Question about Maytag M6Y18F7A Air Conditioner
I need Maytag M6Y18F7A window Air Conditioner manual/diagram , thanks
SOURCE: Maytag Air Conditioner NMPEB08F2A
IF there is a lot of water, the float switch probably tripped. Happened to me, the water motor failed. When this happens there is no water blown up into the evaporator coils and it just accumulates.. and trips the float sensor. 2 problems with replacing the water motor. I can't get the part easily, and you have to remove all the plastic shrouding and drop the bottom out to get to it. (Steve)
Posted on Aug 16, 2007
  • 659 Answers
SOURCE: I need an instruction manual
After much research, you are going to have to call Maytag. Here is their contact info.
http://www.maytag.com/support/contact_us.jsp
Posted on Mar 24, 2009
gtmerkley
  • 190 Answers
SOURCE: I have a Maytag window air conditioner that is leaking out front
The unit has to lean backward to let the water run out. It sounds like it is too level or leaning forward too much. There should be an adjusting screw in back that you can lower and it should work fine.
Posted on Jun 27, 2009
  • 340 Answers
SOURCE: How to get the manual
contact the manufacture they have a web site. Tom
Posted on Jun 29, 2009
  • 92 Answers
SOURCE: NEED INSTRUCTION MANUAL FOR MAYTAG AIR CONDITIONER
maytags website probobly has that manual.
Posted on Jul 10, 2009
How to fix squeal in a Maytag airconditioner
no belt. should be a direct drive motor. most likely bearings in motor going out. you will have to replace motor at some point it will lock up. if it has oil ports you can try oiling to prolong but will eventually stop working.
Aug 30, 2012 | Maytag M6Y18F7A Air Conditioner
My 18000 btu Maytag window air conditioner does not cool. The compressor kicks on in an attempt to cool but no cool air comes out.
Hello my name is Heath it will be my pleasure to assist you. One thing I can suggest is try plugging the air conditioner into a surge protector.
Jul 01, 2010 | Maytag M6Y18F7A Air Conditioner
When running it squeels
sounds like the bearings are going out on the blower motor...........needs replacement.................
Jun 26, 2010 | Maytag M6Y18F7A Air Conditioner
Maytag M6Y18F7A Air Conditioner troble light turns off
you have to open the unit up or atleast see if the fan is failing. The blower motor is usually a double shaft and cool the compressor and also blows the air across the evaporator. Look for the air to stop blowing then the compressor to shake from overheating.
Aug 12, 2009 | Fedders AEY08F2FCOM Wall/Window Air...
I have a Maytag M6Y18F7A Air Conditioner window unit & am having problems w/ the thermostatic control not dropping below 75o. Originally, the unit switched to 67o which wasn't really a concern, but 75o...
This sounds like the control board has malfunctioned. You might have to have it replaced. When you have it on, does the unit switch off at 75o or does it continue to run? Also check the temp of the air leaving the unit, it needs to be below 55o's.
Mar 30, 2009 | Maytag M6Y18F7A Air Conditioner
I am trying to find a motor for M6Y18F7A
Hi Sal,
You didn't mention which motor you're looking for, so here is the condenser motor and her is the dual shaft motor. These links have part numbers so you can shop around for the best prices.
Hope this helps!
SG
Mar 26, 2009 | Maytag M6Y18F7A Air Conditioner
We have a brivis ducted evaporative cooling system and i was wondering how long we can safey run it continuosly?
When you say safely, do you mean operating it with the required doors and windows open? You can run it 24/7 as long as it is operating according to the owner manual.
Jan 30, 2009 | Maytag M6Y18F7A Air Conditioner
No POWER WHEN TURNED
lol not good , these unit are not meant tobe repaired make sure the outlet is not 220 check breaker or try other outlet.
May 16, 2008 | Maytag M6Y18F7A Air Conditioner
Maytag M6Y18F7A Air Conditioner Logo
94 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
