charger for iPod and MP3 Players or Simitlar. I got mine from walmart, follow the link.
http://www.walmart.com/catalog/product.do?product_id=5750794
Dec 11, 2008 | Disney Mix Max Digital Media Player
Garmin Nuvi 760
Sounds like you both have a battery problem. I experienced a similar problem when trying to charge via the USB-cable connected to my computer.
Ended up buying an original charger (expensive) and the charging went smooth.
The car charger should in any case work fine, so probably your battery is not very healthy.
Try holding your finger on the battery symbol for about 10 sec. The unit will then switch to a technical page. There you can observe the battery and charging voltage. When I plug in my computer USB-cable, I read around 4,4V and that is not sufficient for charging my battery.
When connected to the original charger, this voltage rises to about 5V which gives a nice charge. When unplugging charger, the unit displays the battery capacity. If the charging voltage is OK, but battery capacity drops quickly after you unplug charger cable, the battery is probably bad. (Of course you have to charge is for some time) I think around 4V battery voltage give 100% capacity. 3,9V gives about 90% capacity.
This will not solve your problem, but can give you an idea about what is wrong.
Good luck.
Oct 28, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin NUVI 200w
the same issue with mine, but mine cut out after one day. Purchased 6-9-08
Jun 09, 2008 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 205W GPS Receiver Logo
243 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
