Question about NetGear WGT624 Wireless Router
Trying to install a netgear wireless router.
I need the following codes:
subnet mask
default gateway
preferred dns
alternate dns
  • 493 Answers
You can write;
Subnet mask:255.255.255.0
Default gateway:24.218.156.1
Preferred DNS and Alternate DNS:
If your ISP gave you one or two DNS (Domain Name Server) addresses, select Use Theese DNS Servers and type the primary and secondary addresses (preferred and alternate).
Otherwise, select Get Automatically From ISP.
Note: If you get 'Address not found' errors when you go to a Web site, it is likely that your DNS servers aren't set up properly. You should contact your ISP to get DNS server addresses.
If you need user manual please write me.
Hope this helps.
Waiting your comments.
Posted on Jul 07, 2010
Need to set up wireless router
you have two ways:-
  1. DHCP (Dynamic Host Control Protocol)
  2. Manual entry of settings in wireless adapter properties.
1.DHCP:-
In DHCP method you dont have to enter any settings on the wireless adapter. The wireless network which you are connecting will automatically assign an IP Address to you. But to use DHCP it must be supported by your wireless network.
This method is mostly used over wireless Connection in small networks connecting 2-200 computers. In this method you have to obtain the following information from your connection provider.
  • IP address (Its format is "xxx.xxx.xxx.xxx")
  • Default gateway address (very important)
  • Primary and secondary DNS (If not given then you can use "8.8.8.8" as primary DNS and "8.8.4.4" as Secondary DNS...thats free DNS service from google and its very fast)
  • Subnet Mask (not needed mostly...automatically generated)
Sep 25, 2010 | NetGear WNR2000 Wireless Router
Ok i have my router hooked up my laptop will connect but destop will not go online?
Checking IP
For Windows XP or 2000:
1. Please click on Start and select Run.
2. Type in cmd and click on OK.
3. In the Command Prompt, please type ipconfig/all then press Enter or Return key.
For Windows 9X or ME:
2. Type in winipcfg and click on OK.
3. Once the IP configuration window opens, click on the drop down box and select your Ethernet adapter (Note: Do not select dial-up adapter, VPN adapter or AOL adapters).
For Windows Vista:
1. Click on the Windows icon and on the Search box type in run.
2. At the upper left pane of the start menu, please click on run and type in cmd on the text box. Then, hit the Enter key or OK button.
3. On the black window, type in ipconfig/all and hit Enter. You should see the following:
IP address:
Subnet Mask:
Default Gateway:
DNS Servers:
For Macintosh:
1. Click on the Apple icon, select Systems and Preferences and click on Network.
2. Choose the adapter that you are using on the Show drop down list. Then, look for the following values:
IP address:
Subnet Mask:
Default Gateway:
DNS Servers:
Apr 10, 2010 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
How do i use my wireless ethernet? it recognizes the 1394 net adapter and i have the needed drivers with no splat problems. do i need to set up a wireless connection through the connection settings? i have...
If you are in a network, you need to have a thing called IP address which is usually assigned by a DHCP server or a wireless access point.If DHCP Server is not available in your case then you need to configure evreything manually.If DHCP server is available then you don't need to configure anything.Just search for the WI_FI signal and connect with it.
For manually configuring Wireless Network Setting
Go to control panel and click "network and Sharing Center", click Change Adapter settings" Right Click on the wireless adapter, Select "properties", click on "Internet Protocol version 4(TCP/IPv4)".
Select now use the followinf IP address,
Manually fill the IP address :
                       Subnet mask :
                       Default Gateway:
Select "Use the following DNS address "
Manually fill Preferred DNS address:
                Alternate DNS address:
For example :                           IP address               : 192.168.0.10
                       Subnet mask               : 255.255.255.0
                       Default Gateway           :192.168.0 1
                    Preferred DNS address    :218.248.234.117
                     Alternate DNS address   :218.248.136.142
IP address is needed for communications between devices.
subnet mask is needed for identifying your Network Address Node.
Default Gateway is usually your Router or Wi-Fi access point IP Address.
DNS address for resolving domain name(mostly for Internet browsing)
Hope you can connect it now.
HAPPY NEW YEAR.
Dec 31, 2009 | Gateway 4525GZ Notebook
Intermitant signal
on your computer goto start - run - type services.msc and press enter.goto wireless zero configuration and enable it. now goto start - run type msconfig and press enter then goto startup and uncheck your netgear adapter.press apply and OK or close. restart your computer.goto start - control panel - network connection then right click wireless network connection and view available wireless networks.select your network and connect.once it`s connected goto start - run - .cmd - enter..type ipconfig..you`ll get ip address,subnet mask,default gateway.copy it. now right click wireless network connection again and click on properties and double click on internet protocol(TCP/IP).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
this will fix your problem...
Jun 11, 2009 | Arris SURFboard SBG900 Wireless Router...
Error message that says the setting on this computer for the
well, there are several possibilities for this. I would first check to see if DHCP is enabled on the router, also check the connection on the computer to see if it is automatically getting it's settings from the router (this is what it should be doing with DHCP on). It sounds like the IP address and/or subnet mask are configured incorrectly, possibly even the default gateway or DNS settings. On your average home network you should see 192.168.X.X for the IP address of the computer and 255.255.255.0 for the subnet mask. The Default Gateway is also usually 192.168.X.1
Hopefully this helps, post a comment if you need any more help.
Apr 01, 2009 | NetGear WGT624 Wireless Router
Unable to get DNS Server Addy
YOU HAVE TO TRY TO INSTALL ORIGINAL SOFTWARE , SOME
OF THAT MAY BE CHANGED BY USE - DELFO
Mar 20, 2008 | NetGear DG834G Router
Problem with netgear wgr614 v6 daisy chain
I am assuming the Verison was setup and working before this started, if not let me know.
Do you know the address and subnet mask for the lan side of the Verison Actiontec router? assumed like address 192.168.0.1 subnet mask 255.255.255.0 This means all addresses 192.168.0.? belong to the verison router's subnet.
Assuming the Netgear router is being daisy chained using a lan port from the Verison Router to the WAN port of the Netgear, the WAN side of the Netgear router needs to be either dynamically addressed or statically addressed in the 192.168.0.? uniquely outside the DHCP range for the Verison router.
The LAN side of the Netgear Router must not be addressed the same as the LAN side of the Verison router in this configuration.
There is another potential configuration where lan ports of both routers are connected. however in that configuration there are additional considerations. Please let ne know which connection you are attempting between the two routers.
There is some additional informatin you can gather
Assuning you have windows XP for the operating system on your computers hook a computer wired if possible to the LAN side of each router and issue the following commands
Click Start then All Programs then Accessories then Command Prompt in the new window that opens type the following command and press enter
ipconfig
write down th IP Address, Subnet Mask and Default Gateway for each adapter
Then issue the following command once for each default gateway not = 0.0.0.0 where {...} is replaced in its entirety with the default gateway.
pring {default gateway address no {}}
the expected responses will be either 4 timeouts or 4 lines with elapsed times. Timeout is failure -- elapsed times means it was connected.
For each router I need to know the default gateway and the subnet mask for the successful pair. Plese reply ina comment to this problem and additional steps will be forthcomming.
Dec 21, 2007 | Computers & Internet
Belkin router
A couple of items to check -- these will not fix the issue but may isolate the problem.
Turn all machines on before the test and do not turn off until after
On at least one wired computer that is working and maybe all wireless computers I want you to do the following
In the window that opens type
ipconfig /all
press enter then record all of the following for each adapter
  • adapter
  • IP address
  • Subnet Mask
  • Default Gateway
  • one or more DNS addresses
The back in the window enter the following command using the default gateway from the wired connection (your router address)
ping (default gateway)
you will either get 4 timeouts -- the connection fails or 4 messages with elapsed times generally measured in ms or milliseconds.
What you are looking for in the above
Good entries base
x.y.x match each other if subnet mask is right
u should be unique for the network
Wired IP address x.y.z.u not 0.0.0.0 may be 192.168.0.u
SubNet Mask ?.?.?.? assuming 255.255.255.0
Default Gateway x.y.z.? not 0.0.0.0 may be 192.168.0.1
DNS addresses ?.?.?.? not 0.0.0.0
where at least one is not zero.
Then wireless entries should be
SubNet Mask same as wired
Default Gateway same as wired
DNS addresses same as wired
If these are wrong there is a configuration error either in the router or wireless adapters depending on how you want your network setup.
each connected adapter wired and each wireless should also
successfully ping the default gateway or router address
If the ipconfig is right and the wired config has successful pings, then every wireless adapter that fails has a wireless config issue.
If you are willing to work through this let me know and reply with information in a comment to this issue.
You may also want to address wireless security
See this response and let me know what you want to do.
Wireless security
Dec 16, 2007 | Computers & Internet
Open Questions:
See all NetGear WGT624 Wireless Router Questions
NetGear WGT624 Wireless Router Logo
73 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
