I own a Samsung 27" HDTV wide screen, approx. 3 yrs. old. I just changed out satellite providers. Dish Network to Direct TV. Before I did the change out I would have sporadic short loss of sound or crackling sound lasting 1-4 seconds, then it would subside for long periods then return. I thought it was the satellite provider but it does the same with the new provider so that tells me it is the TV itself. Any trends on this and is it in fact my tv?
  • DON BLACKSTONE May 11, 2010
    WHAT IS THE MODEL NUMBER OF THE T.V. AND WHAT INPUT ARE YOU USING FOR THE BOX. HDMI ?
    DON.
It sounds as if there might be a problem with your TV set .
I would suggest that if you have another source that you can connect the audio signal from the Direct TV Box to such as a receiver or amplifier. Connect the RCA cable to one of these
units and see if the problem persist, if not then you know it's
a problem in the audio ckt. in your TV set.
letmehelp
Posted on May 04, 2008
I have a procan tv w/o a remote, How can i make the remote that i have which is provided by dish network satellite work with the tv
Hello, the process to do this is fairly simple. Just follow the step provided from the link below, and you will be good to go!!!!!
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Becki Barned
DISH Network Customer Service
Sep 13, 2010 | Proscan PS27600 27" TV
Will I be able to receive HDTV programming on my TV?
Your HDMI Cable or Component Cables will plug right into their receiver box. You won't need anything else and they should supply the cables too.
Jan 06, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
After programming my NEW Harmony One Logitech remote I can't get it to change channels on the Dish HDTV DVR along with a bunch of other problems.
To control a Dish Network PVR/Satellite, it needs to be set to respond to the default Remote Address (1).
To reset your Dish Network PVR/Satellite to the default Remote Address:
1. Press SYSTEM INFO on the receiver's front panel. The System Information screen displays on the nearby TV and shows the Remote Address.
2. Using the original Dish Network remote, press and hold SAT on your remote control for about three seconds, until all of the mode buttons light up, and then release SAT.
3. Using the NUMBER PAD, press the 1 button
4. Press POUND (#). If you entered the address correctly, SAT will flash three times.
5. Press RECORD. Make sure the Remote Address you see on the System Information screen is 1.
6. Press the SELECT button on the front panel to close the System Information screen.
7. Your Harmony remote should now control your Dish Network PVR/Satellite box
NOTE: Dish Network PVR/Satellite receivers sometimes have two tuners, allowing them to be used in more than one room on different TVs. Harmony remotes can only control a Dish Network receiver's main tuner while still in the same room with direct line of sight to the device.
What other issues are you having with the remote?
Dec 25, 2009 | Logitech Harmony One Advanced Universal...
Philips flat tv. Can't get it to hook up to dish network. The room where the tv is there isn't a dish box. We have to watch what is on in the other room. It only has one coax cable to hook up. Don't know...
I should be channel 3 or 4. This assumes that this coax cable is coming out as a TV R.F. connection of a Dish Network Box (Satellite Receiver) intended for direct connection to an old fashioned NTSC (channels 2-13, 14-83, possibly even has cable channels depending on how old?) TV.
If this coax is the output of a coax going directly to the Satellite Dish or through what might might look to you like some kind of fancy splitter (called a Multi-Switch) the you WOULD NOT want to hook that to your old NTSC tv. The frequency is too high ... etc. etc... you would need Dish Box (as you call it) a.k.a. a Satellite receiver - with a good and active satellite card from your provider.
Jul 07, 2009 | Televison & Video
Philps TV problem
When I turn the TV on, I get a horizontal line across the screen approx 1/3 from the top. My TV make is Diamond and is approx 6 yrs old
Mar 14, 2008 | Philips Magnavox 27MS343S 27" TV
Hooking up a tv
Hi first of all are you using scart leads to plug into each device here is how it should be set up ok
1. Scart lead from dish network into vcr
2. then other scart from vcr into tv
3. Now ti recieve the signal from the dish network you need to have the telly on the right av channel so that its picking up the signal from the vcr.
you can test this by changing the channel on the vcr controll or direct via buttons on vcr.
If the channels change then your on the right av channel.
Now when your on right channel on telly you need to now make sure dish network is on and on a channel or press the tv guide button just so you know what your looking for when the picture comes through.
You need to press av on the vcr controll this will then pick up the signal from the dish network via the scart lead as av is the channel for scart lead.
say if you was recording from dish net to vcr you would put the vcr on av to pick up the signal so press av on vcr controll this should then allow you to watch the dish network with no problems.
Let me know if you still cant and ill assist you further if it dont work tell me what you have done so i know how much you have done ok
Feb 10, 2008 | Toshiba TheaterWide 46HM94 46" Rear...
Picture sometimes goes to zoom mode when changing satellite channels
TV should still be in warraty, if this needs to be fixed, you should be able to get it repaired/replaced for free from the manufacturer
Oct 20, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
