I need a local (L.A. area) Konica Minolta Copier expect that makes house calls. I recently purchased a new computer and now I don't no how to install the right drivers and setup the new connection to my KM C450 copier.
  • Gail Williams Jul 17, 2010
    No one has responded but thank you nevertheless.
    Brigadier General:
  • 7,191 Answers
Please elaborate your problem providing us with more details of the problem.
Thanks for using FixYa.
Posted on Jul 15, 2010
  • AliTech110
    AliTech110 Jul 15, 2010
    You can locate a printer expert near your location from the FixYa Repair service Directory by clicking this link.
    On the page which opens, enter your ZIP code and click the Search button to display a list of names and contact details of the service providers near your location.
    Thanks again
Konica minolta 200 showing please wait
Sir/Mam,
Have you had the developer and drum replaced recently? Or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum or next to it depending on the series. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F 8 procedure/Developer Charge, and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F 8/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the F 8 is run. Or you will start all over again with new developer and a new drum.
May 10, 2016 | Konica Minolta Office Equipment & Supplies
Ow do i fix the error message MACHINE TROUBLE SERVICE CALL (0310) on my konica...
replace the print head. That's the part that houses the LASER. try this site for the part
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
if not try local Konica Minolta dealer
Sep 28, 2014 | Konica Minolta magicolor 1690MF All-In-One...
Bizhub 283 won't scan
did you load the new computer with the disk that came with the machine to load the scan software on the computer
try this site
Self Help Product Support Konica Minolta Business Solutions Inc
Apr 17, 2014 | Konica Minolta Bizhub 283 Copier
Konica minolta continuous printing
Have you had the developers and drums replaced or does the screen say Replace PC Drums? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the developing units next to the drums. Did you recently replace the drums and the developer if so did you clear the counters for the drums and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developers and a new drums and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the drums unit replace the developer. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. .
Apr 11, 2014 | Konica Minolta Bizhub Press C6000 Copier
Just got new Konica Minolta C224 copier. Prints from computer are perfect but when I try to copy something in color it prints page with thin even cyan or magenta lines. Lines are spaced evenly about 15 mm...
MAKE SURE YOU DO EXACTLY WHAT THE INSTALLATION MANUAL SAYES, INCLUDING DOING THE"Performing Non-Image Area Erase Check" I KNOW ITS A PAIN, BUT IF YOU DONT, YOU SEE WHAT HAPPENS
Aug 24, 2013 | Konica Minolta Bizhub C224 Color Copier /...
Konica bizhub C351 copier with BLACK area in center of the copy
u have to run the setup for machine if u like i can send u the step guide how to setup the machine
Aug 05, 2009 | Konica Minolta bizhub C351 All-In-One...
Frequent paper jams with my Konica 2223 photocopier
I wish I could help you, You need to call for service for your copier. An authorized dealer or Konica minolta branch service in your area. You might need a fuser unit that the upper separating claws disloge or broken, exit paper detect actuator is broken or disloged, or you need a new developer.
Feb 05, 2009 | Konica Minolta DiALTA Di200 Copier
C-2204 Error code on C-451
The error code C-2204 is a waste toner bottle code. Try replacing the waste toner bottle with a new one and then restart the machine.
Sep 18, 2008 | Office Equipment & Supplies
Konica Minolta Copiers
F26 Toner density adjustment problem. This means machine is undertoned. To repair, replace developer and enter "47" mode. Press 51. Press print. Allow the machine to cycle until it stops. Some feel that you should disconnect the toner motor first. This ??? ?????? happens probably because either machine wasn't set up properly, or the customer kept on using the machine with the toner light on.
Aug 22, 2008 | Konica Minolta Office Equipment & Supplies
Konica Minolta Di1610 can't print
hello
is it conect via net or parall port?
have you try to detect the printer by its ip ?
(ping)
pini
Feb 14, 2008 | Konica Minolta Di1610 Copier
24 people viewed this question
k24674
