Question about Texas Instruments TI-83 Plus Calculator
TI-83 Plus-- no power
I dropped my TI-83 on the coffee table while sitting and now it will not pwr on--I replaced the batteries but still no pwr--help...
    President:
  • 3,278 Answers
Hello.
See if it's a contrast issue by increasing the contrast.
Try removing the batteries and short the battery terminals IN THE CALCULATOR with the batteries out for about 30 seconds. Use a piece of wire. Sometimes a key ring works.
It's possible that the inside circuits were damaged by the fall, tho.
Hope this helps.
Posted on Jul 07, 2010
  • sheshaw30341 Jul 07, 2010
    Hi.
    How do i use the wire or key ring? I mean what would i do once i take the batteries out?
    sh
  • NinaE Jul 07, 2010
    Hi, SH.
    With the batteries out, take a piece of wire and touch the terminals inside the T1. It may not make a difference, tho.
I cannot power up ti-83 plus after i replace new batteries
Having gone over a month without a reply to my query, I assume the suggested contrast change solved the problem.
Aug 31, 2011 | Texas Instruments TI-83 Plus Calculator
Ti 83 plus has vertical lines and upside down numbers that wont clear
try taking out the triple A batteries and leaving the calculator to sit with them out for a minute or so, replace them and check if it's fixed. If that doesn't work you can do the same, but take out the small button back up battery as well. If you're still not having luck you should call ti cares (800-842-2737) they're usually helpful.
Aug 10, 2011 | Texas Instruments TI-83 Plus Calculator
Power won't come on
Something may have gotten jostled inside, hopefully not broken though. Try taking all the batteries out and then putting them back in and see if it will turn on.
Jul 07, 2010 | Texas Instruments TI-83 Plus Calculator
TI-83 Plus ram cleared message when turned on
It calculator tells you Ram Cleared each time you turn it on, the most likely reason is that the backup battery is depleted. Its role is to keep the memory modules electrically refreshed when calculator is turned off. If the backup battery is dead, the memory is erased when you turn calculator OFF. Main batteries no longer supply power and the contents of the memory are cleared.
  1. Check that main batteries are good and inserted in calculator.
  2. Turn calculator OFF.
  3. Replace the backup battery.
  4. Turn calculator ON.
  5. Press the [CLEAR] key to erase the "Ram Cleared" message.
Jan 19, 2010 | Texas Instruments TI-83 Plus Calculator
TI-83 Plus will not let me view a table
I have just done what you said you had done, but I got a nice, correct table of values. You might have discoverd a secret command to clear memory.
Cheers.
Apr 14, 2009 | Texas Instruments TI-83 Plus Calculator
TI-83 Plus
this could be an assymtote and if you really want exact answers use the table function or just press trace and type in an x value
Sep 13, 2008 | Texas Instruments TI-83 Plus Calculator
TI-83 Plus Problem
For the baos problem, just remove a battery, leave it out for about 5 seconds. Before replacing it, hold the del key. Replace the battery while holding the del key. The calculator should turn on and display: "Waiting... Please install calculator software now." Connect it to your comptuer and install the TI-83 Plus OS.
Jun 01, 2008 | Texas Instruments TI-83 Plus Calculator
TI-83 Plus "waiting ...please install message then "error message
Please Install Calculator Software Now error
This message means that the operating system has been corrupted. These steps will allow you to update the OS.
Unit to Unit
• Connect two TI-83 Plus units by means of the data cable (short black cable that was prepackaged with the TI-83 Plus)
• Make sure that at least one of the TI-83 Pluses contains the current Operating System
• Select [2nd] Link
• Select "Send OS" option from the Link menu
• Make sure that the other unit still reads "Waiting Please Install"
• The OS should be downloading.
From the Computer
• Make sure you have the latest version of the TI Connect™ Software
• Download the latest version of OS for the TI-83 Plus to the desktop of the PC.
• Connect the appropriate TI-GRAPH LINK™ cable between the PC and TI-83 Plus.
• Since the TI-83 Plus is currently off, the TI-83 Plus will automatically turn on when the TI-GRAPH LINK Cable is inserted.
• On your computer, choose Start, Programs, TI Tools, TI Connect, TI OS Downloader.
Dec 10, 2007 | Texas Instruments TI-83 Plus Calculator
Ti-83 plus silver edition for overhead projector hook-up
You can try to put fresh Back-Up batteries into the calculator. If not, you can always call the customer support at Texas Instruments to see if you can get a replacement part for your calculator. This may resolve the problem you are currently having. Hope this helps.
Aug 20, 2007 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
170 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
