Question about Kenmore HE2 Plus Front Load Washer
Sometimes when we put the soap in it runs out the dispenser and straight down front of washer - ??
  • 273 Answers
Check to see if a small item has lodged itself into the dispenser or the dispenser tube.
Posted on Jul 07, 2010
The compartment that you put the soap in sometimes fills with water when the load is finished
THAT MEANS ONE THING. REMOVE IT AND RUN IT IN WARM WATER, CLEAN IT OF ALL SOAP FILM AND ETC. ON THE SLOT FOR THE BLEACH AND FABRIC SOFTENER, FILL WITH WATER TO THE MAX LINE, LET IT SETTLE, THEN ADD WATER TO IT AGAIN AND SEE IF IT FLOWS THROUGH DOWN TO THE BOTTOM OF THE DISPENSER.
Aug 04, 2010 | LG WM-2077C Front Load Washer
Water leaking into soap dispenser when machine off
faulty water valve turn both off to see if it stops then turn on one at a time if it leaks thats it
Dec 15, 2009 | Miele Touchtronic W3033 Front Load Washer
Water is pouring out of where the soap dispenser is. Can anyone help?
its pouring out because the dispenser is getting clogged in somewhere and not letting the water to the drain pump so its pouring from the soap dispenser. Remove the dispenser, pour water into the opening and make sure water can get into the machine freely. Inspect the opening for soap build up.
If water goes down slowly , open the washer door and feel around the bellow for anything blocking the water inlet port into the washer (socks can sometimes get wedged up there and cause a blockage).
If it all checks out ok, make sure the machine is properly leveled and not leaning forward.
Hope that helps!
Jul 09, 2009 | Kenmore 43142 Front Load Washer
Soap dispenser keeps filling with water after everyload. I have to empty after load. The dispenser is also growing mold.
You should clean the soap dispenser regularly by removing it from the washer.
Some units have a release clip but some just need to be pulled out firmly by hand.
Then give the tray a very good clean as no soap residue should be present. It sounds like the fabric conditioner cycle is filling the relevant tray section but unable to drain through blockage.
Should be pretty straight forward to remedy.
My regards
Marc
Apr 17, 2009 | Frigidaire GLTF2940ES Front Load Washer
Soap powder remains in the soap compartment
Depending on which compartment the powder is remaining in, it could be low water pressure causing the problem.
If it is taking some down, but not all the powder, then try putting the powder towards the front of the compartment.
If all else fails then I suggest you get one of these dispenser balls that you put straight in the drum with the washing.
Plz rate this solution.
thanks.
Dec 28, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
SOAP DISPENSING
The soap dispenser is intended for both liquid and powder detergents. If you have a problem with mildew, then you may need to clean it occasionally with bleach water.
Aug 07, 2008 | Hotpoint WMA50 Front Load Washer
LG WM2277HS - water backing up into soap dispenser
The pipe from the soap dispenser to the tub is quite large, it seems as if the water isn't getting out of the dispenser quick enough. Pull the whole dispenser out of the machine. There is a release clip at the back of the cup with the tray fully open. Clean out all soap residue and scum. Sometimes there is also a spot or setting for liquid or powder detergent. Adjust accordingly. Reassemble and try it again.
Apr 08, 2008 | LG WM-1485FHD Front Load Washer
WATER LEAKING FROM FRONT BOTTOM
try onscrewing top panel on machine...when machine agitaes strongly a hose my pop lose up from top.
Jan 22, 2008 | GE WBVH6240F Front Load Washer
LG front loader problem
If you remove the top cover you will see the soap dispenser unit on the left. It has a large rubber hose connecting it to the drum. If you remove two screws at the front you can free the dispenser for maintenance. You can undo the clips on the various hoses and check that they are clean.
Some people report some dripping from the soap dispenser even when the hose is unblocked. This seems to be a design fault.
Nov 04, 2007 | LG WM2277H Front Load Washer
Soap dispenser drip
Normally you shut off the wall valve when you are thru with your washing. If there is a leak in the front area (important: first take the plug off the wall) open up the top of the machine and check whether the three rubber tubes are in place at the soap dispenser - one of them may have come off. Refit or replace if rubber tube is damaged; would be good to check all the tubes. Another thing would be to check that your soap dispenser is not clogged. :)
Sep 21, 2007 | LG WM1815CS Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
77 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
