Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
Carburetor tool i need to adjust my carb on my husky 455 chainsaw but it has a special adjusting screw. where can i get the adjustment tool.
  • Ian Summerfield
    Ian Summerfield Jul 07, 2010
    sometimes they put a plastic cap over the screws to stop people playing with them.describe the screw?
  • 3 Answers
The splined Poulan Carb Adjustment Tool, 530035560, which was readily available for less than $20.00 before 2013, has become scarce and bottom the feeders are price gouging. Check ecrater.com and curtschainsawparts.com. I just received one and it is the quality item at very reasonable price, $14.00
Posted on Jul 06, 2013
  • thatron Jul 06, 2013
    Brigadier General:
  • 4,088 Answers
Unless you are skilled enough to make your own, you are stuck taking the saw to a servicing dealer as they are the only ones allowed to possess the necessary 'D' head screwdriver. Give thanks to the EPA for mandating the prevention of mal-adjustment pollution.
Posted on Jul 07, 2010
Remove limiter tabs on a carb off a 2012 455 rancher
need special tool to adjust carb can buy them on ebay.
Oct 18, 2014 | Husqvarna Garden
Setting hi lo on 235 husqvarna
You need a special tool to adjust the mixture screws, i have to say they are not easy to tune, you will also need a rev counter to set the high revs, it is very difficult to give basic settings for the carb as they vary greatly
Sep 30, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a 16 in 235 Husqvarna chainsaw that starts find and runs for a few minute. then acts as if it is not gettting enough fuel as it starts to bog down while running and will not maintain idle.
It may well just need the carb adjusted, unfortunatley there is a special tool required the adjust the screws, the L screw on the carb may need richening up, so if you manage to get the tool unscrew it by 1/4 out ( anti cliock wise ) tool part no. 530035560
Mar 20, 2011 | Husqvarna Garden
How do I adjust the carb it starts but shuts off hard to get started, is there a tool for adjustment
If the adjuster screws have a spline rather than a screw driver slot, then the special tool is part no. 530035560, be carful adjusting the H screw, this will govern the max revs, if you exceed 12000 rpm you could cause damage to the engine, you realy need a means of testing the max revs, a tachometer.
Feb 23, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My 455 Rancher Husqvarna 20 inch chainsaw wont stay running while idling. its a brand new saw. don't know if it needed to be adjusted or if its pre adjusted already. Starts and runs fine but just won't...
Carb adjustmwnt requires a special tool and a tacho, the saw is set from the factory for the best emmisions, however it may need a small adjustment, this should be done by a qualified dealer, incorrect adjustments can damage the engine.
Jan 02, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I can start my chain saw but when I give it more gas it stalls.
Hi jbboitnott,
There are 3 things I can think of that would cause that problem. First, the saw was not warmed up enough. Second, did you cut the choke back after your saw warmed up? The third cause would be that your carburetor is not adjusted correctly.
If you did the first two things, then you could try adjusting your carburetor. The carb has to have a richer mixture when it's cold than when it has warmed up. If you have your carburetor set with the mixture too high, it would start but then choke on the extra gas when it was warmed up. Thus, you should lean out the carb.
Huskys carb adjustment screws are on the same side as the oil and gas fill caps. They are above the gas cap. The screw on the left is for leaning the carb, the one on the right is to richen the mixture.
So, turn the left screw, sometimes marked "L", counterclockwise to richen the carb. Adjust a very small amount at a time. Let it run a little, cut some wood, then adjust again, if need be.
I hope this helps. If it does, I'd appreciate your vote. Thanks for visiting fixya.com
Handie Andie
Dec 15, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Husky 125B blower, new right out of the box. starts, runs about 30 sec, bogs and quits. I'm guessing likely needs carb adjustment, but set screws are not regular slotted screws. Looks like it requires a...
My name is Dane and I am going to assist you in solving your problem.
You will need to adjust the high speed setting on your Carburetor jet. Turning the screw out just 1/2 turn or so should do the trick. It is not so hard to adjust the Carburetor, however, yes you do need a special tool that is very hard to get your hands on, in order to adjust the jet screws. They don't make many engines with plain screw heads anymore. The newer Carburetors are factory set lean so they can pass emission standards. Since you just bought yours, a local husky dealer should adjust the mixture for free. I hope I've helped. If you found this reply useful, please leave me some THUMBS UP, if you feel I
Dec 09, 2010 | Husqvarna 28cc Hand Held Blower HVH 125B
Member Discussion on Husqvarna 240e Chainsaw Idle Adjustment I have a new 240e and cannot keep it running. It will start, after many pulls, and one of two things happens. After running for 30...
Its not an idle screw adjustment issue, it is a mixture screw adjustment issue, unfortunatly there is a special tool to adjust the mixture screws, pt no. 530035560 ( available from Hysqvarna dealers ) once you have this tool you can make an adjustment to the L screw on the carb, undo ( anti clock wise ) this screw ten minutes on a clock face ,this will richen the muxture, and should make it more stable on idle.
Oct 07, 2010 | Husky Husqvarna Chain Saw 240E w 16in bar
I have a new Husky saw that does not maintain accelleration. I'm operating at 7,500 feet above sea level. And apparently you need a special tool to adjust the carb? And there is nothing in the manual on...
All modern saws are set to operate very lean at sea level (thank the EPA). If you bought it locally take it back to your Husqvarna dealer, he should adjust it without charge. If purchased at a big box store or on line I'd take it to a dealer at the altitude where you use it and ask them to adjust it. there will be a fee but running it to lean will cause it to fail. A few dollars spent for an adjustment will certainly be less expensive than a new saw.
Lou
There are tabbed plastic caps on over your fuel adjustments. Thank the EPA once more.
Sep 04, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna Model 141 Chainsaw Carb adjustment
The tool you need is available from Randy's Engine Repair, on his E-Bay store. The price is about $10., plus $3. shipping. Phone for Randy's is (937) 927-5665. It is usually busy.
Ebay item number is: 390025452838. Buy it online. I got mine about a week after I ordered it.
Jul 18, 2009 | Husqvarna Forest & Garden No.967012396 345...
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
800 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
