Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
The service person replaced the fusible link on my LAARS Lite 2 heater. It worked for a while, but then it stopped (won't turn on or heat). I removed the two wires from the fusible link and shorted them together and the heater starts to work again. Why is the fusible link burning out? It has an automatic pilot light and Natural gas supply. What are the possibilities and where do I look.
    Problem Solver:
  • 11 Answers
The fuse link is a saftey for flame that is rolling up into the cabnet,There are a few things that will make this happen,down drafting from wind,cloged flue,burners cloged,gas pressure.Turn it on with the cover off and stand back look to see if any flames are rolliing up near the fuse link.
Posted on Jul 11, 2010
Jandy lite 2 fl 7
Pressure switch will do exactly what you checked for, when the pump is not running. voltage on one side but not the other is normal when the pump is off. With pump on & operating, you should have voltage on both sides. One lead on the common wire at the transformer and the other checking the flow of electricity across the switches.
It sounds like your roll out sensor/fusible link is burned out. This burns out (open circuit) because of a "Reason"!!! The heater needs to be checked by a professional service company. Heat exchanger in most cases is Sooted & needs to be cleaned/desooted.
good luck
May 25, 2014 | Jandy Laars Lite 2 Pool Heater 125,000 Btu...
How to replace laars lite 2 LD250 ignitor
turn off power remove white leads from fenwall remember which goes to which on bottom in middle unscrew 5/16" screw remove install new one dont bump or it will break hook wires back up it should work
May 21, 2014 | Teledyne Laars Laars Lite 2 Pool Heater...
Have a problem with a laars mini therm ii boiler. the pilot keeps
hi. i have mini temp boiler 150 btu 5yers old . it is burning with know radiation .it is up to thempitio .but it will not shut off.flame is good radietor is hot ,help?
Nov 04, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Laars lite 2, mod-lg125n, sn. d03pj3400.
sounds like heat exch is plugged.remove top of unit and inspect for nests.could also be plugged with soot because of poor burner flame characteristics.with top off,turn htr on and look straight down into unit. you should be able to clearly see burner flames between fins. if not remove exchanger and clean
Jun 07, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars LX400P pool heater Hi Limit Switch light is on? ???Fix?
This indicator normally means that your water temperature in the pool heater exceeds the internal limit. The corrosion should not be causing this problem. Since the high temperatures can be dangerous, you will probably have to contact a pool professional to service the machine.
May 31, 2009 | Teledyne Laars Laars Lx Pool Heater /...
Pilot light on but heater will not start
check the high-limit switches. Under the inlet/outlet header. if either is open it will not allow you to fire up. my 150 degree switch was corroded and after jump9ng out, bam it worked.
May 25, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Will not ignite
First check thermostat is calling for heat or if gas valve fault get unit serviced
Dec 10, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Heating & Cooling Logo
153 people viewed this question
Top Lite On Heating & Cooling Experts
1STHVACMAN
Paul Carew
Michael Galve
Michael Galve
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
