Question about Dryers
Have a whirlpool dryer model WED5300VWO problem is unit won't shut off timer issue ?
catriver
  • 878 Answers
SOURCE: dryer won heat timer dosen't avance
huntman, the model posted shows as a gas dryer. In the lower left side there is a square plastic peep hole. Take a putty knife and pull it off. Set the dryer to high heat and take a look in the hole. Does the ignitor glow? If it doesn't you either have a bad thermal fuse or a bad ignitor. Start with the thermal fuse. You will have to remove the back panel to get at it. I will attach a photo. You can ohm it out, or just jump the wires temp. to see if the ignitor glows. If theral fuse is good and the ignitor does glow, you probabley have a bad set of coils. These sit on the gas valve are easy to replace. The timer won't advance without the heat. Check this out first...Catriver..post back.
Posted on Mar 15, 2007
Jimster
  • 240 Answers
SOURCE: Timer on dryer counting down too fast
Now that there is a good one. Everything you are saying leads to a control board failure. Did you replace the board yourself, or have someone else do it? I have before gotten a new control board of the shelf, and it be as bad as the one I was replacing. Just a thought. Let me look around and see if I can find some other information, just really sounds like a bad part.
Posted on Feb 15, 2008
SOURCE: whirlpool dryer: supreme Not heating up
I had the same problem I change the gas valve coils and it seamed to be working fine.
Posted on Jan 07, 2009
  • 1122 Answers
SOURCE: kenmore heavy duty clothes dryer will not heat
REMOVE THE BACK AND CHECK THE HEATER FUSE AND THE HEATING ELEMENT-MIKE
Posted on Feb 26, 2009
  • 43 Answers
SOURCE: Whirlpool lte6234dq5 Dryer does not turn off.
Could also be centrifugal switch on motor.
Posted on Apr 25, 2009
Elect dryer making noise it works
you need to check the bearings on the machine back and front.
Jul 10, 2014 | GE Clothes Dryer Cycle Select Knob...
Changed timer/whirlpool model leq9508kq1/dryer runs in accudry mode, wont shut off,what is wrong?
if it wont shut off this is a timer problem contacts fused closed,are you sure this is a new timer?(some are remanufactured)
Feb 12, 2013 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet dryer time skips mins.
clean the stainless steel sensor pads located just inside the dryer door with isopropyl alcohol,these sensors register moisture in the garments and adjust drying times accordingly,when you use dryer fabric softener sheets it coats these sensors and throws the system off,make sure to shut off power to unit as this alcohol is very flammable,then leave door open to air out before re-powering up unit
Apr 24, 2012 | Whirlpool GEW9250 Electric Dryer
Won't stop, have to manually open door
Sounds like a bad timer. Your dryer is a Whirlpool product.so a replacement timer should be easy to locate. If the timer is advancing but the dryer won't stop, the problem could be the control unit. Run another load of clothes and take notice of the timer's position. If it doesn't run out, then it's very likely the timer. The video below shows step by step instructions for replacing the timer unit.
Mar 30, 2012 | Estate TEDS740JQ Electric Dryer
Whirlpool dryer model wed5600sq0 won't cool down
If it does not shut off during the cool down part of the cycle then the issue is with the electronics
Mar 10, 2012 | Whirlpool Dryers
Whirlpool WED5300VWO replacement belt
this belt is an FSP part # 341241
Feb 12, 2012 | Whirlpool Dryers
The dryer works and heats up but it won't shut off
I believe that your timer has run out of time! ;) Seriously though, Your problem is more than likely your selector (the dryer timer knob) is worn out. Time to replace it with a new one.
Good Luck my friend!
Phillip
Dec 27, 2011 | Whirlpool Washing Machines
My dryer won't start unless i find the right spot
Hello would you happen to have the model number of your dryer? It sounds like you actually have two issues one being the timer itself and the other being either a hi limit thermister but the timer would be the last thing that you would test. If you happen to have a multimeter when you message me back your model number I can locate your schematic showing which parts that you would test by assuring each has continuity.Here is also a video on basic ways to test and diagnose heat issues with a dryer click this link http://www.youtube.com/watch?v=f1rebeCMVsk if you have any questions message me back those as well. I await your reply Thanks
Rick
Sep 16, 2011 | Roper Dryers
Dryer timer won't shut off at end of cycle. Dryer runs, but no heat. It is a Whirlpool model number LGR4634JQ2.
Since you say that the dryer runs but have no heat, plus the timer won't shut off the odds are the timer is bad. The timer would tell the burner when to be on and when to shut down.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=265840&diagram_id=28265980#d28265980
21 partimage.aspx?imgid=z3bqljbfahrfndg1njc5my9mufcvc290b2hwdhjhcc8%3d
Enlarge Photo
Timer
Part Number: AP3037407 made by WHIRLPOOL $91.55 In Stock
Order now and it will ship Today
Jun 09, 2011 | Dryers
Wed5300VWO dryer only dries clothes occasionally. Some times takes 1 1/2 hrs for small load. waist bands on pants damp etc, All thermostats have been replaced by repairman
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 11, 2010 | Whirlpool Dryers
Dryers Logo
195 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
